Projects Eh, well it's been a minute or T
Discussion in 'Traditional Hot Rods' started by fatassbuick, Oct 16, 2024.
  1. Outback
    Outback
    from NE Vic, Oz
    What a lovely l*** :cool: Looking forward to what you have in mind
  2. Jacksmith
    Jacksmith
    from Aridzona
    Mmmmm... potennn-tiallll...
    Got a visual on where it's goin'?
    fatassbuick likes this.
  3. The37Kid
    The37Kid
    Welcome back! Eleanor looks like a keeper.
    Bob
  4. T_andcrumpets
    T_andcrumpets
    Whoa! I like where this is going!
  5. NoSurf
    NoSurf
    Awesome!
    Does it run?
  6. fatassbuick
    fatassbuick
    from Kentucky
    It turns over pretty easy with the hand crank, but is missing a generator, battery, wiring, etc. The immediate idea is to get the basics working, then make it a mild pre-war gow job..nothing too radical. Rail Job's beautiful Elza coupe is a work of art, so I might swipe a few ideas from it. For now, I've got to build back my finances and make some room in my garage. My brain is like a plasma globe at the moment.
    Outback, NoSurf, 41 GMC K-18 and 2 others like this.
  7. general gow
    general gow
    MODERATOR
    imagination overload is a beautiful thing. i try to live in that space as much as possible.
  8. fatassbuick
    fatassbuick
    from Kentucky
    Wow, 2/3 of the way through January and no update. I'm a little disappointed to say that I was off for almost a month and did very little. Albeit, we had family in, but I also had a lot of down time. It gave me a good recharge.
    First thing I needed to do was start organizing my garage a little. It was getting difficult to walk through, with five cars and one motorcycle.
    First, I had to get this stuff out of the way:
    I haven't seen the surface of that bench in about a year.
    Then I did a few mundane things, like the planetary gears for the steering column, an old rusty dash that seemed to match the rest of it;
    I have ordered all of the bushings I believe I need, so the next thing to do was to drop the front end. Everything was wallered out or loose, including kingpin bushings, which will be pretty evident later:
    Not the intricate art-deco curvature of the wishbone:
    I put the spindles and other bits in ATF/kerosene for a couple of weeks, while the weather calmed the hell down. Today, we were finally in the 40s, so I decided to clean them up a bit;
    Before:
    After:
    Bead blasted parts
    tb33anda3rd, ratster, lucky and 4 others like this.
  9. fatassbuick
    fatassbuick
    from Kentucky
    The bushings had to be removed before the spindles could be properly cleaned:
    Had to drill out the bushing to 9/16 for a 5/8-18 thread.
    After I tapped it, I threaded this ball joint into it because it was all I had. I then had something for my punch to hit while I knocked it out. Gently, I might add.
    They cleaned up pretty nicely.
    It took two days of moving pretty slowly to get all the cotter pins removed and the front end dis***embled. I used metal picks and atf/kerosene with an SS wire brush to clean out as much as I could. I also used a lot of “Knock ‘er Loose” (with a name like that, I had to try it). Worked pretty well, finally got it 95% apart:
    Next up will be removing all the rest of the bushings and figuring out what else needs to be replaced or repaired. Supposed to be nicer out this week, and I’m refilling my propane tanks, just in case. Hopefully, I’ll be able to get all of the bushings replace in the front axle this week.
    The wishbone is tweaked pretty well, so I’ll be straightening that out, or completely destroying it and buying a new used bent one.
    I don't know why this pic isn't showing up, but it takes you to the photo hosting pic if you click it.
    I’d like to reverse the eyes on the man spring, but I’m a little worried that the spring might be brittle from the weather, since it’s sort of pitted. If anyone can give me re***urance that I can bend this thing without heat, I’d sure appreciate it.
    41 GMC K-18, Tim and NoSurf like this.
  10. NoSurf
    NoSurf
    I reversed the main leaf on my coupe without using any heat.
    chicken and fatassbuick like this.
  11. chicken
    chicken
    from Kansas
    Mine too. In fact, I believe that's the way you want to do it if you want the spring to retain its tempering. Some pitting is ok but serious thinning of a leaf wouldn't be good. I set mine across the 4" bed of my press and used a 3/4" piece of round bar taped to the press ram to press every 2" until it got where I wanted it. Took three p***es if I remember right. Stay away from the center hole.
  12. Tim
    Tim
    from KCMO
    Another for no heat
  13. Dedsoto
    Dedsoto
    from Australia
    No heat, in the press 2 inch intervals. If there's a crack or thin spot you'll find it, but better in the workshop than roadway.
    RodStRace likes this.
  14. fatassbuick
    fatassbuick
    from Kentucky
    I think the planets all aligned or something, so I got most of the front end straightened out, with new bushings, an almost straightened wishbone, and a mounted axle.
    20250224_131303.jpg 20250224_150945.jpg 20250224_161140.jpg 20250224_184822.jpg 20250224_185402.jpg
    Nailhead A-V8, lucky, NoSurf and 3 others like this.
  15. fatassbuick
    fatassbuick
    from Kentucky
    I still need to straighten the end of the wishbone out a little more to fit correctly, from where it was bent. Ran out of time for the weekend.
    NoSurf, Outback and RodStRace like this.
  16. Id drive it
    NoSurf likes this.
