Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. D-Russ
    D-Russ
    XO and **O.
  2. So it’s all X’s and O’s then? Hehe.
    D-Russ likes this.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I have found that with anything more than seven degrees of caster one is likely to encounter death wobble on a decell.
    D-Russ and chryslerfan55 like this.
  4. jimmy six
    jimmy six
    It's not a 200 mph vehicle, 6 will be fine.
    D-Russ likes this.
  5. john mullen
    john mullen
    I got the oil pan back from powder coat today, It looks really good.
    I also finished up making bushings for the lifter bore holes to install mushroom style lifters with a 1"pad.
    And we added a steering shock dampener in hopes to cure the front end problems we have been chasing. 20241009_164906.jpg 20241009_164858.jpg 20241009_164841.jpg 20240930_143445.jpg 20240930_143439.jpg 20240930_143415.jpg 20241008_134527.jpg
  6. Y-Block lifters?
    sidevalve8ba and chryslerfan55 like this.
  7. john mullen
    john mullen
    Tested the truck again today and the death wobble is no more. Oh yeaah!!
  8. john mullen
    john mullen
    Yes.
  9. Outstanding work on the oil pan.
    Dyno Dave and chryslerfan55 like this.
  10. john mullen
    john mullen
    Thanks
  11. john mullen
    john mullen
    Installed all the lifter bore adapters to fit mushroom style lifters from Trend Performance products 20241031_191121.jpg
  12. john mullen
    john mullen
    Next is the crank install with a piston and rod to check piston to valve clearance. Just waiting on the head back from Jimmy's Engine Service.
    Once this is done we will deck the block for maximum compression ratio.
    Looking for around 15 to 1
  13. john mullen
    john mullen
    We are now ready to check valve to piston clearance
    I'll pick up the Skinner head from Jimmy's Engine Service on friday 20241106_165931.jpg 20241106_165923.jpg
  14. Hotwyr
    Hotwyr
    Just curious as to how you handeled the line bore. Since you're using billet main bearing caps, i ***ume you converted the main bearings to all the same diameter.
  15. D-Russ
    D-Russ
    Nope, they're still staggered sizes. Our engine machine guy has an extremely skilled "retired" guy he calls on for "special" projects. He set us up.
    EDIT: @jimmy six , this is the block you gave us. Thank you!
  16. Just Gary
    Just Gary
    We need details. Where? How fast?;)
  17. D-Russ
    D-Russ
    We test on the taxi way at a private airport in West Point. It's probably a little less than a mile long. I took her up to 70 one way and 90 on the return.
  18. sidevalve8ba
    sidevalve8ba
    Was it the caster setting you changed to correct that?
  19. D-Russ
    D-Russ
    We changed a lot of stuff - less caster, new drag link set up that has no play and is parallel with the ground and hairpins, rebuilt steering box, toe-in adjustment, and added a steering stabilizer. We still may swap out the tie rod drop blocks with dropped tie rod ends.
  20. john mullen
    john mullen
    Top side photos of the lifter bore bushings to allow the use of mushroom style lifters 20241107_164139.jpg 20241107_164134.jpg
  21. saltflats
    saltflats
    from Missouri
    Is that piston at TDC?
  22. jimmy six
    jimmy six
    I’m guessing yes… there is no chamber with a Skinner, Wayne or Horning 12 port head. You control compression with rod length and pin height when you have your pistons or rods made. If you don’t mind the expense you can have difference thicknesses in copper head gaskets made.
    I believe most use 7cc for valve heads above the surface of the head. I still do castings with resin before I order gaskets to get the compression I want. I have never had valve overlap be a concern. Some builders have also made a chamber in the top of the piston but the spark plug location directs its construction. I personally like as flat a piston as possible.
    Great work I enjoy following . . . Thanks John.
  23. D-Russ
    D-Russ
    Yes, but the block has not been decked yet. As JD @jimmy six said above the Skinner head doesn't have combustion chambers. We are awaiting additional camshaft profile information before making a decision on how much the block will be decked to put the compression ratio exactly where we want it.
  24. john mullen
    john mullen
    Almost ready for valve to piston check just need pushrods. Also taking a look at valve event timing.
    Sorry no data on the cam at this time, maybe later. 20241108_130748.jpg 20241108_130745.jpg
  25. jimmy six
    jimmy six
    I think you will find ample clearance with any cam on overlap. Once it’s all in test fit it will be great to know your true rocker ratio. All advertised have been BS I’ve found. I’ve always tested with lash caps, made adjustable push rods, and used different keepers on the spring retainers not only for proper pressure but to get the correct geometry on the rocker…. Even though I’ve done that since the 70’s, being retired gives me time to do all that in day light…:)
  26. seb fontana
    seb fontana
    from ct
    Quench area?
    saltflats likes this.
  27. john mullen
    john mullen
    Skinner head has no quinch area
    Just Gary likes this.
  28. seb fontana
    seb fontana
    from ct
    So pistons must have a dome of some sort? Can't see in pictures.
  29. jimmy six
    jimmy six
    seb, most are just flat… if you think about it there is no shrouding of a valve this way. There have been pistons designed and used to have a “chamber” cut in and on the opposite side of the spark plug go up to the head but that is shrouding and many engineers have thoughts about it.
    Think about the SBC and the different degree heads to achieve high compression with flat top lighter pistons.
    Remember these were designed originally right after the war and 2 of the styles did have a chamber. The Horning, round, and the Algon, wedge. There are very few Algons and the Horning’s intake ports were not optimal at best.
  30. john mullen
    john mullen
