Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. lumpy 63
    lumpy 63
    Luckily it hit the piston in a weak spot...
  2. saltflats
    saltflats
    from Missouri
    Ground strap from the plug?
  3. lumpy 63
    lumpy 63
    It's pretty big and I ***ume very solid to do that damage. I think it would have spit a ground strap out. I'm pretty sure the offending item went down the carb
  4. hotrodjack33
    hotrodjack33
    Looks like one of my blood pressure pills (capsules)....they're brutal
  5. swade41
    swade41
    from Buffalo,NY
  6. 427 sleeper
    427 sleeper
    What does the head look like? :confused:
  7. Lloyd's paint & glass
    It's a big chunk of iron with springs and valves in it, but that's not important right now :cool:
  8. Lloyd's paint & glass
    Discharge nozzle screw, edelbrock squirter check valve, hmm...
  9. lumpy 63
    lumpy 63
    The head had some damage , it was welded and surfaced. the piston was the weak spot.
  10. 427 sleeper
    427 sleeper
    Thought the head might have some different tell-tale signs of what the hell it could have been. Wierd as hell, that's for sure!
  11. DDDenny
    A forging never starts out looking like the finished product.
    Not talking about forging a piston but after a lot of hammering I don't think that piece started out quite the same shape.
    Sharpone, chryslerfan55 and lumpy 63 like this.
  12. 1pickup
    1pickup
    Helping my Bro get caught up on some bodywork on a couple 60s cars before winter hits. Looking like it will be a bunch of mechanical work this winter.
  13. 67drake
    67drake
    from Muscoda WI
    IMG_2825.jpeg IMG_2823.jpeg IMG_2816.jpeg Killed a few birds with one stone today. My machinist said the heads were ready for my ‘63’s engine. I decided to have him go over the block for tanking and honing and polish the crank. So I did a pickup/ drop off. He lives on the other side of the state from me, so I also went to one of my son’s house in the area and traded a OT rear end for one of his welders.
    Lots of driving, but worth it. :) IMG_2825.jpeg IMG_2823.jpeg IMG_2816.jpeg
  14. Clydesdale
    Clydesdale
    Got some paint on the stepped arms for the Chevy. No show pieces but will work fine under the car for my tastes.
  15. lumpy 63
    lumpy 63
    Been working on the Tempest, didn't take any picture's but did some modifications to fit a 19x 26 double p*** radiator. I ordered a pair of quality flat head engine mounts because they are very similar to the factory unavailable tempest mounts and they are through bolted. Also got a set of Hedman hustler 1 7/8" A body round port headers that look like they will fit pretty well. Tomorrow I am going to fab up an upper radiator bracket using a set of dimple dies ...we'll see how that goes:p
  16. saltflats
    saltflats
    from Missouri
    Have fun with those header bolts.
  17. 402BOSSMAN
    402BOSSMAN
  18. brading
    brading
  19. Clydesdale
    Clydesdale
    With lowered springs. I am currently suffering from excess positive camber.
    The camber adjustment is at the end of the upper arm on 49-54 chevy front ends, so by raising the lower arm mounting it subsequently adds negative camber by increasing the angle of the upper arm.
    At least that's how it works in my mind, I'm sure someone will be along to correct me if I'm wrong:D
    Whether the car will be too low now, with the lowered springs remains to be seen but I can easily get a fresh set of springs and cut to suit ;)
    Sharpone and chryslerfan55 like this.
  20. brading
    brading
    Thanks for the answer Clydesdale. Can you not adjust your positive camber out on the eccentric top pin.
    Sharpone likes this.
  21. Clydesdale
    Clydesdale
    It is maxed out for negative camber right now:(
    Sharpone and brading like this.
  22. lo c dan
    lo c dan
    Frame needed tweaked. . one step forward two steps back, needed to be done. . fixed, now onto the front cross member.
  23. Oneball
    Oneball
    Almost two weeks of on/off struggling and I’ve managed to replace the lower driver’s side ball joint on the Merc, I just couldn’t get it split from the upright.
  24. Clydesdale
    Clydesdale
    Was the chisel involved? Gnarly!!!! :D
  25. Oneball
    Oneball
    Just to get the rivets out, which I’m sure are twice as hard as Chevy ones!!!
  26. Lloyd's paint & glass
    Another quality gl*** job from Big Daddy's trim and custom. 20241017_175147.jpg 20241017_175128.jpg
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    My Son had put a dime size dent in the door with his Nova. It’s currently is on go-jack’s and he leaned against his car when it rolled into the 56. So he took it in for a little paintless dent removal. Attachment.jpeg
  28. snoc653
    snoc653
    from Iowa
  29. Lloyd's paint & glass
    I have to cut the windshield in the morning and he'll pick them up tmrw afternoon.
  30. tomcat11
    tomcat11
    This, upside down?
