Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. Finally finished getting the flex pipe out of my car lol Messenger_creation_D0F4A138-709A-4020-9E3C-2A572EEF0630.jpg
    X-cpe likes this.
  2. Poverty cap
    Poverty cap
    9B1B0719-747E-4BD6-8ECB-23739EBDD4BA.jpeg 53C5E166-C17F-4E1C-876A-79DDED078BC2.jpeg I painted my 65 Belair wagon in 2003 and it started showing some rust around the gas door. I came up with a solid plan, I was going to repair the quarter, blend into the back door and up the rear pillar. I have a different rear view mirror I’d like to use so I thought it was a good time to weld the old holes up. I’ve never been happy with the door gap between the doors, so now I thought is a pretty good time to address that, there are chips I should probably…..
    61Cruiser, swade41, loudbang and 2 others like this.
  3. Almostdone
    Almostdone
    Washed it with soap and water (a rarity) during a light rain. The last drive of the year was pretty wet and it got real dirty. All clean, dry and under cover for the winter now….until April. Drove it just over 4,000 miles this year. Giddyup.
    John
  4. ERguitar
    ERguitar
    ***embling some freshly painted parts..... hopefully on the road this spring. KIMG1332.JPG
  5. RICH B
    RICH B
    Made some mounting plates to attach the wood base to the seat frame. 1/4" kinda overkill; but I wanted to tap them for studs to make it easier to drop in place.
  6. swade41
    swade41
    from Buffalo,NY
    Drove it to the voting place then discovered I have a leaky wheel cylinder
    65pacecar, Chucky, lumpy 63 and 5 others like this.
  7. choptop40
    choptop40
    Old leaf springs removed ..Get a new set for Christmas...Hey , Santa knows I've been a good boy PXL_20241106_144643053.jpg
  8. swade41
    swade41
    from Buffalo,NY
    Got the pieces painted
    And installed
    Just about a wrap on this one for the year
    lumpy 63, Tim, charleyw and 7 others like this.
  9. patsurf
    patsurf
    swade41 likes this.
  10. swade41
    swade41
    from Buffalo,NY
    Thanks
  11. RICH B
    RICH B
    Covered the seat back springs for our '47, hooked the to the back frames, and tried them out on the base to be sure they cleared the wood I added.
    IMG20241107180656.jpg IMG20241107182106.jpg IMG20241107193326.jpg IMG20241107203509.jpg
  12. Primo
    Primo
    Bought new brake drums, pads, and hardware. Then looked out the window at it because they are calling for 45 more hours of snow.
    impala4speed and swade41 like this.
  13. jeepster
    jeepster
    from wisconsin
  14. swade41
    swade41
    from Buffalo,NY
    I changed the leaky wheel cylinder on the Henry J, so that should be good to go now.
  15. cheap-n-dirty
    cheap-n-dirty
  16. cheap-n-dirty
    cheap-n-dirty
    Went to lunch at a restored gas station turned into a restaurant.
    Oneball, osage orange, LAROKE and 9 others like this.
  17. 53olds
    53olds
  18. hotrodA
    hotrodA
    61Cruiser, rod1, mad mikey and 12 others like this.
  19. 392_33
    392_33
    26430C72-EBF8-485F-B7EF-4E5A377B0AB3.jpeg D453EC1B-AC5B-4252-8047-F269F6F7649F.jpeg
    Took my newly blasted and painted reclining -66 T-bird seats to the upholstery shop.
    mad mikey, LAROKE and j hansen like this.
  20. rob-redm
    rob-redm
    changing from HEI set up to a MSD in my Nova
      220 KB
    mad mikey and swade41 like this.
  21. nochop
    nochop
    from norcal
    M***aging the insert frame. On with the in and out game, got close but no cigar. So out it comes IMG_7417.jpeg IMG_7414.jpeg IMG_7415.jpeg
  22. T. Turtle
    T. Turtle
    With temperatures suddenly over 60°f, today was the first time it was possible to work on the car where it is so I picked off where I left last year, namely trying to find why the car runs rich. Well, it's not a too high fuel pressure (the bane of many mechanical pumps these days). So next I'll take the carb off the car, fit a br*** float (currently I have the old plastic one which allegedly becomes impregnated with fuel as time goes by, which messes up its... floating so you cannot properly adjust fuel level) and recheck the power valve gasket for leaks. And if all that does not work, I'm not too proud - I have a Ford 2100 replica made in a certain country, and those according to the internet DO work.
  23. Spooky
    Spooky
  24. RMcCulley
    RMcCulley
    Put the mufflers back on and Finally got the timing set correctly, ripped the carpet out and went for a drive.
    Next up, service the differential (ford 9") and put new carpet in
  25. Kiwi 4d
    Kiwi 4d
    A few friends with old coupes went to the hot rod picnic today. Our club had a record 37 cars attend , we have got the rat fink award for best attending club 18 years straight. Always a chilled out relaxing day we look forward to , no real trophies just chilling out. . Plus raising $6500 for the rescue helicopter as a bonus.
    X-cpe, rpm56, Spooky and 14 others like this.
  26. Adriatic Machine
    Adriatic Machine
    IMG_3854.jpeg Brand new fuel tank in the Ranchero, gonna make some new straps as soon as I scrounge up two strips of stainless steel.
    Yes, I always put the cart before the horse.
  27. The37Kid
    The37Kid
    About a month ago I started to organize things, as I found them I'd put related tools and small projects together. No real plan, there was a 1915 T windshield I got a smoking deal on at Hershey since the lower gl*** was broken. Found some top rests for the Roadster with one screw ceased on the aluminum stand, and other little things. Bit by bit maybe a half hour at a time I'd fool with the stuff. Now I have safe stuff to hang on the wall, and less clutter
  28. Began attaching the '29 Model AA body to the frame. Forgot to put the middle wood pieces in and will have to undo - or at least loosen - the front and back blocks, then pull down the webbing in the middle so I can punch out a hole to accommodate the middle bolts. One on the p***enger side will be a biotch as I've installed the transmission cooler real close on that side and won't have much room to wrench without removing the cooler first. This re-***embly drill is exceptionally challenging as I'm 76 now and I took this all apart when I was 25. I'm grinding forward using logic and bits of memory. It feels good to finally be putting this together. Next will be wiring, then start up!
  29. wicarnut
    wicarnut
    Checked my battery tenders on hobby cars, worked on my winter DD, an old SUV, ordered part needed, will finish when part arrives and cleaned up garage/shop some as flat surface-itis was wining, anybody else have this problem ? every workbench/table etc gathers stuff and then I have to put stuff away so I have a work table. And then I need to fix the snowblower as something broke at the end of the last driveway clearing, sometimes it's like Gilda said, "It's always something"
  30. Spooky
    Spooky
    Howza Bruthas!
    Well, update on my '57, I finally drove it out of the garage for the first time in 2 years!!
    Now, just gotta get an appointment scheduled at the local exhaust shop.
