Anybody have a link to a operators manual that I can print? Searched the web with no luck!! Thanks Sent from my iPhone using The H.A.M.B. mobile app
That BST manual say the Model "Y" is just for 6 volt. And the Model BST is for 6 or 12 volt. It also has a separate plug in for 6 or 12 volt. I do not understand why the separate inputs. Do they have different shuts for the 6 and 12 volt? Why would the 6 volt shunt not also work and give the correct amp reading for 12 volt? /
Hi: I've been looking for a SUN manual for the BST model. The only one I came across was a post on Nov 16, 2018 from you (24riverview) If you still have the scan will you send me a copy? Thank You very much.....Pops Otto
