Technical Lime works horn wire
Discussion in 'The Hokey Ass Message Board' started by deucepickup32, Nov 6, 2024.
  1. Instructions sure don’t give a lot of details. Is the nylon bushing supposed to sit inside the shaft ? IMG_8970.jpeg
    camer2 likes this.
  2. Happydaze
    Happydaze
    Looks like it should and would make sense if it did, and no sense if it didn't!
    Chris
    olscrounger likes this.
  3. I would think so as well but it doesn’t fit. The instructions are vague
    Happydaze likes this.
  4. From the photo, it looks like fitting it into the column would keep it centered.
  5. I agree but the nylon bushing is bigger in diameter than the steering shaft. Just don’t want to grind it to fit then find out that it’s not supposed to. Common sense says it should
  6. Budget36 and alanp561 like this.
  7. To me it looks like the bottom, smaller part of the bushing sits in the column and the top part sticks out above.
  8. I agree.
    pprather likes this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Is the step down on the nylon bushing 5/16” by chance? Instruction say to drill an inner shaft 5/16”.
    uncle buck and alanp561 like this.
  10. alanp561
    alanp561
    Do the other 5 pages of instructions that came with the kit tell you anything about the installation. @pprather 's suggestion to call Limeworks seems to be the next step.
    pprather and deucepickup32 like this.
  11. IMG_8790.jpeg Problem solved. There must have been a small burr at the steering wheel end of the shaft from manufacturing. I cleaned it up with a file and gently tapped it in. Thanks for all the responses.
    One step closer to getting it to Deuce Days next July in Victoria British Columbia
  12. Sometimes stepping away from the problem for a while and then coming back fresh leads to the solution.
    Algoma56 and deucepickup32 like this.
  13. Yes it does
    The Shift Wizard likes this.
  14. Happydaze
    Happydaze
    I'll admit I was scratching my head with those instructions as I'd no prior understanding of horn push wiring and it was only when I realised the bushing was isolated from the shaft that it made sense!
    Deuce Days in Victoria is a wonderful thing. Done it twice.
    Chris
    deucepickup32 likes this.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Think motor armature.
    Happydaze and deucepickup32 like this.
  16. dalesnyder
    dalesnyder
    That is one good looking sedan!
    milwscruffy likes this.
  18. What did Limeworks say about the column top plastic fitting?
  19. It's like a horn contact on a postal jeep.
    The plastic bushing should go into the side the column and the button should be in contact with the bronze bushing on the inner shaft at all times. The white plastic bushing in your picture is to insulate the button so it doesn't contact the outer column. When you hit the horn button it grounds to the inner shaft, through the bronze bushing on the inner shaft to the button in the plastic bushing, through the wire to the relay.
    You drill the inner shaft just to bring the wire from the center of the hollow shaft to the outside of the center shaft and attach it to the bronze bushing.
    38Chevy454 and Happydaze like this.
  20.
  21. I re read the whole post I skimmed at the end of my lunch break. You didn't need the whole how it works post I did, you just wanted to know about the bushing under the horn button......sorry.
  22. No problem and you could have hi lighted something I missed.
