Folks Of Interest Thank you Scott aka RMR&C
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Oct 27, 2024.
  1. iwanaflattie
    iwanaflattie
    I want to publicly thank Scott for helping me out.
    I found a flathead welder in Big Fork MT and I had to have it.
    I asked Scott to pick it up for me and hold it til I had time to pick it up.
    He didn't only did that but also helped me and let me used his shop to get ready for my 1000 mile trip.
    This isone of the many times he's helped me out.
    First time he basically gave me a gmc bellhousing/flywheel and took it to boneville where we met.
    Thanks again @RMR&C
  2. iwanaflattie
    iwanaflattie
  3. Jalopy Joker
    Jalopy Joker
  4. chevy57dude
    chevy57dude
    Top to bottom, that is one kick *** unit! Not a modern part on it. Beautiful. Please show pics of the gauges.
  5. SPEC
    SPEC
  6. patsurf
    patsurf
    chryslerfan55, clem, jet996 and 4 others like this.
  7. iwanaflattie
    iwanaflattie
  8. dwollam
    dwollam
    Nice! Reminds me of my 1940 Ford flatty air compressor!
    Dave
    chryslerfan55 and Sharpone like this.
  9. iwanaflattie
    iwanaflattie
    Pics or it didn't happen
  10. Speccie
    Speccie
    Good man Scott...
    Sharpone likes this.
  11. RMR&C
    RMR&C
    from NW Montana
    You are very welcome Seth! That's what friends are for, I know you would do the same for me.
    Safe travels on your trip home!
  12. Now, that is a WELDER!
  13. catdad49
    catdad49
  14. williebill
    williebill
    Very cool! The welder AND the story of how it all happened. Good people make stuff happen.
  15. b-bop
    b-bop
    I second that. Scott is an awesome dude!
  16. iwanaflattie
    iwanaflattie
    I played with the welder yesterday.
    The flathead spins free and fast with a 12v battery but it doesn't want to fire..
    I jumped the + wire on the coil but it does nothing..
    Would this flathead be 12v negative system?
  17. TrailerTrashToo
    TrailerTrashToo
    Ford was 6 Volt positive ground back in the flathead era. Check the distributor points, both for corrosion and the proper gap. Also trace all the primary ignition wires and verify the voltage (i.e, at the ignition switch, coil terminal and distributor). Also possible that the condenser has failed after all these years.
    Russ
  18. Wow ... I mean WOW :eek:
    With all the moaning on this site about cracked flathead blocks, to the point of some "jokingly" suggesting all flathead blocks left the factory with cracks, there are going to be a LOT of happy people once they become aware that there is such a thing as a flathead welder out there.
    You sir, stand to make a LOT of money from the beast. Congrats ;)
    Hmmmm, a crack filler huh? Your name isn't Richard is it? :eek:
  19. 51504bat
    51504bat
    Now you just need a compressor that uses a flathead V8 running on 4 cylinders and using the other 4 as a compressor.:cool:
  20. iwanaflattie
    iwanaflattie
    Like a I need another hole in my head.
    Thanks
  21. iwanaflattie
    iwanaflattie
    Scott came through again,,helped me out with a nose trim for my project!!
    Scott,you're te MAN
  22. RMR&C
    RMR&C
    from NW Montana
    Happy to help, Seth. I enjoy watching your builds!
  23. ronzmtrwrx
    ronzmtrwrx
    Good friends are priceless.
    RMR&C and iwanaflattie like this.
  24. dwollam
    dwollam
    Only took me a little over a year but here are pics I took today for you Seth!
    Merry Christmas!
    chryslerfan55 and RMR&C like this.
  25. iwanaflattie
    iwanaflattie
    Man that's a cool set up,,sad to see it out in the pasture..
    Is that a Cadillac flat head?
  26. dwollam
    dwollam
    No, it is a 1940 Ford. It runs great. It's not in the pasture, just behind my shop with several thousand pounds of antique car parts! It's 4 cylinders gas and 4 cylinders air. 1 barrel carb and the 2nd air filter is the air intake for compressor. The tube frame is also the gas tank! It also has suspension of sorts. It was used by a fella that made sandblasted wood signs until he finally bought a modern commercial compressor. I used to tow it behind my '40 Ford
    Tudor to cruise nights and fire it up. Very short straight pipes sticking straight up. REALLY loud! The tin cans cover the pipes.
    Dave
    RMR&C and chryslerfan55 like this.
  27. Needs an Ardun conversion. Hehe.
    downlojoe33 likes this.
  28. 51504bat
    51504bat
    See post #20
