Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I like em tight. But this isn’t one of those moments. :)
  2. Lumpy, when we first mocked it up, there was absolutely no way the manifold was going to clear the steering box. With the manifold on it, the engine was pushed approximately 1-1/2-2” to the right. I pulled the manifold off, centered and leveled the engine and will use either the POL or Speedway kit to use a Square Body C-10 power steering box on the outside of the frame. IMG_8340.jpeg IMG_8337.jpeg
  3. Stock Racer
    Stock Racer
    lumpy 63 likes this.
  4. jwilson645
    jwilson645
    from Alabama
    Threw the bedside and fender on to check the stance. It has a 3" drop axle in front with new stock height springs and so far I've removed 2 leafs from each rear pack. I think the rear needs to come down 2 more inches.
  5. lumpy 63
    lumpy 63
    Try extended shackles on the rear:cool:
  6. lumpy 63
    lumpy 63
  7. rob-redm
    rob-redm
    just finished painting the centers two weeks ago. I went and had tires installed on Saturday.. Sunday slapped them on ! WAGON WHEELS.jpg
  8. jwilson645
    jwilson645
    from Alabama
  9. wood buck made from the new gl***
  10. Son built this structure for his jeep floor IMG_2537.jpeg One more brace to go
  11. patsurf
    patsurf
    nice toes there teach....
    rod1, impala4speed and anthony myrick like this.
  12. ALLDONE
    ALLDONE
    3 weeks in on my street stripper, got the new winshield......sanded the bumpers , painted them to preserve them till I find a chrome shop.... looks like they are all gone...mexico???started cleaning under the hood....took a week off and went to utah... so all in it's 2 weeks IMG_3547[9100].jpg IMG_3558[9108].jpg IMG_3589[9116].jpg IMG_3733[9127].jpg IMG_3734[9128].jpg IMG_3547[9100].jpg IMG_3558[9108].jpg IMG_3589[9116].jpg IMG_3733[9127].jpg IMG_3734[9128].jpg IMG_3735[9129].jpg IMG_3736[9130].jpg IMG_3737[9131].jpg
  13. swade41
    swade41
    from Buffalo,NY
    I've been doing my own fibergl*** work as of late, trying to make a silk purse out of a pig's ear with this damn truck hood.
    So far I think it's winning, two afternoons and I still can't get the grill to fit this oversized hood but I'm literally whittling away at it.
    What a stock one looks like, grill fits over the hood.
    I added a flange to bolt the grill to but the hood is so wide I've actually resorted to carving out a space for the grill to sit in.
  14. jimpopper
    jimpopper
  15. Cheers Colin,
    It’s been pretty stressful these last couple of years, literally had nowhere to work on anything and all my gear, and I mean, all my gear has been in storage.
    It has been like living a different life really, soon be back on it though. You don’t realise what you do until you can’t do it.
  16. Hubnut
    Hubnut
    20241015_173417.jpg It's fine....everything is fine.
  17. Putting the broke pieces back together
  18. swade41
    swade41
    from Buffalo,NY
    I know we've talked about the aluminum double hump heads here before, I just ran across Chris Birdsong's latest video and he had bought Speedway's version and the valve broke with only 400 miles on them.
    So be careful
  19. Oneball
    Oneball
    What is going on with the cylinder next to it and why is the block cracked, did the broken valve crack the block?
    jimpopper likes this.
  20. lumpy 63
    lumpy 63
    It is kind of a no no to put 2.02s on a 283 ....I am wondering if the valve hit the piston due to the tiny valve reliefs and maybe it saw a little too much RPM?
  21. Rickybop
    Rickybop
    Nice bright sunny fall morning. Heading off to prep my 1931 Plymouth PA Business Coupe I just purchased so I'm sure it's ready to go when I take the trailer down there in a few days to haul it home. It doesn't have a front axle. So I'm taking an axle from a 1964 Ford truck and I'll u-bolt it to the leaf springs on the Plymouth.
    At least, that's the plan.
    I think I have everything...
    Edit:
    Done did it.
    Just like downtown. LOL
    Good enough just to get it on and off the trailer.
    Looks like a car now.
  22. HOTRODPRIMER
    HOTRODPRIMER
  23. squirrel
    I have to do yet another oil change on the Corvette, and I'm also going to pack front wheel bearings, and "flip" the front tires because of some uneven wear that could probably be prevented with a real front end alignment (and probably some parts replacement). But with over 20k on the clock since I got the car, and it's still driving, I'm happy
  24. lumpy 63
    lumpy 63
    20241024_100630.jpg Tested header fit with actual heads
  25. Lloyd's paint & glass
    You're definitely a bad*** reverend Jim :cool: drive em or let em go!
  26. IMG_2639.jpeg Should fix the issue with hitting the timing cover
  27. Lloyd's paint & glass
  28. We made a transmission crossmember for Papaw. The one I bought from EBay was advertised as being for an AD truck. Nope, didn’t fit for ****. With lots of encouragement from my friends, Lloyd and Lumpy, we made one that will work. It’s not the prettiest thing, but I think it will work. I also taught Little(?) Truckdoctor how to weld. He did damn fine for his first job. Resized_20241027_145154_1730058765627.jpeg Resized_20241027_145211_1730058757282.jpeg Resized_20241027_145215_1730058756962.jpeg Resized_20241027_145147_1730058766346.jpeg Resized_20241027_145140_1730058768678.jpeg Resized_20241027_145129_1730058773776.jpeg
  29. chevyfordman
    chevyfordman
  30. lumpy 63
    lumpy 63
    20241027_162502.jpg Recieved all my vintage and NOS ball joints , bushings and shafts for the Tempest today.
