Projects 1939 Ford convertible mild custom.
Discussion in 'Traditional Customs' started by John 79, Sep 13, 2023.
  1. MMM1693
    MMM1693
    I agree with Jeff
    Okie Pete and guthriesmith like this.
  2. The 39 guy
    The 39 guy
    I agree with guthriesmith and MM1693 !! Drive it and have some fun!
    Jag håller med de killarna! Kör den och ha lite kul!
  3. John 79
    John 79
    from Sweden
    Thats my plan, fix som small stuff and use it as a driver at the same time. 20240804_133244.jpg
  4. Rand Man
    Rand Man
    I like it.
    Stogy and John 79 like this.
  5. Jacksmith
    Jacksmith
    from Aridzona
    What a sweetheart!!
  6. Okie Pete
    Okie Pete
    Awesome
  7. John 79
    John 79
    from Sweden
    Not any updates, been driving it some but now its fall/winter time so there will be some work done soon. 458921531_3694271207549551_1551928900663772110_n.jpg
  8. MMM1693
    MMM1693
    Glad you had a good summer with it. Love the car. Put my 40 on the hoist yesterday, getting ready for new clutch. I'm also gonna switch to 12 volt. Winter work!:cool:
    Stogy, Outback and Okie Pete like this.
  9. SicSpeed
    SicSpeed
    from Idaho
    Great looking 39. Mine still has a Flattie but running an 8ba with a Merc crank, juice brakes, a Columbia, 12 volt and electric fuel pump.
    Stogy, Sart156, F-head and 11 others like this.
  10. John 79
    John 79
    from Sweden
    So, the 39 needs to be a bit lower in the rear. Now it sits kinda level and i want that speedboat stance.
    I got 2 inch lowering blocks and my plan is to use 4 inch instead, it's already hitting the frame in big bumps and i got about 2 inch travel to the frame now. I havent mounted the shocks yet because i knew the rear axle would sit lower than now.
    Started on a little kickup today, dident have any material with the right thickness at home but i managed to do some cutting.
    Im exited to see how this turns out.
    20241103_123547.jpg 20241103_123658.jpg 20241103_131607.jpg 20241103_135019.jpg 20241103_140405.jpg
  11. Outback
    Outback
    from NE Vic, Oz
    Looking good :cool:
    Stogy likes this.
  12. autobilly
    autobilly
    Very nice cruiser, roll-on summer.
    Stogy likes this.
  13. John 79
    John 79
    from Sweden
    Minor progress, made the upper and outer piece.
    Got almost 5 clearance in ride hight minus the 2 that the new 4 inch blocks will add.
    Might take some more but i will do the other side first and mount the new lowering blocks to se were everything goes first.
    Also there is alot more work to do the inner piece of the kickup and i need to take off the rear axle to get more room to work in.
    20241108_130214.jpg 20241108_130240.jpg 20241108_131239.jpg 20241108_132229.jpg 20241108_133815.jpg
  14. Crusty Chevy
    Crusty Chevy
    You may have plans to address this on the inside and I am jumping the gun, but I would recommend adding an extended full face plate that goes over the outer frame rail and what you added above. Rosette weld and perimeter weld. I would not trust just a **** welded arch added on top of the flimsy C channel frame especially as you have cut out the X member part.
    Stogy, Okie Pete, NoSurf and 2 others like this.
  15. John 79
    John 79
    from Sweden
    There will be more stuff added, this is not finished yet.
    Stay tuned
    Outback, Stogy, Okie Pete and 4 others like this.
  16. NoSurf
    NoSurf
    Looking good.
    I'm sure you're going to add fish plates.
    Outback and Stogy like this.
  17. John 79
    John 79
    from Sweden
    I will do box plates on the inside but I want to mount the 4 inch lowering blocks first and see exactly were the rear axle sits before i do that if I need to change something.
  18. Dak Rat
    Dak Rat
    from NoDak
    I would never attempt that kind of work with the body still on the frame. But that's just me.
  19. John 79
    John 79
    from Sweden
    Made a pair of 4-inch blocks and mounted them to see if there were enough clearence, everything seems fine so now i will start vith boxing the inside of the kickup.
    This is how it sits now.
  20. guthriesmith
    guthriesmith
    Stance looks great! :cool:
    Outback, Stogy, Okie Pete and 3 others like this.
  21. ronzmtrwrx
    ronzmtrwrx
    Looks great.
    Stogy, Okie Pete and John 79 like this.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    *****in..... gotta love a tail dragger
  23. Jacksmith
    Jacksmith
    from Aridzona
    Yes-sir-ee!!!
  24. John 79
    John 79
    from Sweden
    Continued on the p***enger side kickup reinforcment, rolled some thick plates for the inner structure.
    Also made a inside boxplate, will weld it in place later today. 20250118_110600.jpg 20250118_112627.jpg 20250118_123553.jpg 20250118_123502.jpg
    Stogy, hfh, Shadow Creek and 12 others like this.
  25. ronzmtrwrx
    ronzmtrwrx
    Nice Work.
  26. Jacksmith
    Jacksmith
    from Aridzona
  27. hotrodA
    hotrodA
    Very nice!
  28. F-head
    F-head
    Very nice, much cleaner than the large clumsy looking operation we see so much now days
  29. John 79
    John 79
    from Sweden
    Got the p***enger side done today, did some repairs to the rear part of the frame that had alot of rust between the outer and inner frame pieces. Made the inner piece first and plug welded it to the old leaf spring beam where the old rivit were.
    The new outer frame piece was also plug welded in four places to the inner piece.
    Also welded the inside boxing plate.
    20250125_141807.jpg 20250125_141827.jpg 20250125_153407.jpg 20250125_181701.jpg 20250125_181750.jpg 20250125_181707.jpg 20250125_181733.jpg
    Outback, Stogy, simplestone and 3 others like this.
  30. Nicely done...made even more difficult with the body on the frame.
