Technical 350 chev mechanical pump issues
Discussion in 'The Hokey Ass Message Board' started by Harleyv89, Oct 13, 2024.
  1. Harleyv89
    Harleyv89
    Hey legends,
    i am having issues with my mechanical pump leaking on my 350 chev.
    I have gone through 2 in in the space of 2 months, first one leaked bad (took all the paint off my inner gaurd), Thought it may have been faulty so replaced it with another brand and it has started leaking aswell but with oil coming through aswell.
    What could cause this to happen twice? Could it be an installation issue? Or just **** luck?
    Its in my 1963 chevrolet impala motor has abit of work done, bigger cam etc.
    Thanks legends!
  2. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Two things come to mind .
    First and saddest is junk production.
    Second hopefully is insufficient hardware.
    If housings vary, and are not uniform thicknaess, oil leaks will occur.
    Internal ( fuel ) leak is bad material and should be returned to Mfg, for compensation.
    Something I have found to be true, for me, is that if I don't keep the receipt, the piece will be no good.
    X-cpe, Unkl Ian, vtx1800 and 3 others like this.
  3. 34Phil
    34Phil
    Do you have the spacer plate under the pump?
    lothiandon1940 and Tow Truck Tom like this.
  4. Harleyv89
    Harleyv89
    The mechanical pump is mounted on the side but no there is nonspacer between the block and pump. Whys that ?
  5. lothiandon1940
    lothiandon1940
    Is it chrome?
    Unkl Ian likes this.
  6. Harleyv89
    Harleyv89
    No
    lothiandon1940 likes this.
  7. TA DAD
    TA DAD
    from NC
    This is the spacer 34Phil referred to. [​IMG]
  8. 19Eddy30
    19Eddy30
    from VA
    Oil or gas leaking ?, If gas, bad diaphragm, they site on shelf for so long & rubber junk , dry rot now adays , buy Name brand $50 plus , & ethanol resistant
    ( for insurance)
    This is what otheres are calling spacer ,
    Not a spacer, its a part , plate to install & seal fuel pump rod & lube pump ,oil from lifter / cam back to oil pan block on sbc IMG_2396.png
    Deuces and Lone Star Mopar like this.
  9. chevyfordman
    chevyfordman
    I've heard that story about leaking new pumps from guys around here too.
  10. BJR
    BJR
    The 55 to 57 T-Bird crowd says to rebuilt original factory pumps. The new ones available all last about a week if you are lucky. All offshore junk. I don't know if the originals for your car were bolted or crimped together, so this may not apply to your pump.
  11. jimmy six
    jimmy six
    They are correct. And rebuilders will not touch an off shore pump to rebuild because as much as the look alike parts don’t interchange.
  12. I wonder if a more expensive pump such as a Holley would be any better than a parts store special? I’m interested in this as I will be buying a new pump before long.
  13. 2OLD2FAST
    2OLD2FAST
    from illinois
    That's a block off plate not a spacer .
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Block off plates “do not” have the oval hole for pump arm to p*** thru. IMG_3196.jpeg
  15. 19Eddy30
    19Eddy30
    from VA
    maybe Gm calls it ablock off ,
    But most consider pic below
    Block off plates .
  16. Mike VV
    Mike VV
    from SoCal
    Yeah, crystal ball time...again !
    You don't mention WHERE...the pump is leaking from !! OR, what it's leaking...gas OR oil !?
    Four different places come to mind, right off !
    Mike
    05snopro440 likes this.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    I've not had problems with fuel pumps but most of the box stores ( AutoZone , O'Reilly's , advance ) offer 1 year warranties on most fuel pumps .
  18. 05snopro440
    05snopro440
    Is it leaking from the pump? If so, where on the pump body? Or is it leaking between the pump and the block?
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    Those are aftermarket , not stock Chevy issue , they're differently designed block off plates . The stock Chevy plate blocks off the casting on a stock SBC .
  20. 19Eddy30
    19Eddy30
    from VA
    Share a pic , I know the pic I posted after market ,
    Around 86 ish , some of block , where equipped start of Efi, I do not know if I have seen a Gm plate ,maybe boat motor , I would think a Gm would look like the plate on left steel maybe cast & more likely with Gm #
  21. Lone Star Mopar
    Lone Star Mopar
    If you are leaking oil & fuel from 2 SBC pumps & you do not have the mounting plate I'd wager that's your issue.
    The pump arm is further in than it should be, probably being depressed to far and causing your problems.
    Yes modern pumps & ethanol gas don't last like they used to, but you should get a few years out of a new one at least.
    They do make a "block off" plate that looks the same but has no hole for the fuel pump arm. Those are used for electric pumps. What you need is a mounting plate. Every SBC w mech pump I've ever replaced required that. Also the new pump should come w a gasket as well.
    I only mention it because the last one I bought did not.
    Deuces likes this.
  22. hepme
    hepme
    Like others said, use the mounting plate. The block off plates are normally used when converting to an electric pump. Use the plate and one of the pumps you took off-bet you're fixed. (gasket it)
    Deuces likes this.
  23. Unkl Ian
    Unkl Ian
    Early 90's I went through 5 or 6 fuel pumps on a SBC, from 2 different retailers.
    All in less than a year. Cheapie aftermarket garbage. The marks on the box were the same,
    from both retailers, so I ***ume they were buying from the same ****py source.
    One lasted 3 days. Parts guy tried to give me a hard time,
    until I showed him that the arm snapped, so there was no spring return.
    Parts guy couldn't believe it.
    The others just stopped pumping, with no warning.
    After a while, I could change them pretty fast. Imagine cold fuel on your hands,
    in the middle of winter, with the wind blowing. Good times.
    Was ready to spring for a big name pump, then they stopped failing.
  24. 2OLD2FAST
    2OLD2FAST
    from illinois
    OK , the plate with the hole for the pump is called a FUEL PUMP MOUNTING PLATE . The blank plates are both fuel pump block off or " fuel pump Delete" plates . There , we good now ?
    hotrodA and Deuces like this.
  25. Harleyv89
    Harleyv89
    Ok thanks mate ill check that it was fitted with a mounting plate, it seems to be leaking from the weep hole or where the pump is crimped together which i ***ume the leak is from a stuffed diaphragm. I had one on their for 12 months no problem
    Lone Star Mopar likes this.
  26. Harleyv89
    Harleyv89
    Looks like its leaking from either where its crimped together or out the weap hole
  27. Harleyv89
    Harleyv89
    Tried 2 different brands but one was carter. Its leaking oil and gas this time, forst was was just gas. Im going to check if it has that spacer
  28. Harleyv89
    Harleyv89
    Hard to tell where its leaking from but this time its oil and gas, last time was just gas but it seems to be sitting around where its crimped together as its a sealed unit either that or the weep hole
  29. RodStRace
    RodStRace
    You are getting junk pumps, most likely. I know stuff costs more down there, but I'd try a quality, preferably rebuild able one if you can find one. BUT, only if they also stock a rebuild kit and have good reviews.
    This does not have a link to the rebuild kit, is more than the chrome version (!?!) and has some bad reviews.
    https://www.jegs.com/i/JEGS/555/15952/10002/-1
    Tow Truck Tom likes this.
  30. 19Eddy30
    19Eddy30
    from VA
    What you are calling spacer is fuel pump plat,,, If plate not installed/missing it will pump a lot of oil out , no little leak ,,
    There are 2 gaskets required one between blocked and plate the other between plate and fuel pump ,
    one square with point on top and one diamond shaped .
