Technical Help identify this terminal block
Discussion in 'Traditional Hot Rods' started by richard crow, Nov 8, 2024.
  1. richard crow
    richard crow
    This came with a car I purchased, I want to use it. I need the wiring diagram or any instructions. It does not identify who made it.
    Thank you
  2. Ron Francis and missing cover for terminals that would have his name on it.
    Jibs, Just Gary, ydopen and 2 others like this.
  3. richard crow
    richard crow
  4. tb33anda3rd
    tb33anda3rd
    if you remove the fuses and use a continuity tester, you will be able to make your own diagram.
    each side of the fuse should be connected to a terminal and the fuses ae marked . brake, horn and hazards should go to Battery power. gages and turn go to ignition feed
    ydopen and '28phonebooth like this.
  5. 24riverview
    24riverview
    Hopefully readable if you click on it once.
    dirt t likes this.
  6. dirt t
    dirt t
    Anything Ron Frances is quarity.
  7. keith adams
    keith adams
    If you get the serial number off of it and call them, they will email you diagram and instructions. Good people. 800-292-1940
    firstinsteele likes this.
