Projects ONE PIECE AT A TIME ('47 FORD COUPE)
Discussion in 'The Hokey Ass Message Board' started by topher5150, Mar 1, 2017.
  1. topher5150
    topher5150
    I mean there was already a hole in the bottom of the fender might as well put it to good use
  2. topher5150
    topher5150
    Got a few bumpers today
    2 49 Plymouth bumpers, 46 ford front and rear, and a couple 55 Chevy halves.
    brEad, Crusty Chevy, bobss396 and 2 others like this.
  3. topher5150
    topher5150
    I'm going to have to get it bolted up a little better to line things up better....maybe.
    Jim Bouchard, brEad, bobss396 and 3 others like this.
  4. topher5150
    topher5150
    Got the lake pipes hooked up. I will eventually get some mufflers hooked up.... ya know for the wife
    Jim Bouchard, brEad, Thor1 and 2 others like this.
  5. topher5150
    topher5150
  6. topher5150
    topher5150
    Focusing back on the electrical I noticed that the buss for the cig lighter/charge had been clipped by the previous owner. I contacted the company that made it and he said that it just needs another wire running from the pink to that fuse....I guess I'm having a hard time visualizing what's involved.
  7. RICH B
    RICH B
    Take any fuses out of the front that engage that buss bar, release the tabs and pull the buss bar, crimp a wire onto one of the open spaces on the buss bar, snap the buss bar back in place, crimp a terminal on the new wire, snap into the desired socket, and put the fuses back into the panel.
    Thor1 and topher5150 like this.
  8. topher5150
    topher5150
    I think I got this right. The speedo and clock are 42 Ford and the gauges are from an old boat.
    brEad and Thor1 like this.
  9. topher5150
    topher5150
    Feeling motivated, sold some parts and bought a new radiator, got lucky at the junkyard and got a nice driveshaft and shifter linkage. Bleed the brakes get some power steering lines then in theory I should be able to drive it around the yard
    brEad, bobss396, Uribe and 4 others like this.
  10. topher5150
    topher5150
    Another beautiful day in the neighborhood, a balmy -3 this morning.
  11. topher5150
    topher5150
    Looks like I have some adjusting to do on the fenders cuz holy cow.
    brEad, RICH B, Thor1 and 3 others like this.
  12. RICH B
    RICH B
    The radiator mounts, inner fenders, and extensions all bolt up thru the front yoke; wonder if something is bent or tweaked down there. Probably already seen the pictures before; but maybe something will stand out.
    brEad likes this.
  13. bobss396
    bobss396
    Not the same car, but with my '59, from having it so far apart with the radiator support removed and all, we had to loosen a lot and manhandle it back into shape.
    This came about when we were putting the hood back on and it was a tad skewed to one side. How well does the hood line up?
    You may have to do as far back as the firewall to start aligning things. Got any parts leftover? I had some hood support pieces in a box in the trunk. It took a while to see where they went.
    brEad likes this.
  14. topher5150
    topher5150
    So I noticed that part 16141 has a bit of flexibility. I'm thinking a couple of rubber pucks will help center that
  15. topher5150
    topher5150
    That looks a lot better....hope I never have to do that again.
  16. RICH B
    RICH B
    Looks like it fits in there now, and you can go on to the next piece of the puzzle.
  17. topher5150
    topher5150
    ummmm how do you get the buss bar out? I got the prong tool to get them out, but I cant get it to do anything.
  18. RICH B
    RICH B
    Not the best picture; but....
    Retainers on common terminals are the little tab the arrow is pointing at, there is one on each side of the terminal, so 2 tabs to release a single terminal.
    If it is a 4 position buss bar there will be 8 tabs to disengage.
    Need to poke in from the fuse side.
    brEad, topher5150 and Thor1 like this.
  19. topher5150
    topher5150
    That's what I figured...stubborn little son of a gun
  20. topher5150
    topher5150
    That can't be good for my seats... just had a mini hurricane blow through here:(
  21. brEad
    brEad
  22. topher5150
    topher5150
    It was like driving your house through the car-wash. I think they said there was around 9 tornadoes in the area. Everything in my car stayed pretty dry.
    Job hunting getting me down so I finished the trunk, covered the fuel filler hole and cleaned up the Merc taillight opening.
    ....and got the bumper guards in place
  23. topher5150
    topher5150
    Got a little more work done on the trunk floor today. The hole in front of the tank is going to be a little trap door so I don't have to wiggle my fat **** under the car if I need to acces anything.
  24. topher5150
    topher5150
    Got one done. Need to find the correct bracket for the other side
    dwollam, Crusty Chevy and Greenblade like this.
  25. topher5150
    topher5150
    What the heck is going on with this thing? Last September I made a temp set up to start my engine and it fired almost right away and I tried it a few months ago without any issue.
    Today I'm trying to fine tune the timing and it keeps backfiring and cranking super slow. The battery was just under 12v so I have it on the charger right now.
    It's a mid 80s 351w HO all stock
  26. Crusty Chevy
    Crusty Chevy
    corrosion on/in the battery cables/terminals?
  27. topher5150
    topher5150
    no the battery is super clean and new.
    I tried putting a socket on the crank and I had to put a bit of effort on it.
  28. Crusty Chevy
    Crusty Chevy
    Pull the plugs and try again, possibly that storm that you had got some water in there?
  29. topher5150
    topher5150
    I pulled the plugs and they were covered in gas. Got the stater tested and that's all good. Took a few things off the front of the engine and got a ratchet on it better and it turns, but I noticed a ticking noise from the carb. I'll get the battery checked tomorrow. Hoping it's something stupid
  30. topher5150
    topher5150
    Ok update #2...starter tested good, the battery tested good, but when I brought it in he quick hooked it up and said the batt was completly dead. Not sure how that works when I had 11v on it a couple of days ago.
