Projects 1962 Biscayne Jr Stocker for the Street Build
Discussion in 'Traditional Hot Rods' started by Stock Racer, Mar 15, 2022.
  1. Poverty cap
    Poverty cap
    Cool build man, I’m enjoying watching your progress.
    Stock Racer likes this.
  2. Stock Racer
    Stock Racer
    Other than some remaining floor work, the bottom of the car is completely painted :). I used good old semi gloss black Rustoleum.
    IMG_6370.jpg IMG_6372.jpg IMG_6373.jpg IMG_6375.jpg IMG_6379.jpg IMG_6382.jpg IMG_6383.jpg
    lewk, swade41, saltflats and 16 others like this.
  3. Stock Racer
    Stock Racer
    Thanks! Glad you find it interesting.
  4. Stock Racer
    Stock Racer
    Rolled her outside today and did a deep cleaning of the car and the shop.
    lewk, HOTRODPOWELL, Outback and 18 others like this.
  5. Stock Racer
    Stock Racer
    After a short break I'm back on the floor pans. Started on the right front today.
    Saving the support bracket in the upper right corner was a bit of a pain in the *** but everything else went as expected.
    She's slowly becoming rust free ;)
  6. Stock Racer
    Stock Racer
    Got the RF floor pan roughed out and saved the stiffener.
  7. patsurf
    patsurf
    Outback and Stock Racer like this.
  8. pivir123
    pivir123
    Outback, Stock Racer and 427 sleeper like this.
  9. Stock Racer
    Stock Racer
    Great question and thanks for asking. I would say it was. It's a channel with compound curves which would be difficult to re-create. It was in great shape as the rust was on the inside of the floor pan. Lastly, the floor pan was so rusted that it was only held on by two spot welds (easy to remove) and the grinder cleaned it up nice. Here's a couple pics that hopefully show it better IMG_6492.jpg IMG_6493.jpg
    Outback, saltflats, Cosmo49 and 6 others like this.
  10. Stock Racer
    Stock Racer
    Thanks! I don't have the space or equipment to do this right but I'm an old, stubborn guy with spray cans and a creeper. :D
    treb11, lippy, pivir123 and 5 others like this.
  11. Dave G in Gansevoort
    from Upstate NY
    And iron oxide grit in your teeth! Great progress.
  12. patsurf
    patsurf
    i see!
  13. ALLDONE
    ALLDONE
    I just joined the group...also ripped both bi-ceps from the bone... so no shifting or pushing a clutch in...
    being old ****s,,.. but getting here was hoot!!!!!!!!!!!!!!!
  14. Stock Racer
    Stock Racer
    Yea, my Race Car is a 4-speed and I am considering putting an automatic in it. The stick is so much fun to race but it adds variables to a run and even though I have a soft loc clutch it still breaks parts. As you age, it's all about making things easier. I want to race the Biscayne so It will have an automatic. I do have a 4-speed set-up for it and when I get to the point that it becomes a street car only, I'll consider putting it in.
  15. Stock Racer
    Stock Racer
    I got the right front floor pan fitted. It doesn't look like a lot of progress but I've spent hours on it. One thing I've learned during this floor project is the better the fit, the easier it is to **** weld and the nicer it comes out. A little extra time here saves aggravation.
    I also got the core support and fan shroud in primer. I've had these parts back from the blaster since back in the spring. They went to the back of the shop and had been forgotten. Decided to get them in paint while it's still nice enough to paint outside.
  16. Dave G in Gansevoort
    from Upstate NY
    Looking good! Does paint taste better than grinder grit?
  17. Stock Racer
    Stock Racer
    Thanks and I'm trying not to taste it but it smells better:D
  18. Stock Racer
    Stock Racer
    Right front floor pan cleaned up, primed, and tacked in. Sprayed some rust encapsulator into the exposed area of the floor brace and painted the parts that I wont be able to get to after the pan is installed.
    No pics (cause it's kinda boring) but I changed the right door hinge pins and bushings. Not necessary at this point but the door would drop down, close like ****, and it was driving me crazyo_O. IMG_6503.jpg IMG_6505.jpg IMG_6511.jpg
  19. saltflats
    saltflats
    from Missouri
    Great progress. I still have more rust to cut out of my car.
    I got pulled away from my project to work on a few more 62s. One a real SS that was a 6 cylinder automatic now 409 4 speed with ignition problems a 62 Biscayne getting a 409 4 speed and a Impala rag top turned SS getting a 409 and 5 speed. Funny back in my day job people found out I worked on British and that was what I worked on most. Not having my day job I have been working on a lot of 62 Chevys now.
  20. Stock Racer
    Stock Racer
    Thanks! Looking forward to seeing you get back on the Shaker.
    SS327 and saltflats like this.
  21. malibumonte78
    malibumonte78
    Sounds like a nice retirement!
    saltflats likes this.
  22. Stock Racer
    Stock Racer
    I didn't get much garage time this week but I did get the RF floor pan welded and cleaned up. Hoping to get the stiffener welded on this week and clean up and paint the bottom.
    Deutscher, brEad, lippy and 8 others like this.
  23. saltflats
    saltflats
    from Missouri
    Keep swinging the axe and the tree will fall. Looking good.
  24. Grumpy ole A
    Grumpy ole A
    Love your build, keep up the good work.
  25. Stock Racer
    Stock Racer
    Thanks guys!
    Tickety Boo and saltflats like this.
  26. Stock Racer
    Stock Racer
    I finally got the RF floor pan finished up. Cleaned up the **** weld underneath. Plug welded the stiffener with a couple self tappers holding it in place. Hit it with a coat of short strand fiber reinforced and then some gold. Got it painted.
    IMG_6551.jpg IMG_6547.jpg IMG_6554.jpg IMG_6556.jpg IMG_6559.jpg IMG_6566.jpg
  27. Stock Racer
    Stock Racer
    Moving on to the left front floor pan. More than half of this pan was solid but I've gone this far so I decided to chop the whole thing out.
    swade41, TFoch, brEad and 9 others like this.
  28. Chucky
    Chucky
    You are doing what I did not want to do to my old ‘63. Go man go!
  29. Stock Racer
    Stock Racer
    I have never done sheet metal fab. When I bought the car I figured the floor would be a fun way to learn something new. I have learned a lot, fun not so much. I was apprehensive at first but I'm gaining confidence and doing better as I go.
    vtx1800, brEad, saltflats and 4 others like this.
  30. Stock Racer
    Stock Racer
    I got the last floor patch roughed out and the contours and bends are way off and the panel is a little short length wise. Of course, the last part of the floor repair is not going to go down without a fight:mad:.
    swade41, TFoch, brEad and 6 others like this.
