Projects T C cab. 60's style on the cheap!
Discussion in 'The Hokey Ass Message Board' started by dumprat, Sep 10, 2022.
Tags:
  1. patsurf
    patsurf
  2. dumprat
    dumprat
    from b.c.
    Finally got a chance to mock up the steering. Shaft still needs coupling. Seat needs to go down a bit. Not sure if I will get the wheel I made 25 years ago chromed, or run a small Moon or something . It’s too tight to run one of my black superiors.
    IMG_2520.jpeg IMG_2521.jpeg Rear suspension is bolted up. Still need to decide on a pan hard or Watts link. Rake is ridiculous! I like it. Need bigger rear tires.
  3. dumprat
    dumprat
    from b.c.
    IMG_2522.jpeg Spent the morning welding bits onto some stainless marine hinges so I can start making doors. Kinda need to get them fitted before I start finalizing things. Some of this **** takes forever!
  4. RodStRace
    RodStRace
  5. dumprat
    dumprat
    from b.c.
    I thought about it. But this body doesn’t have any wood in it.
    Evil plan is to build 1/4” mounts to bolt to the back of each hinge. Then weld the works into each door on the bench. Then fit and adjust the doors to fit the body. I think I would be chasing all over trying it any other way.
  6. dumprat
    dumprat
    from b.c.
    IMG_2577.jpeg Had to pull out the black model A seat to get the back of the cab finished and welded on. The seat was too high and too thick and was “******* on my brain”
    Happy to have it out and moving the project forward again.
    More pics tonight. moving slow this morning, damn Lowenbrau!
  7. dumprat
    dumprat
    from b.c.
    Hangover gone! Added more structure under the box, and built the panhard bar. I wanted to lower the box a bit. So the box lines up with the body line. IMG_2578.jpeg
  8. dumprat
    dumprat
    from b.c.
    Put the cool Buick taillights my buddy Jeremy gave me on. I think they will fit the bill. Yes I know they are upside down. I think they look better this way. IMG_2584.jpeg
  9. dumprat
    dumprat
    from b.c.
    I got started on bead rolling the sides of the cab. It’s more difficult than it looks! Especially with a manual roller. I’m going to had to make a form to do the curve at the edge of the door where it joints the horizontal bead. The roller won’t turn sharp enough. IMG_2586.jpeg
  10. brEad
    brEad
    Lots of progress! Really coming together.
    dumprat likes this.
  11. High test 63
    High test 63
    Dumprat, your truck s looking great!
    Lots of hard work
  12. Olcars
    Olcars
    This is so cool; I really can’t wait to see it on the road!
  13. dumprat
    dumprat
    from b.c.
    IMG_2605.jpeg Logic would dictate running stock rockers on this little motor. But for $80 I couldn’t p*** these up. Now I need to find some cheap poly locks and stock 305 pushrods. I could actually ***emble this motor and get it running! I never expected that.
    Work continues bead rolling, fitting, and tacking the body panels. Lots and lots of welding ahead.
  14. patsurf
    patsurf
    don't forget washers for the intake bolts..
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Let me suggest that you face off the tops of those rocker studs. That way the Poly Locks will have a firm surface to "bite" on and be less prone to losing adjustment or loosening up. If they are screw-in studs it should be easy to face them in a valve grinder or equivalent.
    Your build looks great. Kudos
  16. dumprat
    dumprat
    from b.c.
    They are just temps. The engine needs to come apart to check clearances and relube everything. It’s rebuilt with new pistons, heads and stuff but it sat under a bench for a decade.
  17. dumprat
    dumprat
    from b.c.
    they are just stock press in studs. This is NOT a high performance build. Just a 305 with flat tops and a bit of a cam.
    brEad likes this.
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    You should be OK if you check the tightness occasionally.
  19. dumprat
    dumprat
    from b.c.
    Weld grind, weld grind, weld grind. Several hours worth. One side ready for primer almost! I have to weld up the other side ten ensure the front edge is straight before I tack the front curve of the side panels on. IMG_2616.jpeg
  20. dumprat
    dumprat
    from b.c.
    I need to figure out roof wood. Anyone have a suggestion for what kind of wood? Oak is out I’m allergic to it
  21. patsurf
    patsurf
    better just wear a mask--you want to be trad don't you?
  22. SS327
    SS327
    What about ash or birch?
  23. dumprat
    dumprat
    from b.c.
    I think ash might work. Birch is hard to work with. I’ve used it before.
  24. 2OLD2FAST
    2OLD2FAST
    from illinois
    I've always found birch to be very machinable . Ash & oak are prone to splitting .
  25. Tim_with_a_T
    Tim_with_a_T
    I was told when I made the header for my T top that Ford used ash for their wooden body supports. Not sure how accurate that is, but ash seems like a good idea to me if you're steering clear of oak.
    Outback likes this.
  26. dumprat
    dumprat
    from b.c.
    I think I have a cheap plan! Stay tuned….
  27. Jethro
    Jethro
    ***** willow?
    porkshop likes this.
  28. patsurf
    patsurf
    you think it grows on trees?
    SS327 likes this.
  29. dumprat
    dumprat
    from b.c.
    Sure!that would be some dang big *****!
  30. 2OLD2FAST
    2OLD2FAST
    from illinois
    Go with the watts link , too much sway with that short of a panhard,IMO
    What is the spring rate on your rear coilovers ?
