Technical Hard chop: sitting on the chopping block
Discussion in 'Traditional Hot Rods' started by 65standard, Feb 21, 2024.
  1. alchemy
    alchemy
  2. patman
    patman
    Those 47 holes will lighten that up a bit
    31chevymike likes this.
  3. 65standard
    65standard
    3FBEF62F-352F-429E-BD5C-A9A2C15444BB.jpeg DFE3594E-4FA3-4955-8633-5760DFFE4D8B.jpeg The brace is 14 lbs. not sure how much weight I remove with the chop, smaller gl***, and lack of door panel?
    Here’s my little interior door panel/pull.
  4. 65standard
    65standard
    Mocking up the outer door skin. I marked where to cut
    then cut it and coped out for the hinges. Then cut in the middle of the upper hinge for the rejoining seam. 1F5D8042-9550-4D87-B847-05E0F6BFBFDC.jpeg
    Use ****m to mark the inner skin for scribing C0650C9E-9E9D-455D-A8A6-3C0F2869B768.jpeg C94550E1-1188-40E9-AA29-2E1B27C1A57B.jpeg A506F257-3325-4CF9-8398-F6535A70801B.jpeg 6088D370-F656-4A38-8460-C60622C04703.jpeg
    hfh, RodStRace, Outback and 14 others like this.
  5. AmishMike
    AmishMike
    Beautiful build, nicely detailed for us following. Scary to think all the hours you have put into this build. I am sure your skills make it go lot quicker then some of us amateurs
    31chevymike and Outback like this.
  6. 65standard
    65standard
    635CC123-CC55-4E2E-9E96-2BB3F9A7F3BF.jpeg 2CC2E7CB-898B-4C11-A921-94C7C74BB952.jpeg 3A2CCEA8-8365-4DA6-900D-1F09075301FE.jpeg Have the door gl*** template made. May need to tweak it once I get the window felt and channel. I have to modify the lower gl*** stops so I don’t roll the windows down any more than needed.
    Bob’s cl***ic auto gl*** in Oregon will cut my gl***. He’s been very helpful.
    getting close to having fully functional doors.
  7. I need to know more about this Bob's Cl***ic gl*** company. Where's he at and a ph# please.
  8. Dick Stevens
    Dick Stevens
  9. 65standard
    65standard
    Working on the outer skin now that the inner structure is done with working window and Nader/X-brace for strength and safety.
    with the inner door skin scribed and trimmed to 1/4 “ of the body opening, I then rough trimmed the outer door skin to the door. Next I pinned it on.
    Then adjust the door gaps with a hammer and dolly before folding over the edge. That will be last part of building doors.
    AFBD331D-FCD9-4754-8BDE-894F974A73EC.jpeg 5BDBFC82-6B7C-4284-A51B-68952A90FF18.jpeg
    hfh, Outback, '40 Coupe Fan and 8 others like this.
  10. RodStRace
    RodStRace
    This has been fascinating to be able to watch. Way above my skill level and pockets!
    I do have a question about this next step. I see that everything is done in bare metal and is finished to that point and fine tuned. Would priming or sealing all these inner surfaces be better before the skin is formed over the inner?
    I know that there are a couple places that are going to be subject to welding heat after.
    Not questioning the work and I doubt the car is going to be sat outside in the weather 24/7, just wondering.
    31chevymike and porkshop like this.
  11. 65standard
    65standard
    The outer skin is only pinned to the inner door structure. Once the outer skin is fitted and tacked together, I will take it off to weld it and metal finish the skin.
    Then I will prime seal the inside of the door and put a piece of dynamat to the inside of the door skin.
    Follow along and you will see the full process soon.
  12. 65standard
    65standard
    Now onto the outer door top.
    I can’t stress enough how important it is to plan your cuts to avoid extra work or corners that just don’t flow.
  13. 65standard
    65standard
    704237A3-945E-4ACB-A64B-86E4027A7854.jpeg 9ABEC942-358D-4B3C-A38B-490B449B1701.jpeg CAE3E7B4-4DDA-42B0-8764-8A0D9C1C0F47.jpeg Here is what poor planning gets you. The pie cuts changes the length of the door top and the hinge area just doesn’t flow. Look at the abrupt transition at the cut.
    I will show another way of doing the same thing.
  14. 65standard
    65standard
    5B411291-D111-49D5-BA46-EEB88D004DBD.jpeg 35443EA5-0BB9-4492-8E71-FC9E99D5B3C0.jpeg BE211AD8-6DF8-4707-B622-8FADB761E62D.jpeg 31D7D5FD-5E04-4A9C-ADFD-892C7C866946.jpeg 685F227B-4931-4F6D-82DE-E1F3F9E2B000.jpeg C8F8EE20-4EAE-4770-8E4B-2BF3ABE9F143.jpeg 6F2354DF-A762-4EA1-BB34-8D6C01BEE035.jpeg DA39CC79-D2EB-4E7B-8F20-03CE8DBB0A83.jpeg 1612708D-39C0-497B-A37E-BC0BC5EDB5C1.jpeg Here is my door. I cut a slice into the front edge to change the pitch to match the laid back windshield. I will seam the back area in the middle of the upper hinge. Trim close and then ****m the overlap in order to scribe a perfect cut.
    Woogeroo, Kreepea_1, patman and 8 others like this.
  15. 65standard
    65standard
    8851EB4C-DF25-4CAA-B8DC-B74011F8F268.jpeg A note that Kenny from Brookville Roaster uses paintloc sheet metal on the door skins. Maybe to prevent rust or that’s all they have at the place that stamps them out.
  16. brady1929
    brady1929
    Great job.
    porkshop and 31chevymike like this.
  17. 65standard
    65standard
    Still working on the outer skin door top. IMG_7129.jpeg IMG_7131.jpeg IMG_7129.jpeg IMG_7131.jpeg IMG_7133.jpeg IMG_7135.jpeg IMG_7136.jpeg IMG_7148.jpeg IMG_7149.jpeg IMG_7147.jpeg
  18. 65standard
    65standard
    finishing the door skin, also working on the right door. Lots more to go. Stay tuned
    IMG_7183.jpeg IMG_7143.jpeg IMG_7172.jpeg IMG_7168.jpeg IMG_7176.jpeg IMG_7189.jpeg
  19. 65standard
    65standard
    93CF94C6-4CBC-4776-9230-57A41642DEA3.jpeg It’s starting to look like something.
  20. brady1929
    brady1929
    Damn! That looks so cool.
  21. 282doorUK
    282doorUK
    It certainly is, nice work you did there.
  22. 65standard
    65standard
    Here is the completed inner door. I even filled the middle hinge like I did on the jamb. I coated the inside of both panels satin black and put dynamat on the out skin to muffle the metallic sound of the door. IMG_7206.jpeg IMG_7210.jpeg IMG_7211.jpeg IMG_7213.jpeg IMG_7226.jpeg IMG_7228.jpeg
  23. 65standard
    65standard
    Some more door details
    and with the one piece 2” longer hood. With the correct 5.00x16 front ribbed tires and 7.50x16 rear tires and at full weight, it should have the stance I’m going for. IMG_7229.jpeg IMG_7232.jpeg IMG_7239.jpeg IMG_7267.jpeg IMG_7286.jpeg
  24. curbspeed
    curbspeed
    It's starting to look bad*** is what it is!
  25. The37Kid
    The37Kid
    Longer hood needed a narrower grille shell, correct?
  26. flamedabone
    flamedabone
    Wow!! That is major progress. Nice work.
    -Abone.
  27. 65standard
    65standard
    nope. It’s a custom made hood using the stock grill shell.
  28. Looks fantastic so far. Keep the updates coming.
  29. Rj27buick
    Rj27buick
    Thankful for generous use of your time to share all of your methods through pics and descriptions! All I have been hearing from all my grandkids is what they are thankful for. I try to explain that I am thankful for the pros on the HAMB who take the time educate us but I don’t think my grandkids understand. Very cool hot rod - way above my skill level - but very appreciative of your time to share. Absolutely beautiful
  30. EDMAR'S GARAGE
    EDMAR'S GARAGE
    from Crete, IL
    Wicked cool, my friend! You nailed the chop and stance. As others have said, THANKS for the awesome coverage on this build. Me living just up the road frome you in Crete, I'll keep an eye out for the end product when it's finished...but, then again, are they EVER actually finished??
    Ed
    65standard, 31chevymike and pprather like this.
