Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. atch
    atch
    That body may or may not be considered "pristine", but it looks pretty darned good to me. Most folks (me included) would feel very lucky to have something that nice to start with.
  2. swade41
    swade41
    from Buffalo,NY
    Damn shiny satin paint, I might have to scotchbright it next spring to get it to match better
    Now this looks like what I envisioned yrs back, window viewing of 60's top fuel dual breather goodness
  3. Kosmos55
    Kosmos55
    Finished my headlights. Slightly tunneled 7" to 5.75" conversion.
  4. Got the busted up outer panel glued back together. Doing a glass check.
    Looks ok
    has a couple layers of mat underneath. Made a backer piece for each side along the cut to screw it down to. About to glue this piece in so it can set up.
    Left the center style line in just to line things up. It has cracks in the gel and I’ll grind those out after its glued in The outer will get a couple layers of mat plus an extra narrow strip along the splice
  5. lo c dan
    lo c dan
    Workin' on shock ladder bar combo mount. .
    combo bracket 1.jpeg combo bracket 2.jpeg combo bracket 3.jpeg combo bracket 4 (1).jpeg
  6. swade41
    swade41
    from Buffalo,NY
    Got my grill squeezed in without messing up the paint
    Real happy with how the front of the hood sides turned out
    Screenshot_20241101_183836_Gallery.jpg Screenshot_20241101_190957_Gallery.jpg 20241101_174017.jpg 20241101_174037.jpg
    And the script piece under the tailgate turned out pretty good
  7. lumpy 63
    lumpy 63
    IMG_20241101_191302.jpg IMG_20241101_191255.jpg After a couple of months of searching found a speedo pod for the Tempest to replace the sun fried unit that came with the car. Bonus is it's a 61 which is made of aluminum.
  8. 1940Willys
    1940Willys
    Is that rattle can Rustoleum Satin Black?
    chryslerfan55, mad mikey and swade41 like this.
  9. Good find! I can’t wait to see this beast when you are finished!
    mad mikey and lumpy 63 like this.
  10. swade41
    swade41
    from Buffalo,NY
    Krylon, that's what I used on the front fenders last time, it matched really good
    This time it looks more glossy, Rustoleum's satin black is real shiny now with it's new formula
  11. 402BOSSMAN
    402BOSSMAN
    Got asked to make a one off throttle body for a friend that runs a Turbo VW. Made this from 5-1/4" aluminum bar stock. Layout uses Hilborn style shaft, blade, arms, and stops. Need to TIG weld a V Band flang to the bottom end of it yet. Made this on my vertical mill.
  12. -Brent-
    -Brent-
    Sidetracking myself by prepping parts for yellow cadmium plating. 1st batch sent, today.
  13. chevyfordman
    chevyfordman
    A friend needed a piece made that was missing for his six carb set-up. IMG_2639.jpeg
  14. pila38
    pila38
    Haven’t updated on this thread in a while, but my build thread has some updated pics. Currently working on refreshing the Spalding Flamethrower. IMG_5348.jpeg IMG_5377.jpeg IMG_5389.jpeg IMG_5390.jpeg
  15. lumpy 63
    lumpy 63
    20241102_143846.jpg 20241102_143832.jpg Worked on fabbing engine mounts to put a 289 into a 32 3 window. It's a bit of a chore around the steering box.
  16. chryslerfan55 and lumpy 63 like this.
  17. Kosmos55
    Kosmos55
  18. swade41
    swade41
    from Buffalo,NY
    mad mikey and 427 sleeper like this.
  19. onetrickpony
    onetrickpony
    from Texas
    I've seen an engine eat one of those. The guy took off his air cleaner and spun the wingnut back on the stud so he wouldn't lose it. He then made a pass down the drag strip and the wingnut spun itself off and went right down the wide open carb.
  20. lumpy 63
    lumpy 63
    20241105_085914.jpg 20241105_153737.jpg Cut some housing ends off a junk Chevelle 10 bolt and shortened up a big ol Imapala 12 bolt and turned it into an early Chevy II 12 bolt:cool: will fit the Tempest perfectly.
  21. DDDenny
    I had a real one, they bring big bucks.
    mad mikey, 427 sleeper and lumpy 63 like this.
  22. lumpy 63
    lumpy 63
    My friend Scott has 2... That what I took exact measurements off of. They are like hens teeth.
  23. That is so cool!! Where do you get axles?
    chryslerfan55, mad mikey and lumpy 63 like this.
  24. lumpy 63
    lumpy 63
    Quick performance in Iowa:D
  25. choptop4
    choptop4
    My winter project. Block , fix imperfections, prime , block.
  26. DDDenny
    Early Nova 12 bolt rears were hard to find in the mid 80's when I started looking for one and when you found one they were going for two to three times more money than the garden variety Chevelle, Impala, and Camaro versions, it took a few years to finally find mine and it needed some love as it had one bent axle and the other one had eaten up the hardened bearing surface, the story was it had actually been in a 69 Camaro that slammed a curb during a police chase.
    I was at a Seattle area swap meet and a vendor was there with Nova parts and I mentioned that I was looking for some used 12 bolt axles and he says he had a pair at home in Spokane but didn't bring them because he wasn't sure he wanted to sell them, dig this, they were NOS GM axles.
    After a few phone calls over a six month period he decided to sell them but said they wouldn't be cheap plus I would need to pay the freight from Spokane to Portland, well, hearing that, I was hesitant to ask how much he wanted and when he said $200 bucks plus the stamp I nearly dropped the phone.
    Mailed him a CHECK:eek: and they showed up a week later, arriving in the original GM boxes, I installed them in the housing, rebuilt the brakes and within days had it in my 67.
    I saved the boxes to brag to a friend what I paid as he had been looking for a pair longer than me, and when I called him and told him what I paid I think he too dropped the phone.
  27. F-head
    F-head
  28. My Home State!!! :):):)
