Hot Rods Early Mallory mystery help needed
Discussion in 'The Hokey Ass Message Board' started by Window Licker, Nov 2, 2024.
  1. Window Licker
    Window Licker
    Hey Hamb.
    I'm having a hard time finding any info on this Mallory. Seems that the cam that opens the points has been played with, so a way to confirm this and possibly a points rotor phasing procedure for this seemingly early Mallory for a model A would be helpful. It’s a model Y2 type 11a serial number EMX807. Are point still available for this unit? What is the procedure for installing wires in the cap? I current have the plug wires rigged up to function, but I can find any information on how to make the wires stay in the cap. Can I get a new rotor? Where can I find info on this old bird? IMG_8141.jpeg IMG_8140.jpeg IMG_8143.jpeg IMG_8142.jpeg
  2. squirrel
    If the points are not significantly burned, you can just file them with a points file, and use them again. I put a lot of miles on Mallory distributors and never replaced points.
    11 is for a Model A, as you thought.
    vtx1800, porkshop, Happydaze and 5 others like this.
  3. Window Licker
    Window Licker
    It appears my “rubber seal” is pretty old and dried out, I added oring to pinch the wires -and it seems to sort of work. IMG_8144.jpeg
  4. squirrel
    No, your rubber seal is missing. It's a sheet of rubber with holes in it, with a raised edge around each hole.
    someone tried replacing it with 5 grommets.
    bummer
    (I think the part number for the rubber part is 24012, but good luck finding one) (or 4010 for the whole cap ***embly?)
    RodStRace and chryslerfan55 like this.
  5. Window Licker
    Window Licker
    Yeah that was me. I’m not sure if there is a better way to make this work still.
  6. squirrel
    I added part numbers to my last post. Hard to find that stuff for fours. you can find them for 8 cylinders occasionally
  7. Window Licker
    Window Licker
    There is a rubber seal in that picture matching the part number you said it should be
  8. squirrel
    well, then I guess you're not missing the seal...I just didn't notice that it was there.
    Take it out, look at it closely where the wires go through.
    It might need to be replaced. Or possibly you could add a thin sleeve at each wire for better grip, like heat shrink tube or something
    dmar836 and chryslerfan55 like this.
  9. If that plate just holds the leads from falling out (it looks like the little spikes on the other plate go into the wire /carbon to make contact) , you may be able to silicon or epoxy the leads into the top plate (if you can't find a replacement).
    Window Licker likes this.
  10. Fordors
    Fordors
    I wonder if your cloth covered wires are too small a diameter to work properly with the Mallory cap. The proper ignition wires will be 7mm, or .276 and if there’s clearance at the cap it’s probably there at the rubber too.
    Looking at your photo I see clearance at the insulation.
  11. ClayMart
    ClayMart
    Is there an 8 cylinder Mallory cap that would fit this distributor housing? Maybe you could plug the wires into every other hole, find some rubber plugs to seal the unused holes and run it that way. ***uming that the cap height is the same, uses the same mounting hardware, and matches up properly with the rotor.
    tb33anda3rd likes this.
  12. Zax
    Zax
    squirrel likes this.
  13. tubman
    tubman
    I think whoever commented on the fabric wires being too small in diameter might be on the right track. I use Packard 440 from The Brillman Company on all of my Mallory retro-fits, and everything works fine. Between the way a properly setup Mallory cap grabs the wires and Rajah spark plug terminal snap on the spark plugs, everything is very positive.
    Either throw a calipers on your wires to check them or The Brillman Company makes the improved fabric covered wires as well.
  14. RodStRace
    RodStRace
    Dang I love this place! Vintage aftermarket product question and there are instructions, part numbers, a listing and ***ociated parts help.
    Jim, you are a treasure!
  15. joel
    joel
    Ditto ^^^^^^^
  16. Window Licker
    Window Licker
    I measured the wires vs some others I have laying around. .236 vs .307 I’ll make a new set with the thicker wires, I expect that will solve the looseness.
  17. Fordors
    Fordors
    I mentioned 7mm wires earlier, your .307 wire is 8mm and wasn’t in use when Mallory was producing the two piece caps. If you really want to use the 8mm you will need to open up the holes in the cap.
  18. tubman
    tubman
    It's easier just to get new wires instead of butchering a hard to find Mallory cap. I'll bet a new set of proper plug wires will solve everything.
  19. squirrel
    0.276" is 7mm. Your wires are 6mm.
    so finding some 7mm wire would be a good start
  20. mvee33
    mvee33
    Yes 7 mm wires. Old style Mallory points like yours are very hard to find. But you can replace your old points plate with a later model Mallory dual points plate (Chevy etc.) which are easy to find, rotation on the Chev is opposite to yours but doesn't matter, Mallory made these to go CW & CCW.
    Remove one set of points, use the 4 cyl. rotor and a V8 cap (4004) with stepped rotor terminals, check it rotates cleanly, time points opening to TDC and you are good to go. Centrifugal advance will work, the 2 br*** fittings on the body are for vacuum advance and vacuum wiper hose fittings, a cap gasket will be required if you use these. Good luck.
  21. brjnelson
    brjnelson
    A Mallory 2 piece 8 cyl cap has the wire holes clocked in different than the 4 cyl cap. The 2 hold down screws near the center screw things up.
    You can put a V8 cap on a 4 cyl distrib, BUT the cam that opens the points is not clocked the same, it would fire in between the wire locations.
    Budget36 and ClayMart like this.
  22. mvee33
    mvee33
    BRJNelson, Yes, just changing a 4 cyl. cap for an 8 cyl. cap won't work but there is more to it.
    The rotors locating tab, to fit on the Mallory cam point differently on 4cyl to 8 cyl rotors, also the 4 cyl. rotors distance from the cap carbon brush to the outer edge is longer. Changing to the 8 cyl. points plate as above and using 1 set of points also changes the geometry and clocks the 4 cyl. rotor to a cap terminal (at points just opening) on an 8 cyl. Mallory 4004 cap (with stepped terminals to suit the 4 cyl. rotor) but not a 4 cyl. cap. I have just done this on a 33 Model B.
    Maybe the other points (from a double life) I removed would not clock so well, still playing with the Mallory, but for now my motor runs great.
    Window Licker and ClayMart like this.
  23. 31 Coupe
    31 Coupe
    What about using some adhesive type heat shrink fitted to the leads in just the cap engagement areas.
    That could possibly bring them up to the desired 7mm diameter.
    ClayMart likes this.
  24. patsurf
    patsurf
    c
    could one clock the cap and move the little nub/do without and then it would work??
  25. HEATHEN
    HEATHEN
    from SIDNEY, NY
    The part number for the center pivot point set was 24205 and, yes, they are hard to find today, as they haven't been made for decades.
  26. Window Licker
    Window Licker
    Why not just clock the cam?
  27. patsurf
    patsurf
    prob harder to make the hole for the cam change compared to twisting cap some
  28. Window Licker
    Window Licker
    The points can just presses on, no hole to make
  29. tubman
    tubman
    I would strongly suggest doing whatever is needed to get this distributor working in it's original configuration instead of trying to modify it and possibly ruining it. As "Squirrel" said, "dressing" the points with a file usually works well. It already has the wrong plug wires. In my opinion, redrilling holes, moving the cam on the shaft and twisting things can only result in a bad outcome.
    If it ends up being impossible to fix, then, and only then, consider ****ing with it.
    dmar836 likes this.
