  1. PasoJohn
    PasoJohn
    from Edina,Mn.
    1924 Motorhome built on a Ford Model T truck chassis,
    autobilly, 40two, fyrffytr1 and 7 others like this.
  2. PasoJohn
    PasoJohn
    from Edina,Mn.
    THE HOLLYWOOD BOWL 1929
    echo ed, Volksrob, Wreck34 and 7 others like this.
  3. PasoJohn
    PasoJohn
    from Edina,Mn.
    1930 Hinkler Ibis
    echo ed, Volksrob, fyrffytr1 and 7 others like this.
  4. PasoJohn
    PasoJohn
    from Edina,Mn.
  5. PasoJohn
    PasoJohn
    from Edina,Mn.
    BILLY the KID (TOP HAT)
    echo ed, fyrffytr1, jimmy six and 7 others like this.
  6. PasoJohn
    PasoJohn
    from Edina,Mn.
  7. PasoJohn
    PasoJohn
    from Edina,Mn.
  8. PasoJohn
    PasoJohn
    from Edina,Mn.
  9. PasoJohn
    PasoJohn
    from Edina,Mn.
  10. PasoJohn
    PasoJohn
    from Edina,Mn.
  11. noboD
    noboD
    I think it was in Smokey Yunick's book that I read this. At the time that Hudson's were dominating you had to run ALL factory parts. At the end of a race a factory engineer tore down the winner to make sure only factory parts were used. Smokey cast a new cam with factory part numbers in it to make the engine run backwards for more torque off the corners. He won and the factory guy found the part number and certified it as the real deal. MY HERO.
    BigRRR, 40two, fyrffytr1 and 6 others like this.
  12. Sky Six
    Sky Six
    from Arizona
    1957 NHRA Nationals, Oklahoma City
  13. I guess it would go pretty good in reverse
  14. down-the-road
    down-the-road
  15. down-the-road
    down-the-road
  16. down-the-road
    down-the-road
  17. down-the-road
    down-the-road
  18. down-the-road
    down-the-road
  19. down-the-road
    down-the-road
  20. down-the-road
    down-the-road
  21. down-the-road
    down-the-road
  22. down-the-road
    down-the-road
  23. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    hmm. what about the oil pump and distributor? firing pattern no issue but don't the cam gear pull the dizzy down normally. Water pump? fan? And then the trans gears thrust bearing may not like running in reverse.
    not seeing it.
  24. down-the-road
    down-the-road
  25. down-the-road
    down-the-road
  26. down-the-road
    down-the-road
  27. down-the-road
    down-the-road
  28. down-the-road
    down-the-road
    Yawkey-Bissell mill in White Lake, Wis.
  29. down-the-road
    down-the-road
    Turn-of-the-Century Textile Factory
  30. down-the-road
    down-the-road
