Projects Re-engine-ering my 25 model-T coupe
Discussion in 'Traditional Hot Rods' started by Retired, Oct 2, 2024.
  1. tubman
    tubman
    Seems to be that way. And there is absolutely no oil in the ground up here either.o_O
    51504bat and Budget36 like this.
  2. Retired
    Retired
  3. Budget36
    Budget36
    There are manual racks as well. Work just fine, bit more effort, but might be an easier path to take?
    Retired likes this.
  4. Retired
    Retired
    As I said earlier, I have tried to find a manual to replace this power rack but I haven't been able to find one that mounts the same.
  5. Budget36
    Budget36
    Mounts are not difficult. But a “drop in” may not be available.
    Retired likes this.
  6. ekimneirbo
    ekimneirbo
    from Brooks Ky
    First let me compliment you on a nicely done thread......
    If the heads make a 9.7 Comp ratio with a stock bore and stroke, the additional bore and stroke will increase the ratio substantially. Ad to that the domed pistons and I would expect (as you also suspect) that the ratio is just too high for most gases ....especially todays pump gas. I hate to see you give up the extra displacement, especially with a flathead towing a trailer. Have you considered just trying to find some non-domed replacement pistons ? I see you have some machinery in your shop, so probably have some experience modifying things. Are the piston tops thick enough that you might cut some/all of the dome off ? You might be able to tailor the ratio to exactly what you want. :)
    Retired likes this.
  7. ekimneirbo
    ekimneirbo
    from Brooks Ky
    If the power steering is too quick to suit you, you can shim/some pumps to lessen the pressure and make them more better. Here is some info on the Chevy pumps as an example.
    GuyW and Retired like this.
  8. Retired
    Retired
    This was a wild idea on modifying the steering while I had the engine out.
    Thinking more about it I realised that it wouldn't work anyway . Don't know what the heck I was thinking of ... so I went back and removed the post. ....
    Sometimes my brain just runs away and jumps off a cliff. ....
    ekimneirbo likes this.
  9. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Mine just kinda drifts away..........but I know what you mean.:D
    Retired likes this.
  10. Retired
    Retired
    I received the wrong piston rings from Speedway.
    In all the years that I have been doing business with them, this has never happened before.
    I called them and they emailed me a return shipping label right away.
    So I'm waiting for the return to go thru whatever process that takes and for them to send me the correct rings.
