Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. lumpy 63
    lumpy 63
    20241017_164315.jpg 20241017_164357.jpg 20241017_172733.jpg test fitting mockup 400. A body headers are going to work:cool:
  2. Little Truckdoctor and I set the mock up engine in place last night. It’s no where close to where it needs to be, but we ran out of time. We will go back at it Saturday. IMG_8337.jpeg IMG_8340.jpeg IMG_8336.jpeg
  3. L. Eckart
    L. Eckart
    Recently purchased this Henry 32. Has many little items needing my attention so I'll be working on it over the winter and hopefully drive it some this coming spring 2025. A**** the chores is new fuel line, new partial brake lines and adding residual valves, changing trans cooler lines, valve covers, air intake, dented oil pan and new shocks and coil overs and possibly a new wiring harness. I know once I start it will multiple!
    Okie Pete, rod1, jet996 and 11 others like this.
  4. atch
    atch
    Those things have a way of ***********. Replacing the floors in Clarence started out as a 3-4 week endeavor and grew into 5 1/2 years of major changes and upgrades.
    rod1, jet996, Sharpone and 8 others like this.
  5. Cleaned up and going home :cool: 20241018_131431.jpg 20241018_131421.jpg
  6. rob-redm
    rob-redm
    just finished painting the center on these early D spokes for my 66 Nova Wagon
  7. Cut the leaf spring brackets off of my rear axle, pulled the axles and changed the brakes, I had a new set of loaded backing plates with new drums, had them for sale at the first Lloydfest for $75, glad nobody bought them :D 20241018_154346.jpg 20241018_154353.jpg 20241018_154356.jpg
    Okie Pete, jet996, Sharpone and 11 others like this.
  8. 327Eric
    327Eric
    I reunited my car with the hood I got rid of 30 years ago, installed an N.O.S. Core support and got the flip front working again, rotated the 413 and got her set for yet another winter of not being able to work on her IMG_20241017_163238.jpg
  9. patsurf
    patsurf
  10. No i bent it because I'm a large ***** with a bad at***ude :cool:
  11. swade41
    swade41
    from Buffalo,NY
    How long have you owned the J ?
    Sharpone and chryslerfan55 like this.
  12. choptop4
    choptop4
    Sealing the driveway before winter hits !!!
  13. lumpy 63
    lumpy 63
    20241021_180304.jpg Trans cross member fabbed, engine is sitting where it will stay. I think the hood will shut even with the performer RPM intake:cool:
    Okie Pete, jet996, saltflats and 11 others like this.
  14. lumpy 63
    lumpy 63
  15. Long sleeve shirt
    Big fan and a dust respirator
    no big deal
  16. 427 sleeper
    427 sleeper
    What happened to the Vette Anthony?
  17. Something fell on it.
    This one sat outside for a long time
    Rat and squirrel (not the HAMB one) poop
    The sun eat this one up. Most is raw gl***.
  18. guthriesmith
    guthriesmith
    That vette has definitely had a hard life. I grew up riding in the back of one of those.
  19. The guy just wants this fixed. Needs the upper bird cage replaced.
    He doesn’t want it painted either. Said the plan was to make it go and stop.
    Im ok with that but he better get the ch***is under control before it gets bad.
  20. lumpy 63
    lumpy 63
    Also was able to find vintage Moog and nos Gm front suspension parts for half the cost of an overseas rebuild kit,
  21. 427 sleeper
    427 sleeper
  22. Why do I have a feeling he’s gonna be banished to the couch every time he stays the night.
    Sharpone and alanp561 like this.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The old me would have. Now and day’s life is to short for that nonsense.
  24. IMG_8362.jpeg IMG_8348.jpeg IMG_8347.jpeg IMG_8346.jpeg IMG_8359.jpeg Little Truckdoctor and I got the engine installed and mount made. We ran out of time for the transmission crossmember, it’s currently C clamped to the frame with some wood blocks. We have an idea on what to do, just need some time. Maybe this afternoon when I get home from work. Little Truckdoctor also built us some wheel stands so I can get under Papaw and have him at ride height.
  25. My worlds been on hold for 2 years without a shed, or workshop while finding a new home. Last run at it so I finally have my dream cave,nearly. 787AC7D1-33D5-44F9-912D-C6F015A733EC.jpeg A8D874C4-48B7-4CC4-814A-E7B76FABFE13.jpeg 37BC038F-A645-457D-8F3C-DA42E1C7AAFC.jpeg
  26. lumpy 63
    lumpy 63
    Awesome Chris!
    Sharpone and Barrelnose pickup like this.
  27. lumpy 63
    lumpy 63
    Um....Andy, did you forget the exhaust manifold?:p
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I like em tight. But this isn’t one of those moments. :)
  29. Lumpy, when we first mocked it up, there was absolutely no way the manifold was going to clear the steering box. With the manifold on it, the engine was pushed approximately 1-1/2-2” to the right. I pulled the manifold off, centered and leveled the engine and will use either the POL or Speedway kit to use a Square Body C-10 power steering box on the outside of the frame. IMG_8340.jpeg IMG_8337.jpeg
