Projects Rear/Mid Engine 1927 T Roadster
Discussion in 'The Hokey Ass Message Board' started by Noah*, Oct 4, 2024.
  1. Hemi Joel
    Hemi Joel
    from Minnesota
    I like the idea! I understand the land speed influence, as the SCTA definition of a "rear engine modified roadster" is: "The driver's seat shall be entirely in front of the engine. The entire engine shall be forward of the centerline of the rear axle. The drivers line of sight shall be over the bodywork. Streamlining ahead of and including the cowl and channeling is permitted"
    What is the judging criteria for the AMBR beyond the obvious requirement of beauty?
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    It's OK , I've got my high boots on :p
    Outback likes this.
  3. Marty Strode
    Marty Strode
    If you are using a side shift trans, buckled directly to the rearend, it will get very tight. Don Waite didn't use a trans, and look where he sits in the car. I did this belly tank 3 years ago, you run out of room in a hurry. Good luck with your project
  4. evintho
    evintho
    Yep.......that's about where you'll sit. Outstanding!
  5. One thing to consider is moving rear axle centre line 2-3 inches back, this was common on Rear Modified roadsters
  6. Beanscoot
    Beanscoot
    Looks like a transmission could be put in there without needing any more length:
    alanp561, Toms Dogs, Tim and 2 others like this.
  7. PotvinV8
    PotvinV8
    I wonder how such an arrangement would actually handle on the street...
  8. CSPIDY
    CSPIDY
    or perhaps bonnet
  9. CSPIDY
    CSPIDY
    Found this on another thread, any pictures of wildwood
    Stogy, Okie Pete and Outback like this.
  10. Marty Strode
    Marty Strode
    rod1, alanp561, flatheadpete and 10 others like this.
  11. The37Kid
    The37Kid
    Just wondering, SCTA rules state that the body must face the original direction as manufactures, does AMBR have the same rule? Some gifted artist here could draw up some concepts with the body swapped 180 degrees.
  12. Noah*
    Noah*
    I've been gathering parts for the past couple months. I did manage to make the parts for the tail panel. The center will be a tail light, the exhaust will p*** through the other 4 openings
  13. It's been done. 26/27 Roadster. Whole car was flipped around except for the drivetrain and suspension. If I remember right it went faster Backwards.
    Unkl Ian and AHotRod like this.
  14. lurker mick
    lurker mick
    Here's a photo. I believe it was outlawed the next year. Not sure it would be a AMBR contender with out a **** load of work.
    Mick
    Just Gary, 1940Willys, Stogy and 10 others like this.
  15. The37Kid
    The37Kid
    What was the turning radius of that car?o_O
  16. So, I am sure you call them tissues and not Kleenex, must you say reciprocating saw not Sawzall, and when you cut yourself, you say self-adhesive bandage and not Band-Aid, as Kleenex, Sawzall, and Band-Aid are all brand names.
    Yes, we know they are technically mid-engine, but when someone says they are building a rear engine car you know what they are talking about.
    1971BB427 likes this.
  17. gimpyshotrods
    gimpyshotrods
    Popularity does not elevate wrong to right.
  18. Jay McDonald
    Jay McDonald
    Better take it up with the SCTA and NHRA, I'm going with their definition. It's traditional.
  19. gimpyshotrods
    gimpyshotrods
    Nah. As an actual Automotive Engineer, now retired, I will stick with the correct term that has been established by the industry that makes it possible for you to be wrong.
    Thor1 likes this.
  20. 1971BB427
    1971BB427
    from Oregon
    Why all this bickering over rear vs. mid engine? I'm pretty sure anyone here with half a brain knew he wasn't hanging that SBC out behind the rear axle.
    I personally would love to just watch this build without all the negative commentary detracting from the project thread.
  21. Robdski
    Robdski
    I 100% agree.
    I too am looking forward to watching this come together.
  22. alchemy
    alchemy
    In today’s society it does.
  23. Anderson
    Anderson
    Y’all shut up.
    how goes the project Noah?
    alanp561, -Brent-, 49Olds and 18 others like this.
  24. Noah*
    Noah*
    Got my colors and fabric picked out and worked on the nose today
  25. Gr8laker
    Gr8laker
    from Michigan
    Not sure if your design is locked in yet, but a v-drive rescued from an old boat might work for reducing the center length of the drivetrain.
    Outback likes this.
  26. Noah*
    Noah*
    This is my torque tube
    tb33anda3rd, -Brent-, Stogy and 21 others like this.
  27. Tim
    Tim
    from KCMO
    Very cool, based on your previous builds this should be pretty dang cool!
    Stogy, Outback and rod1 like this.
  28. gimpyshotrods
    gimpyshotrods
    No bickering. Everyone here enjoys the same freedom and liberty to be as wrong as they want to be.
    It's their right.
    Outback and krazee like this.
  29. hrm2k
    hrm2k
    I have 100 pls pictures from the Carrillo Roadster restoration. The sprint car in / out box barely fit between the flathead and the quick change. I’ll be happy to provide you with any pictures you might want to see. For now, this gives you a good idea of the lack of room
    Outback likes this.
  30. Noah*
    Noah*
    I already know I will have to cut into the cowl some.
    Stogy, Outback, hrm2k and 1 other person like this.
