Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. chevyfordman
    chevyfordman
    I got to save a rear main cap by installing a helicoil on a 327. Someone used too short a bolt and broke out some of the cap. IMG_2573.jpeg
  2. Student asked “why are we taking apart an engine that ran so good”
    10 minutes later:
    thrust bearing has some wear but not as bad as I thought it would look if the crank had moved far enough
    Timing gear is not touching the block. I’m thinking the dampener was hammered on to much
  3. Sharpone
    Sharpone
    Is that one of those it was running when parked deals ? Lol
    Dan
    chryslerfan55 and anthony myrick like this.
  4. Cheap trade for the engine .
    I’m still happy with it. Ive got another cover Just more curious for the cause. The hole wasn’t there until I pushed thru it
    chryslerfan55 and Sharpone like this.
  5. I’m going with this as the issue
  6. lumpy 63
    lumpy 63
    What does the crank thrust look like?
  7. lumpy 63
    lumpy 63
    I had a new 292 dampner at the shop...I'll look for it tomorrow.
  8. Looks like a normal bearing.
  9. saltflats
    saltflats
    from Missouri
    My luck was always the crank took all the wear.
  10. lumpy 63
    lumpy 63
    I took apart a 400 sbc recently , the bearing looked pretty good...crank thrust surface not so mucho_O
  11. lumpy 63
    lumpy 63
    20241011_111429.jpg Tore down the 461 Pontiac today.
  12. saltflats
    saltflats
    from Missouri
    Looks like someone threw some money at that Pontiac. I'm sorry to say my Pontiac will end up with a Chevy engine.
  13. lumpy 63
    lumpy 63
    The previous owner let it ingest something that didn't agree with it. I bought one new Ross piston with the same part# but they changed the design... Gunna order a full set on Monday:(
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Make Ross eat the other 7 for the inconvenience. :)
  15. saltflats
    saltflats
    from Missouri
    I have a 409 that needs one piston or a set of 8 that are the same, don't want to change the recipe if you know what I mean. ;)
  16. IMG_8304.jpeg IMG_8305.jpeg I didn’t have much time yesterday to work on Papaw, but I drained the TH-350. My plan was to change the filter, front and rear seals, and run it. The fluid on the dipstick was nice and red, I can’t smell anything since Covid, so I couldn’t go by smell. I removed the pan and found most of the friction material from the clutches laying in the pan. Shit. It’s been 30 years since I attempted to rebuild an automatic and then it was a crap shoot if I wound up with a transmission full of neutrals. The last bench job for a 350 around here was $7-800, that was for my nephew’s buddy’s Square Body. I guess I’ll start shopping for transmission kits. I think we have an account with Transtar at work. Automatic transmissions were the only subject in Tech School I struggled with, but that could have been because of the train wreck with the killer body I was dating at the time. :eek: There can’t be that much Black Magic inside a Turbo 350.
  17. Those " killer body's " have caused a LOT of train wrecks!!
    Ben
  18. You ain’t said Shit there!!!
    Sharpone and 427 sleeper like this.
  19. lumpy 63
    lumpy 63
    Hey Andy, Years ago my kid and I rebuilt one we put in his V8 vega. I bought a DVD and we would watch it , pause it , run to the garage and work on it , go back watch some more....It was comical :D The trans worked fine even with a 125 shot.
    rod1, Sharpone, chryslerfan55 and 9 others like this.
  20. Lloyd's paint & glass
    Blah blah blah... stand back gentleman, I built a 454, it's the lightweight version, low compression, but none the less, I did good :D 20241011_115832.jpg 20241011_115843.jpg
  21. Dick Stevens
    Dick Stevens
  22. patsurf
    patsurf
    well-now just cut the firewall and set the rat back 10% and....
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That belongs on O’Reilly’s floor as a demo. :)
  24. Obviously built to rev, running loose clearences.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
  26. saltflats
    saltflats
    from Missouri
    Get a trans go shift kit for it.
  27. Your version probably weighs less than a Small Block!
  28. atch
    atch
    Absolutely proof positive that "all that glitters is not gold"...
  29. So very true!!
    Sharpone likes this.
  30. lumpy 63
    lumpy 63
    20241011_114119.jpg 20241011_114112.jpg Let's play a game... it's called what did the Poncho eat? It's a very distinct imprint , I don't recall seeing anything similar, no thread marks or nut looking imprints.
