Projects '51 Desoto Custom
Discussion in 'Traditional Customs' started by driprail, Oct 25, 2018.
  1. 34 Airflow
    34 Airflow
    from Australia
    Loving this build, you are doing a brilliant job!
  2. choptop40
    choptop40
    Show Stopper....Would insure it for at least 50,000 , cant duplicate it for twice that amount..
  3. rockable
    rockable
  4. lostn51
    lostn51
    from Tennessee
    Oh I can’t wait to see it together, it’s gonna be amazing :):):)
  5. quakerchevelle
    quakerchevelle
  6. driprail
    driprail
    Got dangerously close today. It’s always something isn’t it? Needed to reroute a brake and trans cooler line then we’ll be in business. Hopefully tomorrow!
  7. Squablow
    Squablow
    Ooh, that's pretty. And the reshaped rear wheel opening really looks good with paint on it, you can really see it now.
    Stogy, chryslerfan55 and Jacksmith like this.
  8. driprail
    driprail
    Feels crazy to be at this stage. This paint can't make up it's mind what color it wants to be o_O
  9. guthriesmith
    guthriesmith
    Man, that looks amazing! :cool: I love the color!
    Stogy and lucky ink like this.
  10. Jacksmith
    Jacksmith
    from Aridzona
    The sunlight really lets those body lines show!
    Greenblade, Stogy and chryslerfan55 like this.
  11. Needs a Bellflower exhaust.
    Stogy likes this.
  12. Woogeroo
    Woogeroo
    from USA
    Well, whatever color it is, it looks amazing.
    Stogy and lostn51 like this.
  13. Jackie Fallen
    Jackie Fallen
    I named my 48 DeSoto OddRod.
  14. Jackie Fallen
    Jackie Fallen
    Wish I had the money, talent, and patience for a build like that. Actually I lack all three.
    Really grrrrrreat looking peoject.
    Jack
  15. driprail
    driprail
    Wiring is in full swing. Been looking forward to getting the dash together for years.
    Greenblade, Stogy, Paul B and 20 others like this.
  16. 41 GMC K-18
    41 GMC K-18
    Perfection cannot be rushed!
    This is the sign of excellence!
    Stogy, pwschuh, safetythird and 4 others like this.
  17. gatz
    gatz
    Great looking car. Superb workmanship
    Stogy, Jacksmith and 41 GMC K-18 like this.
  18. lostn51
    lostn51
    from Tennessee
    So when do you think it’ll be in the Rodders Journal or the cover of Good Guys:D
  19. driprail
    driprail
    ha that would sure be somethin! im happy with how everything is turning out but im not the best welder or fabricator. some parts of this build fall into the “good from afar, but far from good” category.
  20. lostn51
    lostn51
    from Tennessee
    Let’s face it, you have done a killer job on this car and it deserves some serious recognition
  21. caprockfabshop
    caprockfabshop
    I was blown away by the dash, that's gonna be so great in there! Glad to see JC Auto was able to help out with the gauges, they can be time-consuming to restore for a novice.
  22. driprail
    driprail
    JC auto did a bang up job. Really impressed with the work and how much time they were willing to spend on the phone.
  23. pwschuh
    pwschuh
    That's looking great!
    Stogy likes this.
  24. Jacksmith
    Jacksmith
    from Aridzona
    Extraordinary!!
    Stogy likes this.
  25. rockable
    rockable
    Love the color selections!
    Paul B and chryslerfan55 like this.
  26. str8 6 str8 edge
    str8 6 str8 edge
    from Tampa
  27. driprail
    driprail
    Sometimes it’s the little things
  28. driprail
    driprail
    Was one of those weekends! Got a crash course in wiring relays correctly by doing things incorrectly first.
    Wired up a horn relay and patted myself on the back because it seemed easy. Horn stuck blaring on. Okay where is it grounding out? Hour or so later with no luck when it came to me…My rebel wire harness has a horn relay already installed and I put ANOTHER one in series because I thought I was smarter than the instructions :cool:
    Second issue. My neutral safety switch is wired through the electronic push ****on shifter and requires a relay. I grabbed power for the relay from the unused AC/Heater circuit. Go to turn the car over and no cranking…Pace around the car and shop scratching my head only to realize the ac heater circuit is wired as ACC so when I turn the ignition switch to start position it was cutting power to the relay and opening the starter circuit.
    good times. 90% of things working. need to start the car to check the fuel, temp, and volt gauges and we should be in business.
  29. stinkity stoink
    stinkity stoink
    from new jersey
    I always feel I’m smarter than the instructions and it seldom works out for me. That’s not just for wiring cars either and I have done a 1/2 dozen and still screw myself up.
    car looks awesome. Keep it up
  30. driprail
    driprail
    So close to a first drive. Almost there. All of my gauges are working except for the temperature (electronic) and fuel gauges. Do these instruments care which post gets negative and which gets positive? I’m wondering if I wired them backwards.
    Jrs50, 41 GMC K-18 and Stogy like this.
