Hot Rods Big Daddy's 55 2 door wagon gasser
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 1, 2024.
  1. chevy57dude
    chevy57dude
    I was looking hard to see if they were .030 stamped. Like aftermarket would have, ala TRW.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    chryslerfan55 and Sharpone like this.
  3. Lloyd's paint & glass
    Yeah it's steel.
  4. Lloyd's paint & glass
    I can't do it lol, no it's cast. Zero ridge, turns good.
  5. 427 sleeper
    427 sleeper
    That's the plug that usually leaks after the machine shop replaces it with a pipe plug and you forget to check if it's tight before you put the head's on! :oops:
    brigrat, porkshop, badshifter and 7 others like this.
  6. lumpy 63
    lumpy 63
    Johnny , some early small blocks had drive in galley plugs.
  7. Lloyd's paint & glass
    How much should I have paid for it? Pulled a main cap and a rod cap, looked great
  8. blue 49
    blue 49
    from Iowa
    Refering to the road draft tube boss? I've seen a block at a machine shop that had the un-bored casting boss.
    Gary
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If your happy with what you payed then that’s all that matters.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The boss for a road draft tube.
    swade41, chryslerfan55 and Sharpone like this.
  11. Lloyd's paint & glass
    Well of course, but i have no clue what the short block is worth.
  12. Sharpone
    Sharpone
    $50.00 but I’ll give ya a hundred:p
    Dan
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The West Coast market is nut’s. They want a G or more.
  14. Lloyd's paint & glass
    Oh i did good then.
  15. lumpy 63
    lumpy 63
    Only 1968 blocks seem to have the blank boss
  16. Lloyd's paint & glass
    So the pistons aren't stock?
    Sharpone likes this.
  17. lumpy 63
    lumpy 63
    Lloyd I was just talking about the unmachined boss on the back of the block where the road draft tube would go. My guess is due to the fact it has a cast crank that someone added those pistons in its past. Not a bad thing , I would freshen it and run it. Large journal 327s are pretty rare , 2 years only.
  18. Lloyd's paint & glass
    Yeah i knew that's what you guys were talking about. I threw my question in at the wrong time lmao! That's what I'm thinking, honed, tanked, freeze plugs and cam bearings, throw it back together and wait on some heads. And something to put it in lol
  19. swade41
    swade41
    from Buffalo,NY
    That's a nice little 327, one of the local racers has this treefiddy I was thinking about for my 57 pickup
    But I do have that 11-1 short block already with a bit more cam in it, decisions ugh
  20. chevy57dude
    chevy57dude
    Used to be, engines were a dollar per cubic inch on the used market.
    Motorcycles were a buck per cc, that's how we did it.
    Lloyd, I thought you had a set of SBC heads for sale. (?)
    chryslerfan55, porkshop and Sharpone like this.
  21. Lloyd's paint & glass
    No sir I have a set of 781 big block heads for sale. Actually an entire 454, I'll take $500 :D I have $1000 in it
  22. Lloyd's paint & glass
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    So is it safe to say GM did not redesign the block for larger main caps as well as removing extra material from the line bore? IMG_3280.jpeg
  24. Fordors
    Fordors
    Not necessarily, they may have changed the cores for the bottom end of the block and done extensive reliability testing before introducing the LJ production block. The revision eliminating the draft tube hole just came later.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    And finally. Is that the block that created the “mythical” 350 with road draft tube? upload_2024-10-28_8-18-31.gif
  26. snoc653
    snoc653
    from Iowa
    Given my fondness of big blocks, I sure wish I was closer. Big blocks are one of those things you just can't have enough of. When you were considering it, it sounded like a decent engine.
  27. DDDenny
    I'm not a big block guy but if it had these M/T rocker covers on it instead of those $%&#@! Moroso covers I could be swayed to go over to the dark side.:p
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    I have this L79 68 dated engine with a road draft tube opening. Maybe because it is a CE over the counter engine? IMG_1959.jpeg IMG_1958.jpeg IMG_1957.jpeg IMG_1955.jpeg
  29. ididntdoit1960
    ididntdoit1960
    from Western MA
    1967 Camaro 350 - Ive had one and yes, it had a road draft tube and chrome 283 style valve covers
    Johnny Gee likes this.
  30. ididntdoit1960
    ididntdoit1960
    from Western MA
