so what is it....? vintage part id question
Discussion in 'The Hokey Ass Message Board' started by brandon, Oct 19, 2006.
  1. brandon
    brandon
    this thing came with a anglia i bought out of chicago area..... maybe a horn ....maybe .....????? ..has the name warner on the front cover...has 2 post on the back....spring loaded arm .... brandon
  2. Any more or better pics? Stu
  3. brandon
    brandon
    finally got the camera batterys charged.....here are a couple more pics....thanks brandon
  4. Thorkle Rod
    Thorkle Rod
    That's the Warner Device, before you do anything with her, you better Warner, and no that is not a Thorkle Rod.
  5. Shouldn't it say "ACME" then?
  6. Thorkle Rod
    Thorkle Rod
    I don't see it in the ACME Catalog
  7. flatheadmalc
    flatheadmalc
    It's an old trailer brake controller Dad used to have one on his 50 Ford PU
  8. Gumpa
    Gumpa
    That sure looks like my old moo horn that I use to have on my 54 cadilac when I was in school. I use to have it mounted on the left side of the column and tried to make it sound like a bull.
  9. 49ratfink
    49ratfink
    It's Out Of An Anglia, Which Is British...prolly Has Something To Do With Making Tea
  10. dabirdguy
    dabirdguy
    No, It sounds and alarm unless you drive on the left hand side of the road.
  11. Brian C
    Brian C
    It's not for making tea. It's a training device to make sure you hold out your little finger when you drink your tea.
    At least I THINK it's your little finger......maybe it's this finger here in the middle. :eek:
  12. Bruce Lancaster
    Bruce Lancaster
    Lever, clamp looks to be for steering column...is common British and European accessory switch used to flash high beams for signaling, also commonly used for horn or both together.
  13. Gr8ballsofir
    Gr8ballsofir
    "TRAILER BRAKES! TRAILER BRAKES" from "the Long Long trailer" starring Desi and Lucy...
