Projects Back from the dead… and better than ever - Model A roadster build
Discussion in 'Traditional Hot Rods' started by Texas36, Nov 4, 2024.
  1. Texas36
    Texas36
    Some of y’all may recognize this pile of parts. Infact I had a build thread all about it here formerly known as “Romeo and Juliet”.
    And as we all know, life can get in the way of the fun stuff and this project was no exception. Between having a child, building a house ourselves, and totaling my car consequently breaking my back; life has REALLY gotten in the way.
    So after some discussion, Juliet has decided that she doesn't want to continue building the car for herself due to lack of time but suggested I keep building it the way I want to hence the all new thread.
    The plan for this car has gone down a few different paths these past couple years and this new path is by far the most drastic, but is the plan that Im most happy with! Stay tuned, Ive got lots of progress to fill y’all in on.
  2. Texas36
    Texas36
    First item on the chopping block. The Yblock. These engines just aren’t in my wheelhouse and freeing up some funds is going to help me progress this car greatly so I struck a deal with a friend that wants it for one of his projects, and now it sits patiently to the side for its day.
    Instead we are going flathead v8. Im way more comfortable working on these engines and i have abundant flathead junk laying around.
  3. Texas36
    Texas36
    When I last left off on the car, I had just cut the rear of the frame off to build a bigger Z. The 6” Z is still in the plans so I decided to get that item checked off the list to get this frame closer to being cut out of the jig. Im also going back to a spring-on-top banjo set up and returning to the original wheel base.
    IMG_4253.jpeg IMG_4431.jpeg IMG_4483.jpeg IMG_4514.jpeg The rear crossmember needed lots and lots of love. I spent close to 6 hours straight with a grinder and welder fixing cracks and previous backyard repairs to make it safe and useable. At least the ugly parts will be hidden..
    dwollam, chryslerfan55, brEad and 8 others like this.
  4. Texas36
    Texas36
    With the rear crossmember square and tacked in, I decided to drop the engine and transmission in and get my mounts figured out. Sadly the old engine mounts for the Y block were too far off so they needed to be cut out.
    IMG_4551.jpeg IMG_4601.jpeg IMG_4679.jpeg IMG_4680.jpeg IMG_4681.jpeg IMG_4684.jpeg
  5. guthriesmith
    guthriesmith
    Man, you have been through a lot lately! Glad to hear you are doing better and able to work on the car. I’ll be following along as you go.
  6. Texas36
    Texas36
    Transmission mount up next. A little unorthodox but I really like the turnout and it’s pretty darn stout. I still need to machine some steel pads and rubber bushings for the ears of the mount to sit on. IMG_4692.jpeg IMG_4698.jpeg IMG_4699.jpeg IMG_4700.jpeg IMG_4760.jpeg
    dwollam, tb33anda3rd, treb11 and 15 others like this.
  7. Texas36
    Texas36
    With both crossmembers in-place I felt good enough to cut the frame out of the jig.
  8. Texas36
    Texas36
    Doing some math and using my model T for reference, I was able to get a good guess on how the frame will sit and got it blocked up into its “finished” position. I had some extra hands so we decided to set the body back on and put the engine and trans back in so I can start getting my firewall tackled and I just gotta say…. This car is turning out so cool! The stance is killer and I really couldn’t be happier with the way things are working out. IMG_4783.jpeg IMG_4766.jpeg IMG_4767.jpeg IMG_4776.jpeg
  9. Texas36
    Texas36
    And that brings everyone up to speed. Im currently getting the firewall pieced back together in my sp**** free time and will post the progress when Im done. Thanks for following along!
    brEad, AHotRod, Outback and 3 others like this.
  10. brokenspoke
    brokenspoke
    Its good to see you back on this, good choice on not using the Y block motor
    Tow Truck Tom and Texas36 like this.
  11. Texas36
    Texas36
    Then I flipped the frame over to finish the underside. I notched the frame at the front crossmember for some spring clearance.
    I decided to run the lever shocks in front like I did on my T, so I got the holes marked and drilled. The “balls” will weld to the wishbones.
    My wife and Daughter are out of town for the next week and a half so my nights are freed up for the hotrod. Going to try to have it all in primer in the next few days. The fab work is just about finished.
  12. Robdski
    Robdski
    Looking real good.
    The boxing plates and trans crossmember worked out great.
    Thanks for the update
    winduptoy, Tow Truck Tom and Texas36 like this.
  13. Texas36
    Texas36
    I realized my axle wasn't holy enough. I fixed that.
  14. Texas36
    Texas36
    Since I pie-cut my wishbones to get my caster correct, I decided to play it safe and make fishplates for them.
    Next I spun down some shock link balls and welded them to the bones.
  15. Texas36
    Texas36
    I bought some 3" diameter aluminum billet to make my engine risers.
    Motor Mount1.jpg Motor Mount2.jpg Motor Mount4.jpg Motor Mount5.jpg Motor Mount3.jpg
    I think it turned out pretty cool for only having basic machining knowledge. I don't claim to be a professional at any of this stuff :D
  16. Texas36
    Texas36
  17. Jeff34
    Jeff34
    Glad you’re back! Bummed that you’re not using the BW transmission. I was following that closely since I’m doing the same thing.
  18. Texas36
    Texas36
    Yeah it was an awesome engine! A buddy of mine is going to put it in his Mercury so it hasnt fully left the family at least.
  19. Texas36
    Texas36
    I cleaned up the frame and put a coat of paint on it. I left out the transmission crossmember for now because I still have to add the mounts for the ‘32 truck pedals to bolt to.
    For those that don’t follow me on instagram, I revealed a couple weeks ago that I’m going to part out my model T and move the drivetrain over to this new frame. I am just about at that point and I’m pretty excited. If everything goes to plan, I should have a roller very soon
  20. Texas36
    Texas36
    Yesterday’s progress.
    My axle is so Holy it has a slight glow to it with the lights off :p I love it.
  21. NoSurf
    NoSurf
  22. Texas36
    Texas36
    Spindles mounted so why not throw the hubs on and make it roll! I still need to re-paint my backing plates. IMG_6823.jpeg
    Im loving the way it sits, Im excited to see it with the engine in and sitting even lower.
    dwollam, mvee33, chlsnk and 16 others like this.
  23. Dave G in Gansevoort
    from Upstate NY
    Nice work. Watching…
    Texas36 and Tow Truck Tom like this.
  24. Texas36
    Texas36
    It took me more time to set up my rotary table and tram in the 3 jaw than it did to drill the holes. Ill use an actual end mill next time for a nicer hole but Im happy. I might not be done with the backing plates just yet, Ive got an idea Im kicking around… IMG_6840.jpeg IMG_6841.jpeg
  25. Texas36
    Texas36
    I had a better idea this morning. In an effort to clean up some of those wonky holes I decided to re-drill the backing plates, this time with an end-mill like I should have from the start, but I wanted to take full advantage of the rotary table since I had it all set up. Slots it is! IMG_6844.jpeg IMG_6847.jpeg IMG_6848.jpeg
  26. panhead_pete
    panhead_pete
    For those that have owned panheads that sure looks like a linkert carb backing plate lol.
  27. Texas36
    Texas36
    I had to google it and holy **** youre right. I will never not see it now :D
    chryslerfan55 and panhead_pete like this.
  28. Texas36
    Texas36
    Ive been doing a lot of boring non-picture-worthy work on the car this past week, but I did get my backing plates painted.
  29. patsurf
    patsurf
    better oil that chain!
    dmar836, NoSurf, 303racer and 4 others like this.
  30. Nailhead A-V8
    Nailhead A-V8
    Nooooo!...she's looking great!... glad you're back on it...having and raising babies is tough work you're looking at about 18-21 yrs. before she can start building cars again lol...in the meantime His & Hers roadsters will do so keep it in one peice!
    chryslerfan55, winduptoy and Texas36 like this.
