Projects Rickybop's 1931 Plymouth 3W Business Coupe build
Discussion in 'The Hokey Ass Message Board' started by Rickybop, Nov 4, 2024.
  1. Rickybop
    Rickybop
    Brought 'er home today.
    Got going early.
    Got back late.
    Tired but happy.
    Hang on tight, old Plymouth.
    You're comin' home with me.
    Made it.
  2. hotrodjack33
    hotrodjack33
    Way to go Ricky. Looks like you've overcome almost everything life has thrown at you lately and came out on top...and with a damn cool hot rod project to boot.
    Congrats buddy.
  3. bubba55
    bubba55
    Well now Brother Flea - looks like Christmas came early for thee - gonna be kinda hard to get that under yer tree - congratulations to ya - did ya curl up inside and sleep in it tonight? Sweet dreams ehh
    Happy fer ya
  4. Stooge
    Stooge
    Oh yeah thats cool! Love that back window! Looking forward to seeing this come together!
    1Nimrod, winduptoy, mad mikey and 4 others like this.
  5. When we moved to San Francisco in 1956. That type Plymouth is the first hot rod that I saw. It was channeled, and had an Oldsmobile engine in it.
    1Nimrod, winduptoy, Tim and 6 others like this.
  6. guthriesmith
    guthriesmith
    Congrats! So…what are your plans for it? You had a long drive to consider already. :D
  7. catdad49
    catdad49
    Looks promising, is it going to get a Hemi!?
    1Nimrod, winduptoy, mad mikey and 3 others like this.
  8. Rickybop
    Rickybop
    G' morning, fellers.
  9. Rickybop
    Rickybop
    Plans.
    I'm thinkin'...
    No major body mods
    No chop
    Full fendered (basically)
    Minus running boards
    Bobbed fenders
    No hood sides
    Hood top part-time
    Relatively high stance
    All black... on black... on black...
    And chrome
    Foe foaty foe-speed
    mostly stock for now
    modifications or a second hotter motor later
    1960s NOS Hurst shifter
    6x2 w/Strombergs
    and/or
    Dual quads
    and/or
    Long-ram
    Fabbed Rickybop-style exhaust manifolds/headers and side pipes
    Vintage Cal Custom finned aluminum valve covers
    Dana 60 rear axle 3.54 posi
    Narrowed 1964 Ford F-150 front axle
    X-member
    Roll bar
    Large dia tube bumpers
    Parallel leaf springs f&r
    Old style ladder bars
    Early Ford steel wheels painted black with black-wall bias-ply tires most of the time
    Chrome lug nuts
    Maybe a spider
    Maybe some Plymouth caps
    Chrome steelies and slicks when I'm racing Don Garlits
    1960s MG bucket seats
    1938 Packard standard steering wheel
    Groovy gl*** gauges glowing green
    1960s NOS Sun tachometer
    ***y necker knob
    A drawer full of shift knobs
    Vintage magnetic plastic Jesus
    ..."driving 90, it's not scary..."
    1957 owner/builder/driver (not NOS)
  10. marfen
    marfen
    from sask
    Built one of these 20 yrs ago. Really stout frame. I ditched all the factory crossmembers and went with triangulated ladders bars, 32 frt cross member, 4" drop axle and boxed it. I had to recess the firewall 4" and there still was lots of leg room. Big cab. Did you get a grill/grill shell which are hard to find? An aftermarket 32 rad fits fine in it.
    catdad49, 1Nimrod, Stogy and 4 others like this.
  11. Rickybop
    Rickybop
    Mr. marfen is right. These Plymouths have a little more interior room than some others of the same era. So the firewall can be moved back if necessary and there would still be enough leg room.
    My preferences have usually leaned toward the radical. As in heavily chopped hi-boys. But I've listened to those who encourage restraint and espouse the virtues and beauty of no chop. And fully fendered. Hood, even. I've also listened to those who say that a car will tell you what it wants to be. That's true. And since I'm lucky enough to get an old car with a whole body, I think maybe I'll take advantage of that. Keep the architecture and the original envelope intact.
    There's a lot to be said for leaving things be. Designers and manufacturers did a lot of work to make sure that all the panels fit together and the lines flow smoothly. We can pie cut and relief cut all we want, it'll never flow as perfectly as in stock configuration. Besides, not chopping the top will probably shorten my build time by about 14 years. And I think an unchopped top looks pretty cool in its own way. Especially when you consider that almost every other hot rod coupe out there is chopped.
    Back away from the Sawzall!
    I'm thinking the young man who would've hot rodded this coupe back in 1965 might not have gotten too sophisticated with modifications to the body, but focused more on the mechanics.
    1Nimrod, catdad49, winduptoy and 11 others like this.
  12. HOTRODPRIMER
    HOTRODPRIMER
    Congratulations brother! I am so happy you finally have a complete car to get started on and I think you have the right game plan in keeping it pretty much as is, when t comes to suspension I will offer my thoughts on installing a 32 Ford front crossmember and s****ping the 2 front leaf springs, I helped do that on a Plymouth sedan and it worked great.
    Have fun my friend, you deserve it. HRP
    1Nimrod, winduptoy, Stogy and 7 others like this.
  13. marfen
    marfen
    from sask
    We had to add a little width on the aftermarket 32 front crossmember as the plymouth frame is a touch wider. Maybe an A crossmember might work better. Full fendered will really help if there's no chop. I've seen these coupes chopped and the rear window ended up a catseye. yuck.
  14. HOTRODPRIMER
    HOTRODPRIMER
    BTW, were you lucky enough to get the flying lady radiator ornament? HRP
    catdad49, winduptoy, Stogy and 5 others like this.
  15. Rickybop
    Rickybop
    Thanks, you guys.
    Lots of parts, but I haven't seen a flying lady hood ornament. Haven't gone through everything yet, though.
    I do have the grille shell and insert. You can see the shell needs a little work at the bottom, but that won't be too bad. The insert looks to be absolutely perfect except for surface rust.
  16. Rickybop
    Rickybop
    I've considered using a Ford front axle and transverse leaf spring suspension. It would allow moving the axle forward. But I wanna keep the uniquely Mopar personality of this car. I think I'll keep the parallel leaf suspension front and rear. Ladder bars maybe for the rear. I like ladder bars.
    I think one of the first things I'll do is section the 1964 Ford truck axle that's on it now. Excellent heavy duty axle for my purposes. The track width is too wide, but I figured out that if I narrow the axle and get the perch pins to line up, the tires will end up right where they're supposed to be.
    Even though we live pretty far out in the country, there's a large fabricating shop just 1/4 mile down the road from us. They do a lot of very involved and very heavy duty weldments for the farming industry. So they've got the equipment and the know-how to section and weld my axle and make it straight and strong.
  17. Rickybop
    Rickybop
    I think the only body panels I'm missing are the rear fenders.
    So if ya got any...
    I'd pay a million dollars.
    Give or take.
    catdad49, winduptoy, Stogy and 7 others like this.
  18. Sharpone
    Sharpone
    EXCELLENT!!!
    Dan
    winduptoy, Stogy, porkshop and 3 others like this.
  19. Budget36
    Budget36
    What did you end up using for a front axle set up?
  20. HOTRODPRIMER
    HOTRODPRIMER
    Rick, looking at the photo's I'm thinking a fibergl*** Model A coupe or pickup rear fender may work, maybe someone has one you can borrow for testing. HRP
  21. Rickybop
    Rickybop
    @Budget36
    That's a 1964 Ford F100 axle. It's just half-***ed u-bolted to the Plymouth springs so I could get it on and off the trailer. But I'm thinking about using it.
    @HOTRODPRIMER Danny,
    Some fibergl*** rear fenders of unknown origin did come with it. Initial test fit doesn't look real good LOL. But I agree, something can probably be adapted. If I end up bobbing the fenders a bit, the fit of the fibergl*** rear fenders might be a little easier to manage. Or maybe somebody will have a nice pair of original fenders for me. But they're not as readily available as Fords.
    catdad49, Stogy, -Brent- and 6 others like this.
  22. HOTRODPRIMER
    HOTRODPRIMER
    @HOTRODPRIMER
    . Or maybe somebody will have a nice pair of original fenders for me. But they're not as readily available as Fords.[/QUOTE]
    Yes sir, I checked the Hamb and Market place within 500 miles of me for 30/31 Plymouth rear fenders and found nothing. HRP
    Stogy, porkshop, mad mikey and 3 others like this.
  23. Budget36
    Budget36
    If it fits, heck ya. I recall you mentioning using a trailer axle to get it on and off.
    I thought “doesn’t look like a trailer axle under there “. :)
    mad mikey, Sharpone and Rickybop like this.
  24. Rickybop
    Rickybop
    "If it fits" is a relative term.
    The track width of the F-100 axle is a few inches wider than the stock Plymouth. And the spring perch position is further outboard than the springs on the Plymouth by about the same amount. So if I narrow the axle to line up the perch pins, then the track width falls into place, too.
    But I kind of like the way the sidewalls of the tires are just about even with the outer edges of the front fenders. I think it gives it kind of a radical aggressive look. In that case, I could just build adapter plates. Or adapter blocks if I wanted to go up a bit.
    Edit:
    Scratch the idea of the "wide-track" look. I'm gonna go ahead and have the Fab shop narrow the Ford front axle.
    winduptoy, Stogy, porkshop and 6 others like this.
  25. Rickybop
    Rickybop
  26. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    The wider the front, the more stable the control.
    Think 'rail job'
    porkshop, mad mikey, Sharpone and 2 others like this.
  27. choptop40
    choptop40
    That's gonna fly with a foe foety foe speed......good luck all the way....
    winduptoy, Stogy, porkshop and 5 others like this.
  28. Hitchhiker
    Hitchhiker
  29. BrerHair
    BrerHair
    Excellent. Good luck!
  30. RMR&C
    RMR&C
    from NW Montana
    Congrats on the coupe! Being a PA coupe owner I will be following along.
    Too bad you are so far away, I have a Mopar wavy tube axle that would look cool under there
    Stogy, porkshop, mad mikey and 4 others like this.
