Projects Tucks 29 Roadster Build ---->
Discussion in 'Traditional Hot Rods' started by Tuck, Aug 26, 2013.
  1. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    BC523C1C-626F-4DF8-ABA1-643548D27F76.jpeg C7E29A2F-2DC2-432F-B93B-38DB3C40FE58.jpeg
    I’m on it hope ya all are in the garage.
    -1” section from cowl plus the 1.5” lip from before, I f’n LOVE it.
    fixed the stanchion risers too
    Magneto Dimple for the firewall
    more to come
    022A6B16-9504-4C37-85A5-921259A1459E.jpeg 84341CF4-B4AB-43A2-9833-35E278CB1C24.jpeg 7433EA3C-38B5-4FD2-90A9-8EE1B00A63BF.jpeg IMG_1724.jpeg
    enloe, rod1, Shadow Creek and 13 others like this.
  2. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Moved the dimple up because the body sits at a slight angle and it’ll help clear the cap. the new firewall is 1/2” plywood that’ll be laminated with 1/4” aluminum plate which I’ll be able to block sand and polish and it won’t be so fragile.
  3. BigJoeArt
    BigJoeArt
    looks awesome!
    gonna weld the dimple in?
    Tuck likes this.
  4. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    I have a plan I’m hoping works out…I’m going to cut the hole out and the router the opening with a radius and mount the dimple to the back side so I can keep the aluminum flat and polish it like a mirror.
    Okie Pete, 31chevymike, brEad and 4 others like this.
  5. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    a couple updates-
    IMG_2037.jpeg IMG_2064.jpeg A470E19F-BD50-4E27-8C78-FF3554DA8B5D.jpeg IMG_2073.jpeg IMG_2062.jpeg I got the cowl lip welded back in and it's permanent! I love the bobbed cowl so much-
    I sectioned the top lip that rises about 3/4 to an inch above the cowl to where it's almost flat and the chopped windshield frame sits right on top of the cowl, looks so much cleaner.
    IronFord, rod1, Stogy and 13 others like this.
  6. Great work on your cowl mods Tuck! Better to see you're back on your roadster too!
    rod1, Stogy and Tuck like this.
  7. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Thanks Mike, excited to get this cowl and firewall finished up.
    I started to trim up my 40 dash too.
    Just Gary, rod1, Stogy and 5 others like this.
  8. Outback
    Outback
    from NE Vic, Oz
    rod1, Stogy, 31chevymike and 2 others like this.
  9. general gow
    general gow
    MODERATOR
    good talk last night. progress pics are awesome. stoked for you.
    Roothawg, rod1, Stogy and 2 others like this.
  10. silent rick
    silent rick
  11. Roothawg
    Roothawg
    Yeah, what he said ^^^^***
    31chevymike likes this.
