Technical Brake Light Pressure Switch
Discussion in 'Traditional Hot Rods' started by Deyomatic, Nov 10, 2024.
  1. Deyomatic
    Deyomatic
    from CT
    This is in my ‘30 Model A, no clue what the original application would be. Figured I would ask to see if these were fairly universal. Any thoughts on what part number or application to start chasing?
  2. 302GMC
    302GMC
    from Idaho
    Any switch with 1/8'' pipe thread will work. There's at least 10 different configurations of terminals, so pick what serves you best with your wiring.
    dana barlow likes this.
  3. squirrel
    that looks like the type used on Fords....from the 40s-60s.
    SLS27 is a common part number, in stock at OReillys, etc.
    There are problems with how long they last, so maybe you'll want to dive deeper, but there are plenty of threads here about them.
  4. Happydaze
    Happydaze
    Harley D switches fit right in and seem to last.
    Chris
  5. Hotwyr
    Hotwyr
    NAPA SL-134. Fits many applications.
    uncle buck likes this.
  6. Deyomatic
    Deyomatic
    from CT
    Thanks. I will hit up NAPA tomorrow. I’m glad they’re all sort of the same.
    Thanks again.
  7. larry k
    larry k
    Buy the one for motorcycles , the part numbers will always end with M , well I guess for motorcycles !!!
    gimpyshotrods and alanp561 like this.
  8. tim troutman
    tim troutman
    auto zone has a life time warranty 64 f100
    dirt t likes this.
  9. jimmy six
    jimmy six
    Chris …. Is correct ..get a Harley D one
  10. Bandit Billy
    Bandit Billy
    He will have to change his connectors. My HD switch has blades.
    gimpyshotrods and deathrowdave like this.
  11. The older bikes had a switch with threaded studs. I'll guess and say mid-80s or older. But those may be obsolete by now, a bit of minor rewiring is easy.
    Harley didn't even use fuses until the plastic-bodied blade fuses showed up. Everything was circuit breakers. Seems the gl*** fuses couldn't take the vibrations...
  12. 19Fordy
    19Fordy
    Harley switch operates on low pressure . Best one to buy.
  13. pprather
    pprather
    Can someone post a part number for the Harley brake light switch?
  14. Bandit Billy
    Bandit Billy
    My original switch had poles like the OP. Instead of cutting the ends off the harness I made jumper wires to adapt to the new HD style connectors. Now if I lose the switch on the road I can use either type.
  15. Happydaze
    Happydaze
    Here ya go!
    Note where it doesn't come from... makes a refreshing change!
    Chris
    G_Don, Bcap55, chevyfordman and 7 others like this.
  16. Mr48chev
    Those stock Ford Pressure switches didn't last all that long on the cars they came on. I replaced a lot of them in the 70's The one I have on my 48 usually only lasts about two or three years at the most but I attribute that to where and how I drove it.
  17. V8-m
    V8-m
    from Alaska
    Mechanical switches are the best because you can adjust it so that after lightly pressing the brake pedal, the brake light will turn on before the car actually starts braking. I think it's an additional advantage to protect yourself from being hit from behind by another car
    clem, chevyfordman, Toms Dogs and 3 others like this.
  18. Sforzato
    Sforzato
    Same type on my '62 F100, think it was $12 for a new one.
  19. bobss396
    bobss396
    Painless Wiring also has a good one. I got one at NAPA that failed me. It started out fine, then took too much pressure to activate it.
    I have a good one I found on eBay. Also picked up a spare I carry around in the glove box.
  20. Deyomatic
    Deyomatic
    from CT
    Thanks for the help. Picked one up for a Harley Davidson application and it seems to work well. I did the same thing that Bandit Billy did with little jumpers. Stuck a NAPA spare in the trunk, so I can go back and forth in an emergency.
    Thanks again.
  21. atch
    atch
    Thanks for the H-D part number. I've replaced the one in Clarence countless times in the 51 years I've owned it. I'll use a Harley one next time.
    alanp561 likes this.
  22. It looks like the one in Bob Drake's catalog. If you are running Silicon Brake fluid get one from Ron Francis Wire Works https://www.ronfrancis.com, (800) 292-1940. Normal switches won't last with Silicon brake fluid (don't ask me how I know).
  23. uncle buck
    uncle buck
    Another issue could be moisture in the fluid. Brake fluid is a sponge for it and nobody ever flushes it out and change it
  24. Bert Kollar
    Bert Kollar
    I have built 6 cars and used the hydraulic switch in all of them because they are simple, easy to install and , of course, replace. Also, the first build, an off topic car is still in service since 1970 and works fine. That car is a auto cross racer and gets severe use. I keep hoping I will find another switch to work that well but they haven't. In case you are wondering the initial switch came out of a 1964 VW. They obviously know something about brake switches the others don't.
  25. deucemac
    deucemac
    When I first put my roadster on the road in 2009. I used a regular automotive hydraulic brake light switch. I went through several of them in short order. I use silicone fluid they apparently couldn't handle the silicone. I bought a switch from a Harley dealer and never looked back. That was in 2010. About 40k miles later and still working like it should. The only change necessary was changing the two connectors to match the Harley switch. Easy Peasy!
    2OLD2FAST likes this.
  26. Super Streak
    Super Streak
    from Florida
    I've got a Ron Frances switch in mine, it's been on there for 6 years with no problem.
    I'm using silicone brake fluid in the brake system.
  27. From the guy who currently has 5 Harley Davidsons sitting in my ba*****t, spend the extra money and ONLY buy the Genuine Part from the Harley Davidson dealership. All the aftermarket ones are cheap ****, made in Asian countries.
    alanp561, deucemac and jimmy six like this.
  28. I got rid of the hydraulic switch on my '55 Ford. Used a brake light switch for '67-72 Ford pickup. It's a push ****on switch (****on in=off, ****on out=on) Drilled a hole in the pedal bracket where the rubber bumper on the pedal works the brake light switch.
    nochop likes this.
  29. seb fontana
    seb fontana
    from ct
  30. HRBOB34
    HRBOB34
    ECI Vernon ct. makes a great one!
    Check out there web page
