Hot Rods Big Daddy's 55 2 door wagon gasser
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 1, 2024.
  1. Lloyd's paint & glass
    It's all separate pieces. I said earlier that they were Comp engineering bars, but the crossmember is compe***ion engineering, bars are jegs 32" adjustable, coilover crossmember is Allstar performance, and the coilovers are off shore pieces, I call them "coilrovers" :D:cool::p
  2. Lloyd's paint & glass
    I did this different than my usual ********, I set it all up on the stock rear. Brackets are just tacked to the axle tubes. Now I've just gotta cut the tacks and pull it out, put the other axle in and set pinion angle, weld the brackets. And I took a hole saw to the frame rails, both crossmembers are sticking in the frame 1". Hopefully it works lmao
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I was gonna say. Welding on a rusty surface is a… :eek: :) IMG_3168.png
  4. Lloyd's paint & glass
    Lol top quality work Johnny Gee :cool: no I ground off a spot to tack weld to. I do quality hack work in my shop. ;)
  5. chevy57dude
    chevy57dude
    Man, you're rolling! Will you use a track locator like Swade did or a panhard bar like mine? Woe be to that stock rear if you rev it up and dump the clutch with slicks. Fragmentation will ensue!
  6. Lloyd's paint & glass
    I haven't made my mind up, but the stock rear end will be laying behind the shop for whoever wants it lol... unless it gets hauled off to the s**** place
  7. chevy57dude
    chevy57dude
    Don't junk it till after the fest next year, I might want it.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Just looking out after you. Wouldn’t want @lumpy 63 to see your first burn out looking something like… upload_2024-10-6_7-8-3.gif
  9. lumpy 63
    lumpy 63
  10. Lloyd's paint & glass
    It'll be out behind the shop! You should make plans to hit the reunion with me. Change your gears, haul it here, and convoy to Bowling Green :cool:
  11. Lloyd's paint & glass
    Hey it could still happen!
  12. Hold on! This isn’t fair! You guys are both much, much , faster than I am!! :D:D
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Don’t say that!
  14. chevy57dude
    chevy57dude
    Hey, if someone else gets it first, all good.
  15. Lloyd's paint & glass
    I also have a set of 57 front hubs, few other odds and ends if you want me to sit them back for you. There are 2 S10 rear ends out back, a G body 7.5 that's 58", and some other odds and ends, I don't throw away much lol
  16. Don’t forget about the set of 882’s with the tiny valves. :eek:
  17. Lloyd's paint & glass
    Rear cleaned up, new brakes, might put it in the car tmrw. 20241018_154346.jpg
  18. Budget36
    Budget36
  19. Lloyd's paint & glass
    8.5 10 bolt from a 72 Camaro
  20. TA DAD
    TA DAD
    from NC
    Who cares about the rearend ! I'll take the Malibu.
  21. patsurf
    patsurf
    funny- i was thinking that was the sort of car you wouldn't put money into at a body shop!
    porkshop, primed34 and 427 sleeper like this.
  22. chevy57dude
    chevy57dude
    Hey Lloyd, could you get the drum to drum measurement on both the 55 & Camaro rears?
  23. Budget36
    Budget36
    Good deal, same BP that way.
    VANDENPLAS, porkshop and chevy57dude like this.
  24. TA DAD
    TA DAD
    from NC
    Yeah who would have thought, but today they are desirable. Nice full frame car with a SBC or a BBC .
  25. Steve, I believe the Camaro is 62.5 WMS to WMS. At least this is what the charts said when I was looking for Papaw. The 55, I’m not sure.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    55 Chevs are 60" wms to wms
  27. snoc653
    snoc653
    from Iowa
    Borrowed this from the Camaro net site. [​IMG] .
    The 68 Camaro was 60" just like the 55, which I can confirm as I have one sitting in the shop that won't be going in the 51.
  28. guthriesmith
    guthriesmith
    Yep, I have a 69 Camaro rear going under my sons AD pickup and it is a great fit same as the original in those trucks.
  29. Lloyd's paint & glass
    Stock is 60" wms. 8.5 is 62". Gives me another inch of push out on each side.
  30. Lloyd's paint & glass
