What's up with this site?
Discussion in 'Questions & Suggestions' started by Arizona Geezer, Oct 18, 2006.
  1. Arizona Geezer
    Arizona Geezer
    This week this site is sssssssssssllllllllllllllllllllloooooooooooooowwwwwww. Worse than dialup. Seems to freeze, takes forever to open, etc....none of the other sites are acting that way.........did I miss something?
  2. 3wLarry
    3wLarry
    from Owasso, Ok
    I'm glad you brought it up and not me...this place is slower than a 7 year itch that takes 10 years to scratch...and I ain't on AOL...
  3. Cshabang
    Cshabang
    i don't have any problems...seriously...
  4. I check in several times a day.... no probs yet.
  5. no probs....no really,, it's pretty fast unless it's all pics like the art show then it may take a minute or so!!
  6. Mine's been a little slow last couple days, but is better today.
  7. Ryan
    Ryan
    ADMINISTRATOR
    Odd... I'm having no performance issues at all. In fact, our server load is nil right now... I'll keep monitoring.
  8. JD's 32
    JD's 32
    from TX
    Works good for me.
  9. Nah....you missed nothing....only the fact it dont cost you nothing....stop whineing:rolleyes:
    Monkey
  10. Ryan
    Ryan
    ADMINISTRATOR
    So I just went back and did server load averages over the past two weeks... We never spiked at all and average load times are pretty damn quick. I'm not saying it's not an issue on my side, but I don't have any evidence of such quite yet. I'll keep looking.
  11. Arizona Geezer
    Arizona Geezer
    To give you an example, it just took 6 minutes to get to this point from the start of the thread. I'm not having this problem on any other sites.
  12. Ryan
    Ryan
    ADMINISTRATOR
    6 minutes? I would definately get an alarm if a page was taking that long to load. There could be an issue between you and I... Who is your ISP?
  13. 1 shot
    1 shot
    May be you need to reset your browser.
    I dont know how to do it, but my uncle work's on computer's and says that if you are having a slow time getting stuff to load in it may be your browser setting.........hope that helps.
    It doesn't take long at all for me and im on dial up.
  14. guiseart
    guiseart
    might need to run a adware killer on your PC... when my **** starts loading slow, that's usually the culprit
  15. Arizona Geezer
    Arizona Geezer
    Well, I came back to check here at 404PM. That's when i clicked on the HAMB site. It's 412PM as I type this. I've been to several other sites in the meantime, and had no problems........they are working like the HAMB was last week on this computer. I'm not very computer literate, but this is strange.
  16. zap73
    zap73
    from Nebraska
    I have high speed and its fine until i log in , then it slows way down.
  17. cadlights
    cadlights
    from Hooper, Ut
    I cruise in in 2nd gear then hit a couple stop signs ( long enough for a smoke and a couple beers ) Then it kicks me in neutral when I try to read a PM or send a PM and kicks me right out with an ERROR 504 GATEWAY TIMEOUT!What's with that?
  18. Ryan
    Ryan
    ADMINISTRATOR
    That's an AOL error and has nothing to do with the HAMB. Read this post:
    http://www.jalopyjournal.com/forum/showthread.php?t=134253
  19. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    1. If you are using AOL that IS a problem. ARE YOU USING AOL ?
    2. Spyware- Adware hijacking your system.
    3. **** - clean out the history if you have any.
    4. Web history - tempory-clean it out.
    90% chance one or ALL of the above.
  20. cadlights
    cadlights
    from Hooper, Ut
    Thank yewwww!!!! I knew it couldn't be the fault of the HAMB.I'm gonna put er back in second gear and floor it, drive right around AOL and keep on going.
  21. Arizona Geezer
    Arizona Geezer
    Well, that answers it! Good bye AOL..........I'll let you know when I'm set back up.
  22. Ryan
    Ryan
    ADMINISTRATOR
    There really is no excuse to run AOL. There are cheaper and much better options out there.... If anyone needs help finding those options, just let me know.
  23. FiddyFour
    FiddyFour
    another thing to check once in a while if you get really slow *** load times if you browse a lot of pics on the HAMB is to clear your cache more often... that dumps all the stuff your browser stores "so that pages often visited load faster" . . . yea right, if they loaded fast, i wouldnt need to dump the cache :D
  24. teach'm
    teach'm
    from Tucson, AZ
    Maybe it's a Southen Arizona speed issue? The HAMB has been choppy and slow on my computer for at least a week now, while other sites load as normal. I have hi-speed cable internet, use Netscape 7.2, and clear my cache and cookies daily, so mine is not an AOL issue? It is slow to the point that the I can see everything loading separately, first text, then graphics, and finally the avitars. Any help would be great.
    Thanks.
  25. Ryan
    Ryan
    ADMINISTRATOR
    Hey teach.... would you be willing to try a test of sorts? Can you install Internet Explorer or Firefox and see if the performance of the HAMB improves at all for you?
  26. cadlights
    cadlights
    from Hooper, Ut
    WOW!!!!!!:eek: I emptied the cache and cookies, downloaded internet explorer 7 and changed the adapter and it shot me right down. I couldn't even log in:mad: . So, I put er in the garage for the night and when I fired it up this morning it was like someboby put a blower on the HEMI. I can hardely keep up with it. I have no idea what happened but I'm not complaining. :)
  27. Ryan
    Ryan
    ADMINISTRATOR
  28. teach'm
    teach'm
    from Tucson, AZ
    I'll be a good soldier and give Firefox a test drive.
    update: Although the initial page load is a little choppy, switching back and forth between threads and the main message board seems to be quicker than it was on Netscape.
    Ryan (the way less famous one)
  29. husker
    husker
  30. last g-man
    last g-man
    Firefox made a large speed diff in my system ....
