YOTA THE ALL POWERFUL
Discussion in 'Off Topic Hot Rods & Customs' started by Bandit Billy, Nov 3, 2024.
  1. Bandit Billy
    Bandit Billy
    Day of wiring. I dropped a couple riv nuts in the fender adjacent to the new fuse panel and bolted down the relays.
    I also wired the lights with bullets to make replacement and service easier. That’s all done
    I also wired the switch panel and routed the armored cable into the engine bay.
    That armored cable will also run under the truck from the relays to the roll bar along the frame. A lot tidier than running separate wires and covering them with split loom.
    Tomorrow I will wire trailer plugs to the cable so the roll bar can be unplugged and removed if necessary.
    1Nimrod, Oneball, chevy57dude and 3 others like this.
  2. Bandit Billy
    Bandit Billy
    That heavy armored cable has six 12 gauge leads within. It is heavy but under an off road rig there is nothing to worry about. Also made for a tidy user dash install. All the wiring exits the firewall and doesn't look out of place.
    I taped off the superfluous leads for future use, never know when an extra run to the bed may come in handy. I still have to install the stereo and she has asked for a kill switch or two. I have made some plans for that provision, should be easy and effective.
    porkshop and Deuces like this.
  3. deathrowdave
    deathrowdave
    from NKy
    There is a lot of coolness happening in the garage . The wooden stand for the fan is the best !
    porkshop, alanp561 and Bandit Billy like this.
  4. Bandit Billy
    Bandit Billy
    I paint, well I used to paint, no time for it at the moment. But that is one of my easels and it holds the fan well! It is adjustable up and down and I am thinking about mounting casters on the bottom. Possibly a power strip, lights and a cup holder. :cool:
    bchctybob, porkshop and alanp561 like this.
  5. Bandit Billy
    Bandit Billy
    Might be over kill but I don’t like the thought of the wiring bouncing around inside the roll bar. I had a long chunk of 3/4” heater house so I slid it up the bar around the wiring before adding weather proof trailer plugs. They are staggered to fit through the hole in the bed IMG_6686.jpeg
    I added two kill switches. One for the starter and one for the distributor power so it can’t be push started. My daughter insisted on them. Like that Forged in Fire guy says, “it will KEAL”.
    Next up is to install the stereo I bought her. NOS Sony c***ette deck with shafts.
    That’s a cool find and perfect for an 81 truck. Hers was a loaded truck with AC and door speakers which only came in trucks with tape decks I found out. it needs an antenna but I have to remove the fender to install it. That will wait, reception on MT Hood anyway.
    you should see her cabin, she has about 8 feet of albums and a strobe turn table. She is one cool chick.
  6. alanp561
    alanp561
    Bandit Billy and porkshop like this.
  7. Landmule
    Landmule
    I always enjoy Bandit Billy builds. So many good tips and clean work! Thanks for sharing.
    bchctybob, porkshop and Bandit Billy like this.
  8. Oneball
    Oneball
    Auto reverse :D:D:D:D:D
  9. Bandit Billy
    Bandit Billy
    Well ****. The deck I bought will not fit the dash. Way too wide and I don't want to chop up her nice dash to install it. The original stereo must have been tiny. I was thinking about an underdash supertuner? I can always sell this little Sony.
    bchctybob and porkshop like this.
  10. DDDenny
    And here I thought YOTA was Chinese for Year of the ***.:D
  11. AldeanFan
    AldeanFan
    Love some vintage Toyota!
    Bandit Billy likes this.
  12. Bandit Billy
    Bandit Billy
    I checked with my daughter about finding a different stereo that fit the dash better and she told me to “MacGuiver it”! So….
    I cut out the aluminum plate and hand filed to fit the deck. I put a bevel on the edge so some shiny bits would be visible. Sanded the edge to 3000 and tossed it across the buffer.
    Then added the guitar pick like I did on her switch panel.
    Sure beats the plastic faceplate. You can see the rounded corner that fits her dash. The square cornered plastic one just didn’t. And cutting plastic is just wrong.
    For fun I added two fret ****ons in white above the knobs. I mean why not?
    I like it, jury still out in what she thinks. She got 17” of fresh snow yesterday and more coming today. She’s needs her truck back so I have to stay on it. Obviously she can’t come down to help right now.
    This is more solo work anyway. Very tedious. Garage heaters are on, Van Halen on the stereo, perfect day for spending 4 hours milling a face plate for a $100 radio. Did I mention I love this girl? Yeah, I’m wrapped around her finger, always have been.
  13. Tim
    Tim
    from KCMO
    Good progress :)
  14. Bandit Billy
    Bandit Billy
    Thanks man. I will primer the roof tomorrow but it is soooo rusty. And thin! I was DAing it the other day, trying to get through the brown **** and the roof pops around like I was trying to sand a Wrigley's gum wrapper. After the winter I will access that roof and maybe find another one that is straight and clean and chop this one off. Do you think my daughter would notice a little hair cut? Toyota make a factory sunroof truck? That would be cool.
  15. Bandit Billy
    Bandit Billy
    Primer on all the spots that were bare steel and rusting.
    The roof is the worse panel. It will take some hours in the spring. I also had to epoxy primer the tops of both front fenders, the left fender to the tire, the tops of both doors and the rear of the cab where a canopy wore all the paint off.
    bchctybob, Landmule, porkshop and 3 others like this.
  16. Bandit Billy
    Bandit Billy
    I had time yesterday to get the radio installed in the dash. Not much room in there! I see why they used such a small radio frame now. But it turned out nice and doesn’t look “hacked in”.
    4 pedals, bchctybob, porkshop and 7 others like this.
  17. chevy57dude
    chevy57dude
    Looking great, Billy. The pick guard is cool. I knew a guy who built drums, always wanted to do the dash insert on the '57 in drum wrap.
  18. Snow Boarding........ahhhh, those were the days. I remember us being the only ones (or very few) on the slopes in Big Bear, that and the ****py bindings.
    No engine turning on the dash ?!?!?!?!
  19. Bandit Billy
    Bandit Billy
    I had this stuff left over from the wife's 41 PU. I used it on the door panel amps, AC switch plate and dash center emblem. Cool look.
    This girl is a boring guru! She must have 6 or more boards for different outings. Including a cool board that unlatches to make two pieces so you can navigate the lift easier. I remember taking her up the first time at Timberline, seems like yesterday. She was 7.
    We were close to having her drive it out of here tonight. Got the lights working (don't ask but thanks @Pist-n-Broke for talking me through relay wiring). I wanted to run only the ground through the switches, no power. I mislabeled a couple of leads and had to chase them with a voltage tester.
    Right when she was leaving the brake light was on. I didn't mess with the brakes. I checked the MC and it was low. Added fluid the light went out. She pulled out of the shop and there was a puddle of missing fluid under the drivers rear tire. Brake rebuild time. Parts ordered.
    bchctybob, porkshop and Pist-n-Broke like this.
  20. Bandit Billy
    Bandit Billy
    My worker bee. Her boyfriend is under the truck.
    the lights were a pain but they work
    and they are bright.
    She has the outer lights on one switch and the inners on another.
    Stereo works but only one door speaker. I suspect some taped up wiring in the drivers door jamb.
    More work ahead for turkey week. Fun times.
  21. Tim
    Tim
    from KCMO
    Thanksgiving in the garage with your kid. Sounds fantastic. Hope it’s a productive one :)
  22. Bandit Billy
    Bandit Billy
    I have a lot to be thankful of, especially for my kids.
    I didn't like tapping a fuse for my switched 12v source so I pulled the column apart, found a switched source off the ignition switch and tapped that wire. Much neater that way and no wires where you can see them.
    The stereo was only playing out the right speaker, I took the left door panel off and removed the speaker wire and it was broken. Quick repair, more tunes. The right speaker is louder but it may be resistance? I like to match the length of speaker wires when I do an install, this is definitely longer on the left side by double I would say. That combined with he low output of the stereo may be causing the difference. Usually when I install a 4 channel stereo I couple the fronts and rears when there are only 2 speakers. The Sony directions on line didn't say to to do that so I left it be.
    Not a big annoyance, I am deaf in my left ear so this works good for me :cool:. I make my daughter wear ear protection in the shop so she doesn't have the same issues when she is older.
    Brake parts will be here Friday, I am going to reverse the tires so the white letters are out. I'll clean them up and give those Toyota chrome wheels a little elbow grease and tin foil. It is going to be a cool little truck someday. I'll wait for her to come back over so she can learn to do brakes.
    bchctybob, Robdski, porkshop and 3 others like this.
  23. Bandit Billy
    Bandit Billy
    I took the drums up to have them cut and took along the rolling stock to have them reversed so the white letters are out and balanced as my daughter complained about a vibration.
    you can’t hide TA s
    the original yota wheels are showing their age but are so cool on there. When I paint the truck in the spring I may run them down to the chrome shop.
    Either that or I was thinking the only place where they are rusty is the seam where the center hits the rim. Maybe pinstripe that area? Thick black and a light grey accent stripe? Thoughts?
    bchctybob, porkshop, Oneball and 2 others like this.
  24. Oneball
    Oneball
    Bead of silicone sealant at the joint in the rim?
    Just realised what Yota means :oops:
  25. As a general rule I hate anything Toyota with a p***ion. The ONE exception to that rule is anything with a 20r or 22r lol. Anything that absolutely refuses to die I'm a huge fan of. And I've tried to kill multiple 22r's over the years. Notice I said "tried" lol. One was a 22re in an 89 that hadn't had an oil change since bill Clinton took office. Ran that for twenty miles through the Ozark mountains without realizing a rock had knocked a hole in the decade old oil filter running the oil out. We threw a filter and some cheap oil in it. That was in 04. I saw the same truck with same engine running around Thursday while I was visiting family in Arkansas lol
    Landmule, porkshop and Bandit Billy like this.
  26. Long winded story short I'm a fan of thread lol
  27. Bandit Billy
    Bandit Billy
    Don't worry, I didn't understand until I ht the forums and parts houses. Yota, it's what for brunch.
    I am not a fan of working on foreign cars but my daughter insists on buying them. Her VW van has made me learn to swear in German and these Toyotas are cute but I am an XL trying to squeeze inside a Medium Cadet. But anything for the girl!
    bchctybob, porkshop, Oneball and 5 others like this.
  28. Honestly as rarely as a 22r needs work it gets a p*** on my foreign car mechanic work hatred lol. Of course I am a squirrelly scrawny 5'11" that easily gets into smaller vehicles lol
  29. 40FORDPU
    40FORDPU
    Nice that you're helping your daughter out....and for you, some restraint.
  30. Bandit Billy
    Bandit Billy
    The restraint is very, very difficult to muster. My wife continually reminds me that it is not my truck. I am just happy she decided to let me paint it rather than the "patina" route. Rust is not cool. This is no garage queen, she uses her stuff. I am thinking about painting the graphics on so I can bury them under the clear coat. They'll last longer.
    This was the newest vehicle I have put drum brakes on. A lot going on in there. I did the "take one side apart at a time" method so I would have one to reference. Saved time.
    She is on her way to help bleed the brakes and take it home for the winter. I'll get a pic of it in the drive.
    4 pedals, bchctybob, porkshop and 3 others like this.
