Technical Is my axle shaft too long?
Discussion in 'The Hokey Ass Message Board' started by Just Gary, Oct 19, 2024.
  1. Just Gary
    Just Gary
    BINGO!
    I used an old shower curtain rod & measured a bit over 25".
    Then measured the axle; almost 25 1/2".
    Time to cut the axle.
    Thanks again, guys, for all your help.:cool:
  2. 57 HEAP
    57 HEAP
    Be sure to check the spline length and make sure the axle shaft doesn't stop short after cutting.
    mad mikey and Just Gary like this.
  3. Jmountainjr
    Jmountainjr
    mad mikey, Johnny Gee and Just Gary like this.
  4. nobby
    nobby
    Hello, the distance is 1 1/8 inches - in a STOCK OEM configuration
    the cross shaft in the diff is 3/4''
    the 5mm of air each side is because........
    the PITCH of the crown wheels of different gears alter the final position of the carrier when setting the back splash so there has to be some space.
    ergo - you are still ******* in the wind as the shafts you have at 1'' of space WOULD work fine as they would clear the 19.050 3/4'' cross shaft with a 1/16 of an inch on each side
    BUT ONLY
    with the crown wheel pitch of whatever the original gears were, as you could change the gear from what came out of it and it touch.... I.E. who ever done builded that axle purposely but 1/16 of an inch clearance when cutting the axles the first time with the gears in the centre section.......
  5. Just Gary
    Just Gary
    So....
    I followed @19Eddy30 's advice, t******* about 1/4" with my trusty 4.5" Dewalt grinder and a fresh cutting wheel.
    Then beveled the edge with a grinding wheel and filed each splines' inner diameter.
    Everything test-fit nicely, so I re***embled the whole shebang.
    All done!:)
    Thanks again for all the guidance.
  6. mad mikey
    mad mikey
    Nice Gary. It will work just fine. Problem solved!:)
    Just Gary likes this.
  7. Glad you got it sorted.
    Regarding "shortening shafts" ... the pics of the power tools and a finger with a ring on it did make me cringe o_O
    "Giving the finger" is a motoring gesture term ... it should not be used medically :)
  8. lumpy 63
    lumpy 63
    Winner winner chikin dinnyr:D
    loudbang and Just Gary like this.
