Projects 1951 Ford Shoebox build
Discussion in 'Traditional Customs' started by Crenninger, Oct 29, 2023.
  1. Crenninger
    Crenninger
    thank you! for now just getting it running and then ill work more as i go. a running car is a motivating car :)
    Jacksmith likes this.
  2. I expect you will have the only one at the show, I like it so far.
  3. BJR
    BJR
    So how did you cut the windshield to fit the chop?
  4. Nice progress since the first post a year ago.
  5. Crenninger
    Crenninger
    pretty much. i never see shoebox out here int he wild.
    daylatedollarshort likes this.
  6. Crenninger
    Crenninger
    i had a glass guy come out and take measurements. he cut and sanded down the class to make it fit. THO he did break one side that he then remade
    BJR likes this.
  7. Crenninger
    Crenninger
    thank you. ill have more hopefully next weekend. i should have the driveshaft done by then. and start wiring which that part scares me lol
    Jacksmith, Okie Pete and pprather like this.
  8. Crenninger
    Crenninger
    Well.... headers clear gearbox.... new issue lowered car and tie rods are in the way. Need to see how to route exhaust pipe
    Okie Pete likes this.
  9. Crenninger
    Crenninger
    Well small thing done today, The previous owner welded up the gas door and i dude a crude job... so i cut it it all out and replaced with new the gas door :p i was debating on using a mustang gas tank but my trunk floor has no rust and gas tank was good, so i didnt want to cut it out.
    not bad to self taught welding
  10. You might rob a remote oil filter setup from a 4wd S10/blazer to aid in clearance
    Jacksmith and Crenninger like this.
  11. Crenninger
    Crenninger
    oohh i didnt think of that
    The Chevy Pope likes this.
  12. When I looked at your pics my first thought was with as tight as fit was on the oil filter I wouldn't wanna change the oil lol. And I used to mess with s10s so I have a memory bank of parts lol. Added perk is it'll slightly increase the oil capacity helping the oil stay cleaner and a touch cooler. Also should you so choose you could plumb an oil cooler inline. Those actually help a lot in a hot rod
    Outback likes this.
  13. Jacksmith
    Jacksmith
    from Aridzona
    Yeah, on my '49 I used a Moroso remote filter mounted off the firewall... solved a lot of issues.
    Outback and The Chevy Pope like this.
  14. Crenninger
    Crenninger
    Well.. got a rusted patch replaced.... tho still learning how to weld by reading books and youtube. i cant for the life or me figure out why I'm burning wholes... or cracking. I was told to much heat but I have it where the settings suggested. Any ideas?
    .023 wire
    80/20 argon
    16gauge steel
  15. Jacksmith
    Jacksmith
    from Aridzona
    Wire feed rate vs. "heat" setting must be in sinc.
  16. Crenninger
    Crenninger
    if i understand... lower voltage lower wire speed?
  17. Kosmos55
    Kosmos55
    In my experience, rust repair is more about technique than welder settings. It takes time and clean steel.
    guthriesmith and Jacksmith like this.
  18. Jacksmith
    Jacksmith
    from Aridzona
    To a certain extent... As mentioned above, cleanliness is essential for a good weld.
    Rusted metal tends to be thinner in places, hence the burn through. Minor adjustments are often needed as needed. When the metal is rusted, it needs to be completely replaced in that area for success.
  19. Crenninger
    Crenninger
    Well I cleaned the metal and wired wheeles the back the welds came out alot better.
    Still by no means perfect, but way better then a rusted hole.
    Okie Pete, Greenblade and Jacksmith like this.
  20. Jacksmith
    Jacksmith
    from Aridzona
    Cool beans... experiment with less/more wire speed as well as less/more power to get just the right result. Practice is the only way to learn. You'll get it!
    Outback and Greenblade like this.
  21. Crenninger
    Crenninger
    20241112_181551.jpg hood, fenders, innter fenders, grill. All bolted up.
    I ended up changing water pumps to a short pump for more clearance!. Getting close to getting her running 20241113_181724.jpg
  22. Crenninger
    Crenninger
    Well... new problem again.. I had to use spacers to get the rad moved forward.
    The description claims it fits but... nope
    Now I need to find a low profile rad fan thickness about 2.5" total to make work
  23. Crenninger
    Crenninger
  24. UPDATE: I RECENTLY BOUGHT THE WEBSITE NAME, "www.49fordcoupe.com"
  25. manyolcars
    manyolcars
    The 49 was a first try at making a modern Ford and needed to be improved. The 50 was advertised as improved in 50 ways. You may want to look at a 50 to see what the factory did to make it better
    bobss396 likes this.
