Technical Lower hose ideas
Discussion in 'The Hokey Ass Message Board' started by lumpy 63, Oct 26, 2024.
  1. lumpy 63
    lumpy 63
    Looking for a 1 3/4" lower hose for the tempest engine swap, 2 tight 90s with a 45 degree downturn. I pieced one together and can hopefully snoop around oriellys tomorrow. You guys have any suggestions for an application? 20241026_160812.jpg 20241026_160804.jpg
  2. Years ago I purchased 2 flexible heater hoses for a VW bug, they come in handy to use as a template for getting the shape of the upper & lower radiator hoses for a V8 or 6 cylinder,they will hold their shape while you are looking for the correct hose at the parts house. HRP
  3. Phil P
    Phil P
    Lots of pictures with dimensions in this catalogue: dayco radiator hose catalogue pdf
    Phil
    Tow Truck Tom and lumpy 63 like this.
  4. choptop40
    choptop40
    If you get stuck...1 3/4 copper 90 degree and 45 degree elbows will get it done
    bobss396, oldsmobum and leon bee like this.
  5. You're on the right track..... If you've got it, you just have to search the racks. Hopefully they let you hunt.....
    lumpy 63 likes this.
  6. lumpy 63
    lumpy 63
    It would be easy if the aftermarket radiator didn't have a weird angle on the lower outlet...I could chop it off and weld it on straight but I'm trying to avoid that. I was just hoping one of you guys would have a lightbulb go off say Hey Lumpy that looks like a " insert make and model here" lower hose. Here's a tip for an 1 1/2 " upper hose... 1970-72 Monte Carlo, it's about 8 feet long and has several bends. Theres a section in there for everyone:p
    67drake, Algoma56, mohr hp and 2 others like this.
  7. BJR
    BJR
    You could take a small section of exhaust tube that fits inside of the hose, some clamps, and use what you already have.
    Kevin Ardinger likes this.
  8. rockable
    rockable
    Take a small piece of SS exhaust pipe that fits the i.d. and put at least 4 tack welds around the perimeter of each side. 2 hose clamps and you're done.
    Kevin Ardinger and lumpy 63 like this.
  9. nochop
    nochop
    from norcal
  10. but I'd weld a small bead on the pipe so the hose stays on with the clamps.
    done this many times.
  11. lumpy 63
    lumpy 63
    Those are all viable...And yes I've done it in a pinch before. Hopefully tomorrow I will find a hose I can use. I'm trying to make it as clean as possible.
    31 B'ville and Truckdoctor Andy like this.
  12. nochop
    nochop
    from norcal
    That link I provided has small length stainless tube available with stainless 45’s and 90’s as well
  13. Last edited: Oct 26, 2024
    RodStRace, lumpy 63 and nochop like this.
  14. lumpy 63
    lumpy 63
    I tried... It would be nice If I could break it down to just 1 3/4" hose ID sizes....
  15. It's a total time sucking pain in the ass. So you need 1.75 both ends, how long is the hose?.
    Try this one:
  16. lumpy 63
    lumpy 63
    20241026_190722.jpg The most important is the 4" between the 2 90s
    Truckdoctor Andy likes this.
  17. They really don't get the accurate. You get the end IDs and total length, the curves you have to guess by the pics.....that's where Google images and a parts store come in.
    Look at:
    20621
    22541
    23721
  18. lumpy 63
    lumpy 63
    I looked at those #s the bends are too far apart. I appreciate the help. Tomorrow I will search the parts store.
  19. Sometimes it just doesn't work out nicely. I've used a piece of 304 stainless tube to clear a belt (used S.S welding rod as the clamp bead), I used a chunk of 6061 to join hoses on my '41 to get the tight curve I needed. Both didn't look factory, but worked.
    Good luck.
  20. 5window
    5window
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ No No No!
    nochop and Moriarity like this.
  22. 5window
    5window
    So, cobbled together bits and pieces of stainless, copper and silicon tubing with a myriad of hose clamps are okay but smoothly contoured curves of corrugated tubing are not? Didn't understand that in 2005,still don't.
    arse_sidewards likes this.
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’ll repeat, “No No No!” :)
    Moriarity likes this.
  24. Mr48chev
    Phil P beat me to it. https://www.daycoaftermarket.com/wp-content/downloads/HOSE_-_2019_GUIDE.pdf Your scroll finger will get tired before it is over.
  25. 5window
    5window
    OK,why? Dayco makes a rubber corrugated hose, so does Continental. So is it the material or the structure? Both have been around for a long time. Cook-flex is all copper, made in the US and has a lifetime guarantee.
  26. nochop
    nochop
    from norcal
    You can always change the inlet location……
    5window likes this.
  27. mohr hp
    mohr hp
    from Georgia
    IMG_2954.jpeg I like the flex duct idea, but you gotta be gentle with it until you find a good candidate. I keep a few lengths of 1/2" aluminum tubing around for this. Bend to fit the space, write the end dimensions on the ends, and head to the O'reilly or NAPA. Both places have allowed me do it enough times that they just let me rummage through the back without all the dumb questions. Gotta admit, last time, it seems the inventory of usable diameters is way down. Modern stocked hoses are smaller in diameter. And funkier shapes.
  28. brading
    brading
    I just Googled " One Off Radiator Hose Manufacturers " and there are companies over here that make one off's to your specifications., would not think that they are cheap though. Would have thought there were such places in the USA.
  29. rockable
    rockable
    You could also use one of those shrink wrap style black "clamps" and it would be unnoticeable.
    https://www.summitracing.com/parts/edl-8462
    Algoma56 likes this.
  30. I used this on mine, painted it black Screenshot_20241027_071324_Samsung Internet.jpg
    GordonC likes this.
