TOWMTOR - Hydraulic Cylinder Help
Discussion in 'The Antiquated' started by dvdkea, Oct 30, 2024.
  1. dvdkea
    dvdkea
    Hello all. I'm new here and have already found a lot of useful information. I have a 1956 TOWMOTOR LT 460 forklift. I'm planning on removing the lift cylinder and replacing all the seals. I believe the lift cylinder is a "Tripple Action" type. One piston rod comes out the bottom, and two rods come out the top. I am looking for guidance on the dis-***embly process for this type of lift cylinder. I brought it to a local hydraulic shop, and they don't want to service it. So, it looks like I am on my own to figure it out.
    Any advice is greatly appreciated.
    down-the-road likes this.
  2. Sky Six
    Sky Six
    from Arizona
    Send me a picture of the cylinder.
    Use the PM feature.
    tractorguy likes this.
  3. dvdkea
    dvdkea
    I dont see the pm feature...
  4. dvdkea
    dvdkea
    The upper gland nut is removed. But, from what I understand, there will also be inner seals on this type of cylinder?
  5. Sky Six
    Sky Six
    from Arizona
    it's the little envelope right next to the like ****on.
  6. dvdkea
    dvdkea
    I don't see that option. maybe because I'm new? I can text you pictures if you want. my mobile number is 518 727 7624
  7. Sky Six
    Sky Six
    from Arizona
    you have to remove the castellated nut. There are seals in there and also on the piston. One you pull the shaft out; you will need to look at the barrel sides and the piston. you may have to hone to clean. It's a single stage cylinder so its easy
    Replace all of the seals and "O" rings.
  8. Sky Six
    Sky Six
    from Arizona
    at the top of the page on the right are three little icons: a man, an envelope, and a lightning bolt. The envelope is the PM.
  9. dvdkea
    dvdkea
    Thank you. it is considered a single stage even though it has 3 individual pistons? One that comes out of the bottom, and the two you see in the picture, come out of the top?
  10. Sky Six
    Sky Six
    from Arizona
    The piston is at the end of the barrel, at the top is called the packing gland. Single action is power up and gravity down, double action is power both ways.
    Single stage is just one rod and multistage is multiple rods.
  11. dvdkea
    dvdkea
    Got it, thanks. It seems pretty simple to take it apart then. Simply slide the pistons out. I'm not sure why the hydraulic shop I brought it to won't do that.
  12. Okie Pete
    Okie Pete
    I’d look for another hydraulic shop. Don’t know where you’re at but there’s 2 in my area . But only one I’d recommend
    SS327 and tractorguy like this.
  13. You might also contact a farm implement repair shop...
