Projects Removing the street rod from an A RPU
Discussion in 'Traditional Hot Rods' started by GTHOtrod, Apr 14, 2024.
  1. BigJoeArt
    BigJoeArt
    Oh yeah! That's getting it!
    GTHOtrod likes this.
  2. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    The look of a Texas Cadillac.
    Keep it up. :D
    Outback and GTHOtrod like this.
  3. 05snopro440
    05snopro440
  4. Outback
    Outback
    from NE Vic
    Looking good :cool:
  5. GTHOtrod
    GTHOtrod
    Currently, fronts are 175 65 15s on 15x4s, rear's are 275 60 15s on 15x8s.
    Planning to change over to 16x4s all round.
  6. 05snopro440
    05snopro440
    Thanks!
    I bet it will look great with the 16's too. It has a nice hot rod rake right now.
  7. Have you checked to make sure the 16s will clear the front fenders?
  8. Outback
    Outback
    from NE Vic
    With a 4.50 it orta go close?
  9. Id be more worried about height. New wheels and tires definitely look a good bit taller
  10. GTHOtrod
    GTHOtrod
    Ride height isn't locked in as yet. Can raise it to aid tyre clearance.
    Definitely looking at a 4.50 16 up front for big rake
  11. 05snopro440
    05snopro440
    That's about 2" taller than your current front tire (1" per side). So it'll bring the car up an inch and the tire will be 1" closer to the fender.
  12. GTHOtrod
    GTHOtrod
    Had an interstate trip for work this week, and had the opportunity to pick up a front spring the steering arms while i was there. With a little creative packing, they made the trip home on the plane as luggage.
    With the spring and arms installed, I can progress with mounting the steering box. 20240926_111120.jpg
  13. GTHOtrod
    GTHOtrod
    Picked up a set of steel fenders this week. Need plenty of work, but hard to come by in this part of the world. 20241003_134253.jpg 20241003_134259.jpg
  14. GTHOtrod
    GTHOtrod
    Got some time today to get the shock mounts, engine mounts and steering box plate welded in.
  15. 51 mercules
    51 mercules
    Look like sedan rear fenders?
    guthriesmith likes this.
  16. 1biggun
    1biggun
    What rotors and calipers are those ? What is the rotor diameter ?
    I kind of like the look of the calipers for a Non HAMB type project .
    I have a 28 PU that came with a expensive shiny IRS and the frame is way to modifed to just cut it off and start over so its going to stay. ( for now )
    At some point I may build up a new frame and traditional suspension and swap the body over some day .
    Should be a nice truck when your done .
  17. GTHOtrod
    GTHOtrod
    Yes they are. I'll have to add a new flange for the pickup bed, and add a little width at the same time
  18. GTHOtrod
    GTHOtrod
    The brakes are Australian components.
    Rotors are Ford, 1971 XY falcon, 287mm diameter.
    Calipers are GM, 1996 VS commodore.
    1biggun likes this.
