Hot Rods Headlight relays.....why?
Discussion in 'The Hokey Ass Message Board' started by hemimike, Oct 5, 2024.
  1. 05snopro440
    05snopro440
    When I wired my 46, I used relays and circuit breakers in the headlight circuit. Everything works great.
    One thing to think of is where you want the likely failure point to be. If you use a relay, it's less likely to be the headlight switch. An in-cab electrical fire is a lot more dangerous as far as getting the vehicle stopped and getting out without injury than an under-hood electrical fire.
