Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    On Saturday morning, I woke up, hopped on the motorcycle and headed for San Francisco's Old Car Picnic. IMG_5354.jpg
    Naturally, I was drawn to San Francisco's only other flathead-powered A-V8. Rumor has it that it's an old Vern Tardel build. Note the trailer. He hauled a couch and a BBQ to the park! IMG_5360.jpg
    Stoner's T kicking up the hay.
    This chopped Packard was my pick. Such a heavy hitter.
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    After my morning at the park with the friends, I jumped in my truck and headed north to Petaluma. IMG_5370.jpg
    Being greeted by my favorite hot rod always makes me smile.
    David and I had a great half day at the shop. I had some brake parts for Ted's quarter-mile machine, and David helped me out big time by brazing the pedal shaft retainer since it was too thin to weld.
    The master at work!
  3. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Before heading home, I stopped by the local hardware store to pick up the pieces I needed to finish the job on Sunday. I brought the whole ***embly inside because, well, why not! IMG_5376.jpg
    The following day, I spent the afternoon painting, greasing, ***embling, and installing.
    I couldn't be more pleased with the finished product. It's clean, sturdy, and operates smoothly. As I looked at the ***embly in the car, I thought to myself, "I'm really getting better at this stuff."
  4. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    On Sunday, I also ordered a handful of parts ranging from gauges to banjo fittings. I fully intended on making templates for the aluminum pieces for the floor tonight, but that will just have to wait for another day.
    The recipe is: Hudson wheel, 1932 Ford dash, Moon column drop, Stewart-Warner "Mate" cluster, and old hot rod upholstery.
    Later this fall, I'll be painting the axle bells, spring, and shackles white. That's all for now!
  5. Joey,
    The combinations are all working so well together. Your careful planning and eye for what looks "good" and "right" and "correct" really show in this build. I am in awe!! Can't wait to see the completed product.
    Brian
  6. Joey, as Brian said, you have the right combination of parts, and they do look good together.
  7. Tim
    Tim
    from KCMO
    It’s so good dude.
  8. Six Ball
    Six Ball
    from Nevada
    Attention to detail is never wasted in these guys!
    osage orange, 41 GMC K-18 and J.Ukrop like this.
  9. ZerroHalfcup
    ZerroHalfcup
    I'll repeat what has already been said because it all works so well together. The car just looks very organic, nothing jumps out as out of place.
  10. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you so much, Brian. I really appreciate it. I feel like all my years of research are really paying off right now, although some of the elements happened so serendipitously, like the old torque tube headers and chopped windshield frame and posts from the mid-'50s. What a journey it's been!
    Thank you, Nick! It's special to be able to give them life again. When I was looking at that photo, I was surprised to see how few pieces are reproduction. I'm just doing my best to build them how they really did in San Francisco during hot rodding's Golden Age.
    There are few things I like in this world more than details. If there's an opportunity to make something special, I'll do it. The trick is just not going overboard!
    Thank you so much. That was the goal. Once it has a little bit of paint on it, it'll really flow together. Everything in due time. Can't wait for our roadsters to meet one day!
    Tim, BigJoeArt, Ragged Edge and 5 others like this.
  11. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    On this evening's trip to the garage, I focused on the pedal area. First, I did some t******* to give the clutch pedal more clearance. I worked in short bursts with the cordless grinder, trying not to annoy the neighbors. Once I got as far as I could, I decided to switch gears and call one of my old roommates to catch up.
    As we talked, I pulled out some card stock and started making my template for the floor area around the pedals. By the end of our call, I had the template looking and fitting right. I painted the card stock because, well, why not. I'll have a picture of it in position tomorrow.
    Cutting these aluminum floor panels isn't a required step at this point, but I figured it was a low-stress activity. This weekend, I'll be fitting the gas tank and potentially drilling the filler neck hole, all of which get me closer to dis***embly.
    Oh, and tomorrow I'll have some fuel block questions. That's all for now!
  12. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    As promised, here's my template. There will also be a center piece that will go right above the column, but I'll dial that in once everything is in position. (The whole thing will shift left a little bit, too.) IMG_5426.jpg
  13. Six Ball
    Six Ball
    from Nevada
    Reminds me of the first trip to Texas in my son's unfinished Studebaker station wagon. We pulled off in a parking lot near Hover Dam and laced up a leather boot for the steering column because we didn't need the extra heat.
    Tim, Ragged Edge, Kelly Burns and 3 others like this.
  14. Silva
    Silva
    I love the interior layout, dash, instruments and steering wheel all look pretty harmonious!
    You must be pretty excited, things are really starting to come together...
    J.Ukrop likes this.
  15. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Hahah that's some good on-the-spot thinking. I'm sure that interior had plenty of "sole."
    Thank you! That's the goal: make it feel as-found. I'm so excited. Now it's really feeling like a car rather than a conglomeration of parts!
    Tim, Outback, Ragged Edge and 2 others like this.
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    It was a light evening in the garage tonight, but I was able to put in a couple of hours worth of work.
    Before I did, I conducted a little science experiment with my new water temp gauge. The good news is that it works. I felt like a real moonshiner with this setup.
    Down in the garage, I spent a little bit of time messing with the gas tank mount. I'll be finalizing it this weekend, so I can check it off the list. Although chaotic, this shot reminds me of something you may have seen in an old Rod & Custom.
  17. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Next, I modified the instrument cluster ever-so-slightly to accommodate the ignition switch from the previous version. I'm still trying to decide where to put the push-****on from @Hitchhiker. Maybe it'll go in the cluster? Maybe it'll go on the far left of the dash? I'll have to think on that one before I drill a 5/8ths hole in anything.
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    For the final project of the night, I made two more templates for my floor. There's no rush on these. I'll cut them out of aluminum as time allows. Don't worry, the real ones will be painted black. Note that I removed the pedals so I could start thinking about bushings.
  19. RodStRace
    RodStRace
    I always figured a push ****on to be hidden on the underside of the dash directly in line with the key.
    Easy for those who know, less visual clutter, and here it's central to the other hand controls (brake, shifter). This will over time cause a bit of hand wear to the lower edge, which can be that lived in look or a clue to it's placement.
  20. Six Ball
    Six Ball
    from Nevada
    Far left side where Henry put them. It is a left hand task and leaves the right hand for shifter, E-Brake, key. or other things on your right that might need attention. :rolleyes: Also it would be protected and out of the reach of others and safe from accidental activation during other ****pit activities. :eek:
  21. Plus you can push the ****on while hand choking the carb from outside the car.
    Tim, NealinCA, J.Ukrop and 3 others like this.
  22. Six Ball
    Six Ball
    from Nevada
    And for that there is also the starter solenoid with the ****on on the bottom. Got one for my roadster build.
    J.Ukrop and 41 GMC K-18 like this.
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Great starter advice, friends. I think I have a plan that I'll be able to act on later this week.
    This weekend, I spent a couple of days finishing up the gas tank mount.
    The tank is fastened via six grade 8 bolts to a piece of 3/16ths steel that spans the width of the car. That piece is then bolted through the subrails to the frame via four 1/2 inch Grade 8 bolts. Rubber insulation was used to reduce vibration.
    Once the tank was secured, I took a 2-1/4-inch hole saw to the tulip panel.
    Once the filler neck was poking through, I moved the lunchbox latches slightly inboard. Now the steering column, gas cap, and latch are all in a line. The extra holes will be filled soon.
  24. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    The only other development from this weekend was that I took a gamble on an original SW water temperature gauge off of eBay. I was mainly buying it for the cast aluminum mount, but when it showed up, I decided to give it a try while eating breakfast. Michael supervised. IMG_5503.jpg
    I'm playing with location, but it looks right at home here. I didn't get a picture, but it matches the column drop perfectly.
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    As I closed down the garage tonight, I stopped and took a moment to reflect on everything that's happening on this project. We've been checking off a lot of "to-do" items as of late, and I'm feeling really good about how my skills as a hot rodder are developing.
    I'm fortunate to be able to have a project like this, and I'm grateful that I get to share my progress on here. These are special times.
  26. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    On this car, every piece counts, and all my friends seem to realize that. The other day, I received a small box in the mail from @So Cal Brian B. Inside, I found a thoughtful note on bright green paper and a very special sampling of cotter pins.
    Best of all, they had even spent time in the North Bay city of Benicia. IMG_5574.jpg
    These are the kinds of things I absolutely love.
    Can't wait to unbox them and put them to good use later this fall!
  27. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    In the meantime, I've been catching up on some light reading from my friend Kerry.
    And I'll end things tonight with a question: does anyone know what size fittings this fuel block takes? I'm planning to run my SW fuel pressure gauge on one side and a barb end to connect to the mechanical fuel pump on the other. IMG_5563.jpg
    That's all for tonight!
  28. 60 Special
    60 Special
    from Omaha Ne.
    Looks to me like the fuel mounting block holes are either 1/4" or 5/16". Based on that I would say the fuel delivery holes are 3/8-18 NPT. Looking at the end fitting, appears to be a 3/8-18 NPT to 1/4-18 NPT reducer. I might be wrong, but they appear to be one or the other. That fuel block is "PERFECT" for this car! You could not have picked a more appropriate specimen. Congrats on a very cool build! 60 Special
  29. dumprat
    dumprat
    from b.c.
    Don’t use br*** fittings on that fuel block if you can avoid it!
  30. Tim
    Tim
    from KCMO
    Yeah I think they are probably pipe thread I’d just take it to the store and try til something fits. Great updates I like that you got the steering/ gas cap/ hinge in line :)
    I laughed reading about your neighbor friendly bursts of grinder use. My last garage was under my kids bed rooms. I became real familiar with a sharp hack saw and files lol
