Projects 1941 Studebaker Champion Sedan Gasser Resurrection
Discussion in 'Traditional Hot Rods' started by Chucky, Sep 9, 2024.
  1. Chucky
    Chucky
    After a few measurements, I made a wooden stand that put the engine close to where I wanted it.
  2. Chucky
    Chucky
    I try not to buy parts until I need them, but these came in handy at $150.
    catdad49, -Brent-, pila38 and 9 others like this.
  3. Chucky
    Chucky
    I ordered the fat fendered Speedway headers and proceeded to cut them up. I’ll be cutting more and adding a different collector eventually.
    catdad49, -Brent-, pila38 and 16 others like this.
  4. choptop40
    choptop40
    The mock up engine crate jig is a good one...Love these Studes...nice build..
    porkshop, Chucky and RodStRace like this.
  5. RodStRace
    RodStRace
    The only concern with a solid mount for stuff like that engine is that the ch***is is on springs and tires (not solid). Adding weight to the body/ch***is or even a tire gone low could mess with stuff. @Chucky seems to be a pretty handy guy, so I doubt this is a problem for him. More a caution for anyone emulating this.
    Tickety Boo, porkshop and Chucky like this.
  6. Chucky
    Chucky
    This picture was taken today. I removed everything up front and then split the body from the ch***is. Most of the welds on the front axle were completed. Lower shock mounts, steering stabilizer mount, and steering stops are done. Holding off on spring pads (only tacked) until full weight mock up.;)
  7. Chucky
    Chucky
    Here’s the 327 I grabbed from a drug addict on FB marketplace. It was an experience I’d rather not repeat, but it was a “smoking deal”.:rolleyes:
    catdad49, -Brent-, pila38 and 10 others like this.
  8. Chucky
    Chucky
    Although it looked good, I like to check things over. So, I tore it apart.
  9. lumpy 63
    lumpy 63
    What pistons are those?
  10. bchctybob
    bchctybob
    I’ve always wanted a Stude like that, especially a two door sedan, I just never found the right car at the right time. Looking forward to seeing where this goes.
    Chucky, Apenaut and lumpy 63 like this.
  11. Chucky
    Chucky
    @lumpy 63
    The pistons are Keith Black hyper’s. I have them bagged / soaked in lube right now so I don’t have the exact part number.
  12. lumpy 63
    lumpy 63
    You may already know this but you need to open the top ring end gap with those.... Make sure you check it Chucky.
  13. John Metzker
    John Metzker
    I have a 40 champ available if you’re serious, I’m in So. Cal
    Chucky, porkshop and bchctybob like this.
  14. John Metzker
    John Metzker
    I have a ‘40 Champion business coupe. Tri5 rear end, non posi, ratio unknown. Front suspension and steering stock. Frame is uncut. 6” fire wall recess done with a torch. SW gages. Body is straight. Appears to be original paint with much red primer. Trunk floor
    is rusty, some rust in front floor boards. No ***le, bill of sale. Vin tag matches hidden number on frame. Was going to install a sb 360 mopar engine which is included in sale.
    Looking to get 2500.00 for it.
    catdad49, bchctybob and Chucky like this.
  15. Balljoint
    Balljoint
    My grandfather was a Studebaker fan, when he p***ed there were three of them sitting in front of his home. He’d drive one until it wasn’t economical to repair, then get another and do the same. He wasn’t a hot rodder but he was a mechanical genius, self taught and he could fix or build most anything. If he were still around he would like the direction of this build.
  16. Chucky
    Chucky
    @Balljoint I’m humbled to hear my simple home brewed thread invokes fond memories for others.
    The plan is to head to north Minneapolis tomorrow for a variety of steel products. I’m looking forward to a complete redesign of the front of the ch***is. Here’s a close up color photo of the Speedway shackle mount. The ch***is is up-side-down in this picture. Most Speedway parts need close inspection and often times modification, but these mounts are terrible. You can clearly see how not “centered” they are, WTF? Not to mention the leaf springs were 3/16” difference in length unloaded, and stayed different lengths even when loaded. I ended up ordering a 3rd spring which netted me 2 springs within a 16th of each other.
    catdad49, -Brent-, pila38 and 11 others like this.
  17. Chucky
    Chucky
    Flashing back to my initial mock-up…I used exhaust clamps to mount the Speedway column. The column drop is 2 threaded rod couplings welded together and ground smooth.
  18. bchctybob
    bchctybob
    Those Speedway basic steering columns are great. I just put a longer one in my Austin to improve the driving position. I like that intake manifold too, taller than most. Great progress.
  19. Chucky
    Chucky
    I welded high grade fine thread nuts to the steering box bracket, in place of the provided spacers. Since the bracket is 1/4” thick, it allows the bolts to completely p*** through the welded nuts. The co**** threads in the box itself were drilled out and the cheap ****on head Allen bolts, that hold on the cover, were swapped to hex head bolts. After I adjusted the big nut, which often is too tight (ruins the bearings), the box went from not smooth to…oh my goodness, that is one smooth steering box. YMMV.
    catdad49, pila38, saltflats and 8 others like this.
  20. Chucky
    Chucky
    There’s a lot going on in this picture…Adjustable steering stops were set to give 1.5 steering wheel revolutions in either direction, which is slightly less than the capacity of the box. A traditional VW steering damper is installed with a single mini bike handle bar mount (clamped the tie rod perfectly). The calipers were modified (grinder) to allow the brake hoses to be installed up-side-down. The hoses are angled at the banjo bolt and I wanted them to point slightly up, instead of slightly down. The double sided steering arm was tweaked to allow proper caliper movement. And, you can see the shackles were mounted beyond the end of the factory frame. I’ve recently extended the frame by 6”.
    catdad49, pila38, saltflats and 10 others like this.
  21. Chucky
    Chucky
    This thread is now mostly “caught up” and ch***is mods have begun. The cool weather makes for excellent working conditions. Please keep in mind this is a low budget build, so no frame table for me. But, I have saw horses, several levels and a speed square.;)
  22. Chucky
    Chucky
    The driveshaft p***-through p***es through the cross-member at a slight angle. I wanted it done before I cut the front of the frame apart. The frame is up-side-down in these photos.
  23. Chucky
    Chucky
    Someone prior to me installed a 2.5” square front crossmember. The factory frame rails are close to 2.5” tall X 1.5” wide. It bothered me that they used a crossmember that was actually larger than the frame rail. The feng shui was all wrong. I initially left it in place, regretted it, and now it’s gone. My new crossmember is 2” X 1.5” which allowed for an easy weld to the new 2.5” X 1.5” frame extensions, which make the frame 6” longer than stock. I went ahead and changed the shackles to longer, more robust shackles that use all bronze bushings. Finally, I made the front shackle mounts more precise than the Speedway junk and they bolt to the frame for now, in case I need to move them.
    catdad49, -Brent-, pila38 and 8 others like this.
  24. Chucky
    Chucky
    A 3/8” “HEAVY” hex nut accepts an 11/16” wrench, unlike the normal 9/16” wrench size. Using a step bit, I enlarged some of the factory body mount holes to 3/4”. Mild hammer blows to the sacrificial bolt will “press” the hex nut into place. The extra material allows easier welding and this can be done after boxing the frame.
  25. NoSurf
    NoSurf
    Great build.
    Now I want one too.
  26. Chucky
    Chucky
    I made 3 “pins” out of 1/2” bolts. The plug welded pins tie the steering box bracket to the outside surface of the frame rail. Not super beautiful, but the bracket isn’t coming off…ever. Obviously the plug welds aren’t done in the photo, but they are now.
    catdad49, pila38, saltflats and 3 others like this.
  27. Chucky
    Chucky
    The frame has some damage from days gone by. There was a notch cut by a torch that I can only ***ume was for exhaust clearance. When my welds turn out a bit ugly, I just recall how they looked before and then I feel better.
  28. In_The_Pink
    In_The_Pink
    Front end of the frame is looking much cleaner and tidier now. :)
    How much do you expect the front leaf spring to flatten out once they are fully loaded?
    One suggestion would be to pick up a small digital level like so. You don't have the same length to work with as a two or four-foot spirt level, but you always know the exact angle, instead of trying to decide exactly how close the bubble is to centered:
    I have used mine so much in one year's time-- it's one of those tools I wish I had purchased long ago. The magnetic base is extremely handy, too, especially if you are using it in combination with a piece of steel angle or similar to check for level over a longer distance.
  29. Chucky
    Chucky
    I think the springs will grow in length about 2”. I set the shackles about -1” from plumb. I’m in uncharted territory, as I find no other examples using my selected parts. I’m committed to re-work if necessary to get this set-up “right”. I’ve seen 3 examples recently on the HAMB where the shackle angle was very bad. Besides re-work, there’s options I’ve pondered including adding a leaf or two. Also, I’m kind of a fan of those cheap coil-over shocks the VW guys use for a little lift. Think JC Whitney. Either way, the frame is about 70% finished and I will be doing a full weight mock-up. Looking forward to hanging all the front sheet metal, as I’ve never seen this car fully dressed.
    Note to self…buy digital level.
  30. Chucky
    Chucky
    The frame welding is 95% done! I plan to get some paint on it and then take the ***embly process further.
    catdad49, -Brent-, pila38 and 13 others like this.
