Technical Flat Head main bearing dilemma .
Discussion in 'The Hokey Ass Message Board' started by str8 6 str8 edge, Oct 22, 2024.
  1. str8 6 str8 edge
    str8 6 str8 edge
    from Tampa
    I’m building an 8ba using the **** stroker kit. My main journals all measure 4.998. After I install my main bearings, torque and measure, I’m coming up with .003 - .0035 bearing clearance. The block and caps seem to be in good shape . I know, back when, .002 bearings were a common thing but seem to be as rare as hens teeth now. I’ve also considered using shim stock to tighten my clearances . Anybody have any ideas or opinions on the best move forward?
    Unkl Ian likes this.
  2. str8 6 str8 edge
    str8 6 str8 edge
    from Tampa
    Found some NOS .002 bearings. Perfect fit.
    Algoma56 and Unkl Ian like this.
  3. Unkl Ian
    Unkl Ian
    Is the crank small ?
  4. PackardV8
    PackardV8
    We line hone the main bores of all our blocks to the spec we want; most every old block needs it anyway.
    jack vines
    chicken, Budget36 and AccurateMike like this.
  5. Bearing Burner
    Bearing Burner
    from W. MA
    If your main journals measure almost 5"your flathead must be from a ship.
  6. str8 6 str8 edge
    str8 6 str8 edge
    from Tampa
    Ha! sorry , 2.998.
  7. str8 6 str8 edge
    str8 6 str8 edge
    from Tampa
    Do you cut your caps ? We thought about making a jig for the mill.
  8. PackardV8
    PackardV8
    The Sunnen CPG-750 cap and rod grinder is the shop standard for nipping main caps for line honing.
    jack vines
    rod1 likes this.
