What OT crap are you working on
Discussion in 'Off Topic Hot Rods & Customs' started by anthony myrick, May 9, 2024.
  1. Modified the bump stop mount
    This should yield a 5 1/2 to 6 inch cruising bumper height
    6 lug rotors just got here so now we can test for the 22s
  2. 6sally6
    6sally6
    Saw/heard a Ford Econoline van at Cruis'in the Coast a few years back with a real snot-sling'in-balls dragg'in-AA/Fueler sounding MOW-DER in that puppy !!
    I'm not sure how well it ran but...when it was idling along, the back tires would bark in time with the blower surge !!!
    Talk about a sleeper.
    That faded light blue that millions of Eco's wore...narrowed rearend to hide the BIG meats..and tinted windows and that was it.
    One of "the crazies" fer sure that make going to the event worth it all.
    6sally6
  3. bobss396
    bobss396
    The Belair had a pull to the left, went under and worked the driver side strut rod, now it is world's better.
    Okie Pete, 29A-V8, SS327 and 4 others like this.
  4. Stooge
    Stooge
    Got the 396 back from the machine shop the other day to go back into my good deed for the year project. 1969 chevelle ss that belonged to a friend of mine's late father, has been stored in the garage for a few decades with a broken lifter and wiped out cam, and im getting it back up and going for her and freshening things up
  5. Sandcrab
    Sandcrab
    Picked up a dash last year for a wall hanging that turns out to be a '32 Chevy that fits perfect with a little modification.
  6. HOTRODPOWELL
    HOTRODPOWELL
    Camaro bird ch***is is coming together A9504956-CA72-4C24-B57C-7069AAE09742.jpeg D3B8D7A2-A410-46F1-80DC-B6D039166AB4.jpeg 08DA3A97-DC28-4944-9118-D3EC38AD67D4.jpeg
  7. Lloyd's paint & glass
  8. 67drake
    67drake
    from Muscoda WI
    image000001.jpeg The F550 bucket truck at work. Went to grease the upper ball joints-sigh WHY!
    I figured out if I rotated the wheel “just right “ I can fit the grease gun between the yoke and U-joint, just barely makes the angle.
    A 90 degree zerk would have been nice.
    bobss396, Okie Pete, 29A-V8 and 3 others like this.
  9. TrailerTrashToo
    TrailerTrashToo
    29A-V8 and 67drake like this.
  10. bobss396
    bobss396
    No pictures but we aligned the Belair yesterday morning. Used Snap On portable tables, etc. Now it drives a lot better.
    Also did the headlight alignment. I had installed all new adjusters and springs which made it a quick job.
  11. HOTRODPOWELL
    HOTRODPOWELL
    This Kid makes me so mad DFB4E178-CB52-4CB4-B20A-AB1461129C7E.jpeg D32C4D37-0642-4DD2-A08B-48B92027A2C4.jpeg
    He can weld with either hand after 30 years I still can’t do that
    Sharpone, porkshop, Okie Pete and 6 others like this.
  12. onetrickpony
    onetrickpony
    from Texas
    Painted my bed today.
  13. Bandit Billy
    Bandit Billy
    Tailgate I did epoxy primer, yes. - Yota
  14. 29A-V8
    29A-V8
    from wyoming
    Helped an 82 year old friend of my wife's, social security is her only income. Upper and lower ball joints on her 2007 Chrysler Aspen ready to fall out. Local rip off garage said 800 labor + parts. Figured I could do it a little more reasonable for her. Talked to my buddy at another shop, told the story, I bought the lower ball joints, they pressed the lowers out and in on the house. Replaced the uppers with new arms, and sway bar bushings had to buy a new battery too. Came in a little over 500 bucks.
    Was in my shop for 10 or 12 days, got it tore down and got sick, that took a while cause Im a couple decades past 50 something, Ive had worse though. Had to wait on parts anyway. Torsion bar suspension looked like it been parked in a crick for a couple of years, thought I bit off more that I could chew, had to get a bigger and bigger hammer, but you know what they say. Perseverance or some ****. Anyway I won.
    First of the month the wife hands me a hundred dollar bill first installment she said. I figure good enough if I dont see anymore at least god gave me the ability to help someone who needs it.
  15. Okie Pete
    Okie Pete
    IMG_0137.jpeg IMG_0176.jpeg IMG_0188.jpeg IMG_0189.jpeg W900A 1966 the drivers window wouldn’t roll down . Took it apart and found the ears on the crank shaft were broken off . Welded them back on and it works good as new . There are new replacements but after picking one up there are differences . There 3/8” thick spacers where it bolts on to the door . The shaft the handle bolts on is 3/4” longer than the old one . So I repaired the old one .
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    Going through the carbs on my crosley powered chopper trike
  17. Moriarity
    Moriarity
    SUPER MODERATOR
  18. chevy57dude
    chevy57dude
    Running like a champ, Mark. Hope you went for a ride.
    Moriarity and Sharpone like this.
  19. Sharpone
    Sharpone
    Good on you, acts of kindness - Bravo!
    Dan
    Okie Pete and chevy57dude like this.
  20. 29A-V8
    29A-V8
    from wyoming
    Thank you.
    Sharpone and Deuces like this.
  21. Stooge
    Stooge
    Plugging away on the Chevelle SS that im doing for a friend, that belonged to her late dad, and at my normal lumbering break neck speed :rolleyes:, but making progress. Its alot of going through and fixing/ replacing either stuff that has fallen apart in the 20+yrs its been sitting or the stuff that was maybe mickey moused/ half ***ed decades ago. Should be ready to fire up this weekend. (it is a girl's car now and ive lost a few compromises, so pictures were taken before the bright pink spark plug wires were put in :()
    Squablow, Sharpone, 29A-V8 and 11 others like this.
  22. JohnLewis
    JohnLewis
    Brothers Camaro blew a brake line, been redoing those. While he ended up trading it for dad’s nova, so got both those in the garage while mine got moved to the side. As I slowly sand away on it. IMG_0112.jpeg IMG_0113.jpeg IMG_0114.jpeg
    Squablow, Sharpone, 29A-V8 and 9 others like this.
  23. Good updates, guys. :)
    JohnLewis likes this.
  24. deathrowdave
    deathrowdave
    from NKy
    If I lived near , I’d be helpin you tinker . Love seeing how old stuff was built and works
    Sharpone and Okie Pete like this.
  25. Sandcrab
    Sandcrab
    I didn't like the pedal on the speedway throttle so I made a half scale "Moon" pedal and cast a couple.
    Squablow, wfo guy, Papas32 and 10 others like this.
  26. Okie Pete
    Okie Pete
    IMG_0309.jpeg A ugly I’m working on
    68Dodge, 1pickup, Oneball and 6 others like this.
