  1. EV34
    EV34
    Awesome! I will have to plan this out for down the road.
  2. Hank37
    Hank37
    Change color of hood and body to red . 459711149_887926233258570_323078470195982934_n.jpg
  3. James D
    James D
    And what do we say....?
    Dick Stevens, Ned Ludd and ClayMart like this.
  4. Unclebrad
    Unclebrad
    With the black rims - no trim rings...
  5. themoose
    themoose
    Hank37 and Unclebrad like this.
  6. Unclebrad
    Unclebrad
    And... your original request - whitewalls only. F079C6A9-9F00-4572-85AB-3AEE07DDEE26 d.jpg
  7. Hank37
    Hank37
    themoose likes this.
  8. EV34
    EV34
    uncle Brad that looks great.
    I guess I wasn’t exactly clear on what I was looking for. I want to keep the black walls and paint the wheels is what I was after. Is that something you could do?
    thanks again for the great work!
  9. Unclebrad
    Unclebrad
    Ah. Yes.
    Here is with the trim rings. Without them coming soon. F079C6A9-9F00-4572-85AB-3AEE07DDEE26 e.jpg
  10. Unclebrad
    Unclebrad
  11. EV34
    EV34
  12. snoc653
    snoc653
    from Iowa
    UncleBrad I have been planning my build with this image as my ultimate goal for looks. The engine has gained a 871 and 2 850s so it is unclear how far it will stick out of the hood. That will ultimately have to wait to verify the way it will look. If you have time, would you be able to modify the rear wheel wells? I have had to change rear ends and instead of staying inside the wheel wells, it looks like I'll be running 30 inch tires. Travlr has shared a couple pictures of his Chevy with radiused wheel wells and 30 inch tires. With the extra HP, I think I will need to use more tire to hook my car up. 30 inch tires will hopefully get the job done. If you could, could you modify the image to have radiused rear wheel wells and the 30 inch tires. I still want the down in front stance and hopefully the same wheels you posted but if cutting and pasting his is easier it will still give me the effect. Here are the pictures Travlr shared: [​IMG]
    Thanks,
    Glenn
  13. Stan Back
    Stan Back
    Na-na-na. This one's best! Even better if the filler cap guard goes away.
    (I guess it's not mine -- but it sure is purdy.)
    whtbaron, skooch, jimmy six and 3 others like this.
  14. Unclebrad
    Unclebrad
    Hi Glenn, Happy to give it a shot. Could you re-post the pictures from Travlr? I can't seem to retrieve them. Thanks. Brad
  15. snoc653
    snoc653
    from Iowa
    [​IMG][​IMG]
    Here they are again. Hopefully they will work for you. If not, I can download them and PM them to you.
  16. Unclebrad
    Unclebrad
    I'm afraid that I still can't get them.
  17. Unclebrad
    Unclebrad
    snoc653 likes this.
  18. snoc653
    snoc653
    from Iowa
  19. jnaki
    jnaki
    Hello,
    I am doing a project for my brother's two sons. Would someone please make the large black 1951 Oldsmobile two door sedan as low as the 51 Olds sedan with the Moon Discs? But, make the whole black car the Pale Yellow from the other photo? Now, include whitewalls and Moon Discs all around.
    The original Oldsmobile was painted a Pale Yellow from the factory and the first thing we did, was to put on some screw in Moon Discs. We lowered the whole car, raised up the back, so it was on a mild rake. He drove it around for a couple of years and had it painted a Lime Green and sold it to a friend. At one time, it was so low on the rake that we had to take off the "under the door, lakes pipes" as they hit the ground when going over the neighborhood road dips. So, no pipes in the pale yellow version.
    Jnaki
    We have no photos or film of the 51 Oldsmobile sedan as in the Pale Yellow version. So, would someone with time, please convert the top, all black OLDS photo to the lowered rake, whitewall/Moon disc version, without the rear skirts?
    Different artists versions are appreciated in this project.
    Thank you. I would like to get the finished product, so I can give it to them on our next road trip to Santa Barbara.
    It is a long time project I have tried many times to put together, but never finished it. Much appreciated.
  20. themoose
    themoose
    @jnaki
    Not a real good image to work with but this should give you some idea...
    Unclebrad, 51504bat and jnaki like this.
  21. jnaki
    jnaki
    Hey M,
    Thank you for the great yellow version of my brother's first 51 Oldsmobile. Now, would it be possible to make a Pale Yellow version of the above photo? That would be great.
    Jnaki
    We do not have any photos that are with the Yellow original paint. Thanks.
  22. themoose
    themoose
  23. Stan Back
    Stan Back
    Nothing says phony like snap-on Moon discs.
    Sorta like putting a number on the door with an impossible cl*** designation.
    This ain't a race car.
    51504bat likes this.
  24. mbstude
    mbstude
    Is someone willing to throw a set of 2.5" wide whites on this Lark for me?
    Or a readily available aftermarket wheel that you think looks good. I'm open to ideas.
    Thank you...
    Apenaut and rusty1 like this.
  25. themoose
    themoose
  26. mbstude
    mbstude
    I've considered those and.... yea. Way better than wide whites. Thank you sir.
  27. jnaki
    jnaki
    Hello,
    Nice 5 spoke additions. I was drawing a Lark custom for a later Friday Art project and it was similar to the custom features. 5 spokes make any car look great.
    Using the beige Lark, my drawing was lower in front along with the 5 spokes.
    Jnaki
    It sure needs a chop, but then, it might look like a Volvo Bertone model... YRMV
  28. themoose
    themoose
    Just a minor chop would look pretty good....
    Apenaut, whtbaron, Unclebrad and 2 others like this.
  29. Phil P
    Phil P
    Good morning everyone
    I've been contemplating doing a 2" chop and do to my limited skills and paint availability I would paint everything black above the body. Can someone please show me this. IMG_1703-1.jpg
    Thanks Phil
