Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. No one has mentioned the tank hold down you came up with, but it looks like it will stress the hell out of the tank seam causing a leak over a period of time and use. I only bring this up since that thin sheet metal it is made from does not look structural, it is just to cap off the ends of the tank. I could have sworn that style tank uses straps to keep it planted. If I'm incorrect, then you can disregard my paranoia. We have seen so many gas fires on this forum and I would like to not see that with your dream car.
  2. The 39 guy
    The 39 guy
    Pocket Nick brought up a good point there Joey. A pair of straps would be a better option for mounting the gas tank. Some rubber between the tank and straps would also be something to consider.
    41 GMC K-18 and Dick Stevens like this.
  3. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Nick, to be totally honest I have no idea because I’ve never done this before. Here’s how they had it on their site, so I was basing it off that?
    I’m happy to run straps—maybe I’ll make them?
  4. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    If not br***, then what?
    41 GMC K-18 and Six Ball like this.
  5. RodStRace
    RodStRace
    Think of br*** AND aluminum as soft, malleable metals that form fit.
    Think peanut ****er and jelly and trying to separate them after they are smooshed together.
    I'd go with a steel fitting.
  6. Silva
    Silva
    NPT fittings are available in stainless steel, if your so inclined...
    Six Ball likes this.
  7. Six Ball
    Six Ball
    from Nevada
    Cool that the cotters found their way home back to the Bay!
    41 GMC K-18 and So Cal Brian B like this.
  8. 31Apickup
    31Apickup
    Don’t use stainless in aluminum.
  9. Beanscoot
    Beanscoot
    I think the worry over br*** fittings in aluminum is over rated. Ford used br*** fuel inlet fittings on its aluminum body carbs for decades and I didn't see any problems.
  10. NealinCA
    NealinCA
    tr_rodder, BigJoeArt, rpm56 and 6 others like this.
  11. Tim
    Tim
    from KCMO
    I agree adding straps to your existing tank mount. In my head I’m seeing a sorta cylinder shape, sloshing gas and San Francisco hills. That’s a lot of rocking. Straps would be peace of mind at minimum
  12. Six Ball
    Six Ball
    from Nevada
    I've used br*** fittings in aluminum stuff for 60 + years with no problems with the ones I put together. I have had trouble getting old ***emblies apart. Head gaskets with copper seals on aluminum head has caused problems. Just look at the water p***ages on old heads.
  13. gimpyshotrods
    gimpyshotrods
    I have installed that exact tank, with that exact mounting methodology, going as far back as 12-years-ago.
    None have had any issues.
  14. denis4x4
    denis4x4
    from Colorado
    Go to a thrift store and buy a couple of leather belts to go under the metal straps. This set up is 24 years old.
  15. Looking at the picture it seems it should be ok since that is how it is advertised to work and you also have a real world testimony using your method. There are a pair of raised sections, one by the filler and the other pair right after the sending unit, that is where the tank straps could go. Seems like they gave you a few options to secure it. My only experience with tanks Inc is with an off topic El Camino. Carry on.
  16. Silva
    Silva
    I get your point, However I've used stainless in aluminum with antiseize to mitigate dissimilar metal corrosion. I've also used br*** in aluminum with teflon paste and zero issues...
    Either method is fine.
    41 GMC K-18, warbird1 and Six Ball like this.
  17. Hitchhiker
    Hitchhiker
    Like Neal said. All the old ones ive taken apart had br*** fittings.
    I've never seen an old stainless one.
    Since joey is building a period correct car, it makes sense that he should use br*** fittings. End of discussion.
  18. Six Ball
    Six Ball
    from Nevada
    I bet it is not the end of the discussion. :)
  19. Hitchhiker
    Hitchhiker
    People can talk all they want, but I bet it gets br*** fittings.
  20. Tim
    Tim
    from KCMO
    I think he’s gonna get a bag of bugles and stick a few in there having confused br*** with trumpets and trumpets with bugles.
    no word on if Teflon tape will be involved.
    chlsnk, Outback, ZerroHalfcup and 3 others like this.
  21. Hitchhiker
    Hitchhiker
    Did someone say Bugles? I used to put them on my fingers like claws. Unfortunately, I out grew them years ago.
    They need to make Bugles in adult sizes.
  22. Tim
    Tim
    from KCMO
    Lol
  23. Tim
    Tim
    from KCMO
    I’m a bit of a problem solver myself. Here ya go Matt. Untitled_Artwork.jpeg They went with giant sized because sausage finger size tested poorly with marketing focus groups
  24. Six Ball
    Six Ball
    from Nevada
    They need to make them big enough to fit our heads.
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks everyone for the continued support! Remember the cheese Bugles? Those were the best.
    Over the weekend, I was able to take some time to turn some wrenches on the ol' A-V8.
    The main task? Install the new radiator and make everything else fit. Back when I was looking at the car mocked up, it came to my attention that the radiator was a little bit too tall. Per my measurements, it was about 5/8 of an inch. Being the traditional hot rodder that I am, I figured I could have just left it, adjusted the support rod mounting position, and moved on with my life. But when the thought of having an uphill hood came around, I knew that wasn't going to fly. So, after a phone call to Johnson's (formerly Walker) and a major investment, my new radiator was on its way for Alabama.
  26. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Like a novice, I figured the shorter radiator would just bolt right in. Yet when I set it into position, I found that nothing lined up. I spent part of Saturday and part of Sunday making a new front brake line, t******* the grille shell, and modifying the radiator support rods.
    Mocked up and it's already looking better.
    Backyard mechanic, defined.
    Doodlebug.
    What's that quote about restoring a car versus cutting it up?
    It was dark by the time I wrapped things up, but I was happy with how it all turned out.
  27. RodStRace
    RodStRace
    I watched a couple videos touring Johnson's. They seem to be good folks putting out a quality product for the varied desires of car builders. Yeah, it's not cheap but they are one of those places that are doing things right. I hope the purchase experience mirrors that.
    That 5/8 inch and fixing it is what makes the difference between a car and a real rod. But you knew that.
  28. Tim
    Tim
    from KCMO
    One of those things that you would have hated and *****ed about the whole time you had the car together, but once it’s together on the road it’s so much harder to take it back apart and fix it right.
    it ****s paying new radiator $$$$ but if it’s the right one you’ll get it in there and never again think about the money it cost.
    looks great. And good illustration of how litterally nothing bolts in unless you make both half’s and some times the bolt.
    OFT, Outback, The 39 guy and 2 others like this.
  29. 41 GMC K-18
    41 GMC K-18
    As cool as this car is and its evolution, I always get a kick out of the details on the walls of this tiny garage. The vintage dustpan that has the embossed letters on it, with that distinctive wire handle, so far with web searches, that relic hasn't shown up!
    So fess up amigo, where did it come from, was it a find at a swap-meet back east?
    I am also curious about the radio hanging on the pegboard, what brand is it?
    I will say I am very impressed with the custom NEON sign.
    I have a Mobile Pegasus NEON sign in my office, the cool thing about NEON is, it never goes out of style.
    Keep at it kid, you are making great progress!
    Thanks from Dennis.
  30. Tim
    Tim
    from KCMO
