Technical Trifive Gasser Steering Boxes & Arms.
Discussion in 'The Hokey Ass Message Board' started by brigrat, Oct 31, 2024.
  1. brigrat
    brigrat
    from Wa.St.
    Every time I have a question on anything you guys have come threw & saved me alot of time, money and frustration, thanks. Got '57 Chevy truck axle ready to mock up under my '57 Chevy 150, drilled axle holes, "fitted" '61 Corvette drum brakes to truck spindles, still need to drill backing plates. Question, need info on what type of steering box and arm to run. Remember pics are a plus! Thanks!
  2. TRAVLR
    TRAVLR
    Are you planning to move the steering in front of the axle since you are planning to run a BBC? It will give you more clearance, especially if you are setting the engine back any.
    In wouldn't use anything smaller than a Saginaw 525 box. I've heard of some guys running a reversed Vega box, but I think they are too small for a heavy car like a tri five chevy... especially with a BBC.
    I know my car isn't a tri five, but if you want me to send pictures of my steering setup. I will. I'm using a 525 box and cross steering with factory style tie rod ends (no heim joints) and factory end links on the spindles. The only real difference is I am running a tube axle.
    brigrat and Unkl Ian like this.
  3. 1971BB427
    1971BB427
    from Oregon
    I'd use a 525 box myself and mount it in front of the axle with pitman arm pointing back. You'll likely need to grind the alignment off the pitman arm to turn it 180 degrees, but that's easily done with a small round file.
    Of course the tie rod will go behind the axle, but drag link will be in front, and a steering arm pointed forward off the top side of the spindle.
    Here's the setup I have on my '39 Chev:
    mad mikey and brigrat like this.
  4. brigrat
    brigrat
    from Wa.St.
    I only use the Vega box on Deuces and even that it has to be a quality one. I use 525 on '35-'40's. Was hoping to adapt what I have laying around like a '57 Chevy truck & p***. car box, but if there's a handful of good reasons not to I will listen! I thought if going the BBC that there would be enough real estate to get by? Looks like I need to mock up the front suspension & sub frame first.
    mad mikey and Unkl Ian like this.
  5. TRAVLR
    TRAVLR
    One of the advantages of having the steering box in front of the axle is so the drag link can be parallel going to the p***enger spindle without having to worry about oil pan clearance.
    I'll try to post some pictures of my set up on here tomorrow. Unfortunately I won't be home till after dark today.
    1971BB427 likes this.
  6. brigrat
    brigrat
    from Wa.St.
    First choice is to keep in front of the front suspension area clutter free if possible, but realize modifications will have to be made. Looks like I am jumping the gun a little. First rule of hot rod building is mount what has to go where it goes and modify to fit the surrounding parts. Will be back after the stub frame, axle & springs are mocked up under the fenders.
  7. squirrel
    if you want to use cross steer, you could probably use the original steering gear. Drag link to oil pan clearance might be tight.
    427 sleeper and mad mikey like this.
  8. mad mikey
    mad mikey
    Correct, If the clearance is to close, the oil pan can be modified, a lot of guys have successfully done that.
    427 sleeper likes this.
  9. Kerrynzl
    Kerrynzl
    If you're planning on "Cross-steer" look at an Aisin Steering box from a RWD Chrysler Sigma.
    They are available in Power and non-power steering.
    The sector is tall enough so the top of the box sits above the frame [so you can shift the whole box further to the L/H side allowing for a longer drag link ]
    The steering column is also further to the left above the frame allowing for header clearance
    I trusted the Sigma Box at 176 mph in my race car.
    Here is a power steering variant I adapted into a C3 Corvette
    The Pitman arm can be clocked 360° on these boxes.
    The Sigma box is also available in Starions and L200 /D50 pickups
    [also a C3 Corvette box would also be a good choice]
    vtx1800 and brigrat like this.
  10. 1971BB427
    1971BB427
    from Oregon
    The issue with going with a stock box, or a behind the axle box is pan clearance, and drag link angle. If you want to keep the box behind the axle it's going to mean you'll have a steep drag link angle which will create bump steer issues. Bump steer is scary as Hell when it happens.
    By going up front you can get the drag link almost perfectly level, unless you go nuts with the frontend height. Zero bump steer, and no clearance issues anywhere. And the bonus is no heat from headers affecting the steering box.
    Just Gary and brigrat like this.
  11. brigrat
    brigrat
    from Wa.St.
    My main goal is trying to make it look like it was built in the '50's-'60's, with parts of that era. Keeping it simple and safe, maybe I am dreaming! Already figured out that I better get it all mocked up under fenders with stub frame & BBC mocked up than figure out what can be done. With motor/trans placement, steering, headers, etc. At the most I may run a pan hard bar if not to cluttery looking or in the way of BBC pan. IMG_5440.JPG
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Then stock steering box and set engine back.
    brigrat likes this.
  13. brigrat
    brigrat
    from Wa.St.
    This '57 Truck axle has a stock drop to it as opposed to a "straight" axle so hoping that will give me some free real estate in the BBC pan area.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    This may be stupid on my part, but a first generation Corvette box may work with the steering in this picture. You seemed to have some vette parts there, do you have the steering box? the pitman shaft comes out the side of the box and may just work???
    427 sleeper and brigrat like this.
  15. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^^^^^ Well yes I do & it was sitting 3' away from my axle^^^^
    Ever have so much **** that you forget what **** you have? 1961 C1 Vette, Will give this a look see! Thanks! IMG_5441.JPG
    427 sleeper and Moriarity like this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    How would this work when the pitman arm operates inside the frame vs the outside? IMG_3303.jpeg IMG_3304.jpeg
    Moriarity likes this.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    hmmmmmmm......
  18. brigrat
    brigrat
    from Wa.St.
    Thats what I am trying to figure out now, hoping the steering geometry will work when I mount the pitman arm outside the frame rail ( box upside down). Cross your fingers that when the steering shaft is turned to the right the wheels go right instead of left!
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Will the sector shaft poke thru the frame enough? If so, why not a truck steering box? Just throwing it out there but not a go to for me.
  20. brigrat
    brigrat
    from Wa.St.
    That I don't have for a look see, a truck box. This isn't going to be doing any road course. was wondering though what the steering ratio of a truck verses a p***. car '57 would be.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    @brigrat do I see a vin tag on that steering column? where is the car that it came from???
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    Sorry man, no big wheels
  23. brigrat
    brigrat
    from Wa.St.
    You asked!
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    Shouldn’t that vin tag be put on the car?
  25. stewartwhite
    stewartwhite
    55 Frame with 1958 3100 axle, custom springs and Borgeson 525 box.
    [​IMG] [​IMG]
  26. Kerrynzl
    Kerrynzl
    Early Land Cruiser and Hilux [Straight axle] 4 x 4 boxes are correct for side steer.
    The Corvette box with the geometry shown above will need to be reversed [The third arm in that drawing is opposite orientation to the steering arm "fork" on conventional side steer]
    When the drag link goes forward it steers right, on a normal side steer when the drag link goes forward it steers left.
    brigrat and Johnny Gee like this.
  27. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Is it me or my mind losing it. Is that axle or parts of it-in funny. Seems to me the axle should decapitate the chicken, before tie rod.
  28. 1971BB427
    1971BB427
    from Oregon
    Appears to have the tie rod up front, so I hope the steering arms are outside the kingpins to have the correct Ackerman angle? It's much easier to attain correct angles with the tierod behind, but it can be done in front if your wheels have enough offset to not hit the steering arms.
  29. 1971BB427
    1971BB427
    from Oregon
    Not a period correct steering box, but the old late 70's Ford RangerMazda PU boxes are fantastic. They sit outside the frame rails, and are very tall so easier to get a flat drag link angle with. I found one of these boxes at a local wrecking yard when I was building my '63 Falcon g***er and it worked fantastic. Did it front side steering, and being outside the frame rail it didn't interfere with anything. The box part offsets over the top of the frame so connecting a DD shaft and joint to it is a nice straight shot. No clearance issues at all, even with a BBC in my old Falcon.
    brigrat likes this.
  30. brigrat
    brigrat
    from Wa.St.
    "Moriarity, post: 15406779, member: 218"] Shouldn’t that vin tag be put on the car?
    On the To Do list it's #17 I will get to it!
    seb fontana and Moriarity like this.
