Technical Vintage Sun tachometer housing
Discussion in 'Traditional Hot Rods' started by Timchek, Nov 6, 2024.
  1. Timchek
    Timchek
    Gents, found this vintage 6 cylinder Sun tach on EBay. Would like to find a steering column mount housing for it. Seems deeper than most of the housings I’ve seen. I’m hoping that a housing does exist for this model?
    Shows model RF-5 on tag rear of tach.
    Thanks!
    Al
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I can't help but doesn't it also say it is for a 2-cycle? Like for a 6-71 Diesel or a 2-cycle outboard marine engine?
    If that's the case it may read only half engine speed on a conventional automotie six cylinder.
    EDIT: I know most diesels don't have coil ignitions. They may have tach signal generators.
    Re the housing: If you want to get creative maybe part of a stainless steel water bottle or the like could be made to work. I once lost the stainless steel center cap for a motor home wheel and the RV manufacturer wanted $176 dollars for a new one. Nope. I sent my wife out for a stainless steel dog dish, cut it down and with a little hammer forming made it work. Saved $166 dollars.
  3. Timchek
    Timchek
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Additionally, the fact that it is an 8-grand tach would seem to suggest its for a 2-cycle six.
  5. Jokester
    Jokester
    Alternative tach cup...
    Okie Pete and saltflats like this.
  6. Timchek
    Timchek
    Jokester, what is the source of your alternative tach cup?
    thanks,
    Al
  7. Timchek
    Timchek
    I might have purchased a nice display piece! :(
  8. Jokester
    Jokester
    Junkyard! Pretty sure it's a Camaro or Nova rally wheel cap.
    .bjb
  9. deathrowdave
    deathrowdave
    from NKy
    Looks like Chebbie Rally Wheel center cap
  10. stuart in mn
    stuart in mn
    You could go back to eBay, I just looked and found a number of them. Search on 'sun tach cup'.
  11. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I think the first thing I'd do is hook it up to an engine - any spark ignited engine - and see if it works. Depending on the number of cylinders and the needle movement you could see if it works and if it is relatively accurate.
    Doing this in a car with another tach wired in would be a plus.
    Timchek and patsurf like this.
  12. Timchek
    Timchek
    THE FRENCHTOWN FLYER likes this.
  13. Timchek
    Timchek
    Yeah, looks like I’m gonna havta make sure it works first on my car! Not a two stroke!
  14. Budget36
    Budget36
    Maybe contact the instrument repair/upgrade places, see about converting it for your engine.
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Timcek,
    Just as an aside, if you insert a quote and then reply outside the OP's [/QUOTE] bracket your response will be displayed outside of the OP's message. Hope this helps.
    Timchek likes this.
