Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. Sharpone
    Sharpone
    I was taught that a bolt or screw should have a couple thread out, on a blind hole best practice if at least 1 -1/2 diameter for depth, usually the bolt is of higher strength than the tapped material and more threads increase the clamping ability.
    Dan
    Tow Truck Tom and 29A-V8 like this.
  2. Six Ball
    Six Ball
    from Nevada
    A bolt must at least fill the hole or mason bees will build a nest in it.
    61Cruiser, vtx1800, jet996 and 3 others like this.
  3. 29A-V8
    29A-V8
    from wyoming
    yes you did and its kinda fun to watch!!
    RodStRace, osage orange and Sharpone like this.
  4. 29A-V8
    29A-V8
    from wyoming
    I wanna add my 2 cents worth but I checked my change and I dont have a cent. :cool:
  5. j hansen
    j hansen
    From the web,,,
    Skärmavbild 2024-10-21 kl. 11.07.28.png Skärmavbild 2024-10-21 kl. 11.07.17.png
    GuyW, Sharpone, 29A-V8 and 5 others like this.
  6. nochop
    nochop
    from norcal
    I actually like the look of 2 threads peeking out of a nut
  7. 57tailgater
    57tailgater
    from Georgia
    That's a standard rule of thumb where I work - no exceptions. I like the look too and it gives me more confidence on the joint.
    RodStRace, Sharpone, nochop and 3 others like this.
  8. Bandit Billy
    Bandit Billy
    Too old to be climbing in and out of a pick up bed but it needs a Por-15 bed liner? Make your daughter do it!
    Just Gary, seb fontana, fauj and 32 others like this.
  9. patsurf
    patsurf
  10. deathrowdave
    deathrowdave
    from NKy
    looks as if she is doing great work
  11. Bandit Billy
    Bandit Billy
    I told her she will do the base coat when we paint it black next spring. Dad will handle the clear bit.
  12. '34 Terraplane
    '34 Terraplane
    from Western PA
    You should be very proud of her interest and effort.
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I hope you are paying her at union scale, Dad!
    seb fontana, 29A-V8 and Bandit Billy like this.
  14. RICH B
    RICH B
    While it's not something I can show pictures to illustrate; cell phone video can be handy.
    I've set my phone up inside my car's trunk to check for latch location, taped it to a piece of cardboard and hung it in front of the radiator to verify hood latch engagement, set inside the glovebox to figure out why the latch wasn't working right, laid it on a creeper to watch drag link to pan clearance thru lock-to-lock travel, and a few others. I've either put light in with it or used the phone's light in closer confines.
  15. Stooge
    Stooge
    I dont know if this is common knowledge, but i was surprised when some other people were surprised by it. A speedway vacuum port that was made of cheese, made a mess of some threads on a newly installed intake on an installed engine. I didnt want to have to pull the intake, so pipe tap, some real sticky grease and a 12point socket to hold the tap and non flexhead ratchet to make it a little rigid since my tap wrench that would fit a 3/8 npt tap wasnt going to fit in there. Coat the tap in grease, do a few turns, clean it off completely, coat it again, few more turns, and repeat. The chips get caught in the grease and nothing makes its way into the intake so i didnt have to remove it, regasket, reseal, etc. I've done it similar for spark plug holes, stuff at work, garage, and has saved alot of time and effort over the years. I used Lucas red n tacky because i already had it, but it works great for this scenario.
    *Sorry didnt realize how big the pictures were
    enloe, brEad, 61Cruiser and 18 others like this.
  16. billfunk29
    billfunk29
    from Minnesota
    You can use an infrared bathroom heat lamp to cure the paint. Much more durable.
    Rawrench and Six Ball like this.
  17. RICH B
    RICH B
    Why improvise; they made a tool just for heating paint. Father-in-law said it made that old enamel lay down like gl***. Not sure what I'm going to do with the thing.
    In_The_Pink, orbitup, jet996 and 9 others like this.
  18. atch
    atch
    I cut the top off of a 2-liter soda bottle to heat rattle cans. Just fill with hot tap water and put paint can in, give it a few minutes and paint away.
    Pretty much free and idiot-proof.
    Boneyard51, brEad, 29A-V8 and 7 others like this.
  19. sixty3
    sixty3
    from Erie, Pa.
    I recently used the phone to record bubbles in the brake fluid while reverse bleeding my brakes. I clamped the phone to a yardstick that reached from the core support to the cowl over the master cylinder. Worked great, showed me what I needed to see.
  20. j hansen
    j hansen
    From the Web,,
    enloe, vtx1800, 2devilles and 12 others like this.
  21. Fabber McGee
    Fabber McGee
    When I worked in the body shop at our local Chevy Buick dealership as a young feller we didn't have the fancy paint heater. We used a single burner hot plate with the paint in a pan of water to keep from overheating it. Alkyd Enamel only, not very volatile.
    29A-V8 and Six Ball like this.
  22. arse_sidewards
    arse_sidewards
    from Central MA
    I don't know why the paint heater suggestion reminded me of this but:
    Any oily substance can be poured into a cylinder that's mid-stroke on compression and the spark plug reinstalled to lock up an engine so it doesn't spin when you're trying to R&R the crank pulley or flywheel.
    This is particularly useful when trying to do a crank pulley in vehicle as you often can't get an impact in there without draining the cooling system.
    If you have tools to lock the cam(s) you can also use it for timing belt replacements.
    I've even used water in cases where I was 100% sure I'd be getting the car running again same day.
    seb fontana, loudbang, 29A-V8 and 8 others like this.
  23. j hansen
    j hansen
  24. BJR
    BJR
    What keeps the whole works from sliding up on the red pole when pushing down on the handle?
  25. RodStRace
    RodStRace
    @BJR I'd guess the leverage on the top pulling out and at the bottom pushing in causes the silver square to jam on the red upright. You could add a locking thread on the other side, but it would add a lot of extra steps to the process.
    j hansen, 29A-V8 and BJR like this.
  26. j hansen
    j hansen
    From,,,,you know
    HemiDeuce, 29A-V8, Six Ball and 4 others like this.
  27. I am betting the back [ left here] side is like a bumper jack.
    Ben
  28. LOST ANGEL
    LOST ANGEL
  29. BJR
    BJR
    And what is that used for?
    Tow Truck Tom likes this.
  30. southerncad
    southerncad
    BJR, haven't you ever used a "chainsaw"?
    woodscaper, enloe, SS327 and 12 others like this.
