Projects Nate’s 32 roadster build
Discussion in 'Traditional Hot Rods' started by heyitsnate, Nov 17, 2020.
  1. RodStRace
    RodStRace
    Amazing detail and craftsmanship! All in the pursuit of the perfect form.
    heyitsnate likes this.
  2. Malcolm
    Malcolm
    from Nebraska
    Man, that top is a work of art.
    42merc and heyitsnate like this.
  3. Krash
    Krash
    from Cleveland
    Looks great! What did you use for that rear window?
  4. heyitsnate
    heyitsnate
    It’s from Sid Chavers .
  5. dirt car
    dirt car
    from nebraska
    Nice ! so many times builders tend to miss the mark with a poorly designed or fitting top, this one is spot on !
  6. hotcoupe
    hotcoupe
    Like everything else on the car, the top looks terrific!
    Tom
  7. Duke
    Duke
    Wow, that really turned out well! Best top ever!
    Outback and heyitsnate like this.
  8. hotrodA
    hotrodA
    I was wrong.
    I thought it couldn’t get any better after the interior. Wrong!
    Then the hood and fenders showed up.
    And now You and Rex made a new standard for roadster tops.
    And now…..it’s PERFECT
    brEad, heyitsnate and Outback like this.
  9. Dak Rat
    Dak Rat
    from NoDak
    Would you show the brackets you built to allow the '32 chevy hood latch to operate. Thanks so much for the build thread!
  10. Jaber
    Jaber
    Really loved it. Great taste man, specially that dash!!! Congrats
  11. heyitsnate
    heyitsnate
    you can kinda see em. I put my phone flashlight on the engine facing down and used the holes in the side to reach through and set them up . The front ones bolt to the crossmember with 10/24 screws. I tapped the crossmember. The rear ones I bent up from sheet metal
    Tim, Shadow Creek, brEad and 8 others like this.
  12. Dak Rat
    Dak Rat
    from NoDak
    Great, thank you. Simple and effective.
  13. oliver westlund
    oliver westlund
    Very cool build!
  14. brEad
    brEad
    Top and hood both turned out amazing!
  15. Paul
    Paul
    Editor
    so nice
  16. heyitsnate
    heyitsnate
    IMG_1351.jpeg 7DABE4DB-F217-4969-B323-8DC592CFE3DC.jpeg IMG_4681.jpeg IMG_0613.jpeg IMG_0612.jpeg This next bit I made once, and didn’t come out perfect so I started over from scratch. I’ll just post the one . Imagine me doing all that before though haha. I love the old prewar cars Kurtis and Duvall did with the skirted front fenders so that’s what I’m setting out to do
    rob-redm likes this.
  17. heyitsnate
    heyitsnate
    As you can see above I made a model and Jason killlpack made one too a long time ago. Now we get into the real work . Pretty straightforward. These are the first ones and some wire edge tests also. I had the dies but no roller so circle city hot rods put the bead in for me after I wire edged it. The next series is me . I didn’t get the template right so I ended up redoing everything . IMG_4925.jpeg IMG_4928.jpeg IMG_4935.jpeg IMG_4937.jpeg IMG_4952.jpeg IMG_5007.jpeg IMG_5009.jpeg
  18. heyitsnate
    heyitsnate
  19. heyitsnate
    heyitsnate
    And now you’re all up to date. The next thing is t******* shaping and welding these in , then things are coming apart for paint . At that point the engine is getting replaced. This one is ok but it smokes and leaks a lot.
    brEad, Outback, wandi harry and 2 others like this.
  20. 57tailgater
    57tailgater
    from Georgia
    This has been a great thread to follow. Interesting idea on the fender skirting. Reminds me of a '35 International pickup front fender.
  21. Just checking in on the progress. As always looks killer. See you at GNRS
  22. 31Apickup
    31Apickup
    I like where this is going, will look great!
  23. Outback
    Outback
    from NE Vic
    When I first saw this photo, I thought wow that's it! That's the pinnacle.
    Then I saw this & I couldn't imagine that it could look any better, but now you've shown us the skirted front fenders the stock ones look plain & as if something is missing. Well done, I wish I could get to see this car in person.
    I'm looking forward to seeing it come together. :cool:
  24. patsurf
    patsurf
  25. heyitsnate
    heyitsnate
    thanks!
    I hammered the edge on a wood form, then you kinda clamp the wire with vice grips as you go through and hammer it over. If your bend height is 5/16” it covers a 1/8” wire nicely . Then there’s a die with a gap for the wire and you just bead roll that ****er.
    brEad and loudbang like this.
  26. heyitsnate
    heyitsnate
    Thank you! I was worried it would look weird or it wouldn’t come out as cool as I thought it could
    Outback likes this.
  27. alchemy
    alchemy
    Have you seen English 33-34 Fords?
  28. patsurf
    patsurf
    nothing to it....!
  29. heyitsnate
    heyitsnate
    No. I did see somewhere a totally stock set of 32 skirted fenders. I think ford made some but no idea why or where
    RICH B and Outback like this.
  30. justabeater37
    justabeater37
    I have been toying with the same intrusive thoughts since I saw this rendering and the European skirted front fenders.
    Outback, brEad, hfh and 4 others like this.
