Projects Building an early offset sprint roadster. 8-8-24
Discussion in 'The Hokey Ass Message Board' started by Frames, Aug 9, 2024.
  1. Frames
    Frames
    I eliminated the under loops by designing the lower rail to run 2-3" off the track. I eliminated the bend in the top rail going down in front of the engine. Instead of this upper rail ****ing into the torsion bar tubes it p***es over them. Good place to install the bumper. Different than my drawing I used the Edmunds type truss. I eliminated the bend at the rear of the lower rail by making that section removable. I like the #5 paint job. I like the Hyder Hawk generation one tail. I like the Greg Weld early 60's sprint car. 2024-08-09 08.20.49-1.jpg 2024-08-07 21.51.35-2.jpg 2024-08-09 08.20.49-2.jpg 2024-08-09 08.20.49-3.jpg 2024-08-09 08.20.49-5.jpg 2024-08-09 08.20.49-7.jpg 796C9157-DDC0-4ECA-968D-527636534E91.jpeg nice body.jpg 52633384099_7fa072f6f0_k.jpg
  2. Frames
    Frames
    Sharpone, Outback, 69thumper and 7 others like this.
  3. Jay McDonald
    Jay McDonald
    Awesome work as usual Dennis.
    Sharpone and porkshop like this.
  4. Frames
    Frames
    Forgot to mention that's an X-Shift 3 speed transmission. Will have a hand clutch. 2020-08-13 18.52.14-1.jpg 2020-08-13 18.52.14-19.jpg 2020-08-13 18.52.14-21.jpg The 350 engine is ready. I have 6 Ken's Equipment Hawthorne, CA aluminum wheels.
    Sharpone, RICH B, BigJoeArt and 9 others like this.
  5. porkshop
    porkshop
    from Clovis Ca
    Ed Hyder built some beautiful cars..and was local to me...
  6. A Boner
    A Boner
    Dennis, were you friends with Pogo…back in Wisconsin.
  7. Frames
    Frames
    I considered Tom a good friend. He was a great car builder. The Etchie Corvette bodied modifide is my all time favorite Pogo car. I branched off into building late model stocks when the modifieds [ M S C ] lost Cedarburg and Hales Corners to the late models but I didn't build any cars for that circuit either because the promoter barred my coil/over cars. 1974 Larry Ninneman in the Pogo sprint car and Gary Schlafer [My ch***is ] traded fast time until Fast Eddie said 'There is no way Gary is going to beat Larry's time." Gary went out and set the World Record for modifieds on the 1/4 mile. 11.76. My late models set the 1/4 mile World Record. 1978 Pat Schauer 11.92. Mark Martin 1984. 11.59.
    Sharpone, Outback, sr and 7 others like this.
  8. Frames
    Frames
    Installed uprights [ 3/4" X 1.5" X .083". ] for the front torque plate and the radius rod mounts. I wanted to make the lower shock mount and front radius rod mount. 2024-08-11 21.55.18.jpg Did not want to jig saw out a template for my flame cutting machine so I stapled 2 pieces of template cardboard together. Worked just fine.
  9. Frames
    Frames
    Offset supermodified roadster I built in 1971. Wedge body. Had a USAC legal cage at first. Changed it to an I R A legal 1.750" OD cage when I sold the car to 6' 4" img121.jpg img122.jpg Gene Coleman. Coleman Machine Race Products.
  10. Frames
    Frames
    Finished welding the right side. 29 lbs. Lots of angle irons clamped to the board to duplicate the left side. 2024-08-13 22.50.19-1.jpg 2024-08-13 22.50.19-2.jpg
  11. Frames
    Frames
    I set 2 tubes in place just to see if I can match the dimensions of my drawing. Checks out perfect. The 1/4" thick magnesium engine plates are something I used years ago in my super late model dirt cars. I think I will try to purchase a 1/2 sheet of 3/16" thick magnesium to do the full engine mounting plates. 2024-08-14 21.19.46-1.jpg 2024-08-14 21.19.46-2.jpg 2024-08-14 21.19.46-3.jpg
  12. Jmountainjr
    Jmountainjr
    Coming together nicely. Since my early teens supermodifieds have been my favorite circle track cars. The first ones I remember were the early offset cars similar to what you are making. Then up here in the northeast things changed in '76 when Jim Shampine built his radical offset car. I still love watching them. Will be watching your build.
    Sharpone, tractorguy and porkshop like this.
  13. Frames
    Frames
    Checking fuel injection pump clearance. Will fit inside 2024-08-16 09.49.42-1.jpg 2024-08-16 09.49.42-2.jpg body side panels. Figuring out Ross steering mount. Eliminating left tube. Mounting box it self to the torque plate. Finished left frame rail. Will move the rails to the frame jig now to install the cross members.
  14. Frames
    Frames
    Punch marks in the upper rails to measure crisscross to square up the rails. Installing the torsion bar tube cross members next. 2024-08-19 18.31.01-1.jpg 2024-08-19 18.31.01-2.jpg
  15. Frames
    Frames
    No jig. Lots of vise grips and lots of measuring and re-measuring. All the notching for the torsion bar tubes was done before hand with a Port-O- Band. Left outer rail notch needs a little grinding. Ready to install torsion bar cross members. 2024-08-19 23.05.41-1.jpg 2024-08-19 23.05.41-4.jpg
    Sharpone, MMM1693, wicarnut and 4 others like this.
  16. Frames
    Frames
    2024-08-18 12.18.41-1.jpg 2024-08-25 19.44.11-1.jpg 2024-08-25 19.44.11-2.jpg Shortened the steering side shaft. Will mount box to the torque plate. Built front bumper. Fabricated right rear bolt in tube section. Left side tomorrow.
  17. Frames
    Frames
    Welding on frame complete. Decided to build rear bumper while still on the jig. Short 90 degree bends I had in stock. They were for building my road race upper control arms. Just like the old days. Use what you have laying around. 2024-09-01 00.04.39-1.jpg 2024-09-01 00.04.39-2.jpg
    Sharpone, sr, dana barlow and 7 others like this.
  18. Frames
    Frames
    9-8-24. Hand clutch/hydrallic throw out bearing. Battery box. Cross member for seat and seat belt brackets. 2024-09-08 23.38.17-1.jpg 2024-09-08 23.38.17-2.jpg 2024-09-08 23.38.17-5.jpg 2024-09-08 23.38.17-6.jpg
    Sharpone, Graham08, porkshop and 2 others like this.
  19. Frames
    Frames
    Built headers. A sprint car header kit but required LOTS of time to fit perfectly. Header plates have oval holes and tubes go in at a pretty good angle. Sanded with 320 grit to get rid of imperfections. WANTED; One Kens Equipment 6pin 15 X 8 aluminum wheel. 2024-09-15 12.35.23-1.jpg
  20. Frames
    Frames
    Made a new mount for the injection pump. Made the front torque plate, 3/16" thick 5052 aluminum. 2024-09-16 21.54.20.jpg
  21. patsurf
    patsurf
    do you beef up the curved edge of the cutout for the pump?
  22. Frames
    Frames
    No. This front engine mounting plate is about 10 times stronger than the front engine mounting plates on WOO sprint cars today.
    Sharpone, porkshop and dana barlow like this.
  23. Frames
    Frames
    Made the rear torque plate. Shortened the steering shaft. Lengthened Pittman arm to 5" & 2015-03-18 20.16.41.jpg 2024-09-22 13.14.21-1.jpg 2024-09-22 13.14.21-2.jpg 2024-09-22 13.14.21-3.jpg 2024-09-22 13.14.21-4.jpg 6". I built 2 offset supermodifieds in 1972. #67 built for owner/driver Ron Marish with a S B C. I asked Ron if he had to take any chances winning races. He said " Anyone could win driving that car" Independent front suspension! 1973 I installed a B B C engine. I had to rotate the engine to the left to make room for the drivers feet. Right side headers now horizontal. This was way before the radical Oswego supers of today. 1974 Ron sold car to Bill Klien pictured here.
  24. Frames
    Frames
    Having trouble finding one 5 degree K P inclination F 150 spindle to finish the offset sprint car roadster roller so I thought I would throw a vintage dirt supermodifid ch***is together while waiting for an F 150 spindle to show up. I had all the major components in stock for the supermodified. 2024-11-02 21.48.06.jpg
  25. Frames
    Frames
    Another picture of the offset sprint roadster and another picture of the supermodified. Have you ever seen a wide 5 wheel like the left rear? 2024-11-06 12.38.07-1.jpg 2024-11-06 12.38.07-2.jpg
  26. dana barlow
    dana barlow
    from Miami Fla.
    Thanks Dennis.
    Fun seeing your ideas an great work.
    I been retired for over 20 years,so no new race car builds for me.
    Just messing around with my old high school hotrod from the late 50s n early 60s,plus a small bit of work helping with some buddy's rods now days.
    South Florida has lost all its weekend ovals,other then one small sandpit oval in https://hendryracing.com/ ,, I get to go to every few months.
    Your new stuff looks awesome too.. :D
  27. noboD
    noboD
    Thanks for showing these.
    Sharpone likes this.
  28. Graham08
    Graham08
    Old Safety Racing magnesium wide 5?
  29. Frames
    Frames
    dana barlow, Sharpone and porkshop like this.
  30. Frames
    Frames
    Obtained another early small tube Hilborn for the offset sprint roadster. 2024-11-14 10.30.25-1.jpg 2024-11-14 10.30.25-2.jpg 2024-11-14 10.30.25-3.jpg Better visability for low seated driver. Installed the big bell stacked Hilborn on the supermodified.
