Projects 60's 1932 3W Build
Discussion in 'The Hokey Ass Message Board' started by hotrodfab32, Jun 1, 2018.
  1. hotrodfab32
    hotrodfab32
    I appreciate all of the great comments from everyone.
    I've made a few changes to the car in the last couple months. The biggest is the wheels. As much as I liked the Indy style wheels, I didn't think they matched the style I originally had planned for the car. I found a pair of 15X4 Early American 5 spokes that I could afford after looking for several years. These are the first spindle mounts they came out with that were just the standard 15X4 castings with ribbed hubs cast into the back of them. I was going to machine the hubs off, bore out and drill them to use lug nuts. Then I realized there was enough material to mount the Buick drums I was using and thought they would be even better as spindle mount.
    After gl*** beading them I machined the ribs off leaving as much material I could. Then 10 holes 3/8-16 X 1/2 were drilled and tapped into the back of them to mount the Buick drums.
    The centers of the drums were bored to be a snug fit on the wheels and the 10 hole pattern was drilled in them.
    To make up for the strength of the ribs removed, a hub that bolts on with the drum and clamps on the machined hub on the wheel was fabricated.
    When everything is ***embled with studs it looks pretty strong and clears everything for the brakes.
    Some caps like the originals were made from stainless pipe caps. They use an O-ring to hold them onto a groove that's been cut in the wheel's center bore. They were gl*** beaded again and will hopefully not take too long to darken up.
    PFF, 40FORDPU, swade41 and 31 others like this.
  2. caprockfabshop
    caprockfabshop
  3. pprather
    pprather
    No. Double wow!
  4. Chavezk21
    Chavezk21
    DANG! I just discovered this thread and holeeeee cow batman!!! All fab work welding etc. is unreal. That car is impressive as all get out. DANG!
  5. nrgwizard
    nrgwizard
    from Minn. uSA
    :D . You rock... Thanks for the idea & sorta-how-to sharing. :D .
    Marcus...
  6. Speccie
    Speccie
    That looks so cool. Fantastic engineering.
  7. hotrodfab32
    hotrodfab32
    Thanks for the nice replies.
  8. rod1
    rod1
  9. hotrodA
    hotrodA
    What an outstanding car!
    I’m totally amazed by the work on the dash!
    What is the source of the checkered gauge panel ? So much more elegant than engine turned.
  10. hotrodfab32
    hotrodfab32
    For the rear wheels, I wanted 16X10 Halibrand Speedway Specials. I found these on FB that looked like **** and took a chance because I got a pretty good deal.
    They were soaked with Awsome cleaner and power washed. The paint on the center parts had helped protect them. Then put on a brake lathe and lips sanded. Next sand blasted to remove corrosion. Sanded again. The 5" B.C. holes I'm using were then spot faced and reamed.
    Then they were gl*** beaded to smooth everything out and to match the front wheels. There ended up being minimal pitting. I then put a heavy coat of Por 15 on the outside like the front to seal any porosity.
    Still the best looking back wheels ever made. Just need to darken up now.
    PONTNAK123, clem, swade41 and 25 others like this.
  11. hotrodfab32
    hotrodfab32
    The diamond impregnated aluminum came from McMaster-Carr
    hotrodA likes this.
  12. hotrodfab32
    hotrodfab32
  13. AmishMike
    AmishMike
    Sure did a great job saving those rims - sweet looking
  14. hotrodA
    hotrodA
    Thanks very much for the response.
  15. DDDenny
    When I commented to my friend who built my roadster ch***is that I wanted to get the aluminum K.O. wheels to look more like aged magnesium Halibrands he said bring them down here (Oregon Coast) and leave them laying out behind his shop for six months.
  16. hotrodfab32
    hotrodfab32
    Might age them so well that they're not usable. Luckily I have plenty of time before they will get used.
    elgringo71 likes this.
  17. Hard Luck
    Hard Luck
  18. hotrodfab32
    hotrodfab32
    I'm working on sheetmetal now. Boring stuff
    Hot Rod Ron, Hard Luck and Happydaze like this.
  19. IronFord
    IronFord
    from NoDak
    Not sure how I missed this one, but great work. I apologize if this has been asked before but are you planning on chopping it?
  20. Rand Man
    Rand Man
    Lotsa neeto details here.
    IronFord likes this.
  21. brady1929
    brady1929
    Great hot rod. Could you please provide a link for the diamond impregnated aluminum for the dash. I know you said McMaster-Carr, but I could not find it.
  22. caprockfabshop
    caprockfabshop
    Looks like:
    https://www.ebay.com/itm/310427672317
    rod1 likes this.
  23. Jeff Norwell
    Jeff Norwell
    MODERATOR
    What a great thread!!!
    RatPwrd, Kelly Burns and rod1 like this.
  24. flyn schlosser
    flyn schlosser
    from Elko,NV
    Just read thru the whole thread..amazing. can't wait for more
